https://en.wikipedia.org/wiki/Vought_F4U_Corsair
The Vought F4U Corsair is an American fighter aircraft that saw service primarily in World War II and the Korean War. Demand for the aircraft soon overwhelmed Vought's manufacturing capability, resulting in production by Goodyear and Brewster: Goodyear-built Corsairs were designated FG and Brewster-built aircraft F3A. From the first prototype delivery to the U.S. Navy in 1940, to final delivery in 1953 to the French, 12,571 F4U Corsairs were manufactured, in 16 separate models, in the longest production run of any piston-engined fighter in U.S. history (1942–53). The Corsair was designed as a carrier-based aircraft but its difficult carrier landing performance rendered it unsuitable for Navy use until the carrier landing issues were overcome by the British Fleet Air Arm. The Corsair thus came to and retained prominence in its area of greatest deployment: land based use by the U.S. Marines. The role of the dominant U.S. carrier based fighter in the second part of the war was thus filled by the Grumman F6F Hellcat, powered by the same Double Wasp engine first flown on the Corsair's first prototype in 1940. The Corsair served to a lesser degree in the U.S. Navy. As well as the U.S. and British use the Corsair was also used by the Royal New Zealand Air Force, the French Navy Aéronavale and other, smaller, air forces until the 1960s. Some Japanese pilots regarded it as the most formidable American fighter of World War II, and the U.S. Navy counted an 11:1 kill ratio with the F4U Corsair. After the carrier landing issues had been tackled, it quickly became the most capable carrier-based fighter-bomber of World War II. The Corsair served almost exclusively as a fighter-bomber throughout the Korean War and during the French colonial wars in Indochina and Algeria. Role Carrier-based fighter aircraft National origin United States Manufacturer Chance Vought First flight 29 May 1940 Introduction 28 December 1942 Retired 1979 (Honduras) Primary users United States Navy United States Marine Corps Royal Navy Royal New Zealand Air Force Produced 1942–53[1] Number built 12,571 Developed into Goodyear F2G Corsair Engine considerations The F4U incorporated the largest engine available at the time: the 2,000 hp (1,500 kW) 18-cylinder Pratt & Whitney R-2800 Double Wasp radial. To extract as much power as possible, a relatively large Hamilton Standard Hydromatic three-blade propeller of 13 feet 4 inches (4.06 m) was used. Landing gear and wings To accommodate a folding wing the designers considered retracting the main landing gear rearward but, for the chord of wing that was chosen, it was difficult to make the landing gear struts long enough to provide ground clearance for the large propeller. Their solution was an inverted gull wing, which considerably shortened the required length of the main gear legs.[24] The anhedral of the wing's center-section also permitted the wing and fuselage to meet at the optimum angle for minimizing drag, without using wing root fairings.[24] The bent wing, however, was heavier and more difficult to construct, offsetting these benefits. The U.S. Navy received its first production F4U-1 on 31 July 1942, but getting it into service proved difficult. The framed "birdcage" style canopy provided inadequate visibility for deck taxiing. Even more seriously, the machine had a nasty tendency to "bounce" on touchdown, which could cause it to miss the arresting hook and slam into the crash barrier, or even go out of control. The long "hose nose" visibility problem and the enormous torque of the Double Wasp engine also created operational problems. Marine Corps combat From February 1943 onward, the F4U operated from Guadalcanal and ultimately other bases in the Solomon Islands. A dozen USMC F4U-1s of VMF-124, commanded by Major William E. Gise, arrived at Henderson Field (code name "Cactus") on 12 February. The first recorded combat engagement was on 14 February 1943, when Corsairs of VMF-124 under Major Gise assisted P-40s and P-38s in escorting a formation of Consolidated B-24 Liberators on a raid against a Japanese aerodrome at Kahili. Japanese fighters contested the raid and the Americans got the worst of it, with four P-38s, two P-40s, two Corsairs and two Liberators lost. No more than four Japanese Zeros were destroyed. A Corsair was responsible for one of the kills, although this was due to a midair collision. The fiasco was referred to as the "Saint Valentine's Day Massacre".[43][44] Despite the debut, the Marines quickly learned how to make better use of the aircraft and started demonstrating its superiority over Japanese fighters. By May, the Corsair units were getting the upper hand, and VMF-124 had produced the first Corsair ace, Second Lieutenant Kenneth A. Walsh, who would rack up a total of 21 kills during the war.[45] He remembered: "I learned quickly that altitude was paramount. Whoever had altitude dictated the terms of the battle, and there was nothing a Zero pilot could do to change that — we had him. The F4U could outperform a Zero in every aspect except slow speed manoeuvrability and slow speed rate of climb. Therefore you avoided getting slow when combating a Zero. It took time but eventually we developed tactics and deployed them very effectively... There were times, however, that I tangled with a Zero at slow speed, one on one. In these instances I considered myself fortunate to survive a battle. Of my 21 victories, 17 were against Zeros, and I lost five aircraft in combat. I was shot down three times and I crashed one that ploughed into the line back at base and wiped out another F4U. Specifications F4U-1A[edit] Data from WWII Aircraft Performance[130] The Aviation History Online Museum[131] General characteristics Crew: 1 pilot Length: 33 ft 4 in (10.1 m) Wingspan: 41 ft 0 in (12.5 m) Height: 16 ft 1 in (4.90 m) Wing area: 314 ft2 (29.17 m2) Empty weight: 8,982 lb (4,073 kg) Loaded weight: 11,432 lb (5,185 kg) Powerplant: 1 × Pratt & Whitney R-2800-8 radial engine, 2,000 hp (1,491 kW) Performance Maximum speed: 417 mph (362 kn, 671 km/h) Range: 1,015 mi (882 nmi (1,633 km)) Service ceiling: 36,900 ft (11,247 m) Rate of climb: 2,890 ft/min (15.2 m/s) Armament Guns: 6 × 0.50 in (12.7 mm) M2 Browning machine guns, 400 rounds per gun 4 × 20 mm AN/M2 cannons, 375 rounds per gun Rockets: 4 × 5 in (12.7 cm) High Velocity Aircraft Rockets and/or Bombs: 2,000 pounds (910 kg) F4U-4 General characteristics Crew: 1 pilot Length: 33 ft 8 in (10.2 m) Wingspan: 41 ft 0 in (12.5 m) WS Folded: 17 ft 0.5 in (5.2 m) Height: 14 ft 9 in (4.50 m) Empty weight: 9,205 lb (4,174 kg) Loaded weight: 12,405 lb (5,626 kg) Powerplant: 1 × Pratt & Whitney R-2800-18W radial engine, 2,380 hp (1,775 kW) Performance Maximum speed: 446 mph (717 km/h) at 26.200 ft (using emergency power) Stall speed: 89 mph (143 km/h) clean Range: 1005 mi (1617 km) on internal fuel Combat radius: 285 nmi (328 mi, 527 km) with one external 150gal tank Service ceiling: 41,500ft (12,649 m) Rate of climb: 4,360ft/min (22.1 m/s) at sea-level (using emergency power) Armament Guns: 6 × 0.50 in (12.7 mm) M2 Browning machine guns, 400 rounds per gun or 4 × 0.79 in (20 mm) AN/M2 cannon Rockets: 8 × 5 in (12.7 cm) high velocity aircraft rockets and/or Bombs: 4,000 pounds (1,800 kg) * |
Vought F4U Corsair pics [19/19] - Vought-F4U-Corsair-Images.jpg (1/1) | Miloch | Aviation Photos | 3 | June 20th 16 04:42 AM |
Vought F4U Corsair pics [16/19] - Vought F4U Corsair Aircraft 4.jpg (1/1) | Miloch | Aviation Photos | 0 | June 20th 16 01:15 AM |
Vought F4U Corsair pics [14/19] - Vought F4U Corsair Aircraft 2.jpg (1/1) | Miloch | Aviation Photos | 0 | June 20th 16 01:15 AM |
Vought F4U Corsair pics [13/19] - Vought F4U Corsair Aircraft.jpg (1/1) | Miloch | Aviation Photos | 0 | June 20th 16 01:15 AM |
Vought F4U Corsair pics [12/19] - Reno Air Races F4U Corsair.jpg (1/1) | Miloch | Aviation Photos | 0 | June 20th 16 01:15 AM |
