state tax question
Old April 5th 17, 08:30 PM posted to rec.aviation.soaring
Del Jensen
Default state tax question
You guys are probably tired of these kinds of questions, but I have been searching the web and haven't found the answer to my situation.
I recently purchased a glider in AZ, where I intend to keep it and fly it. I am a Utah resident, and the bill of sale and FAA registration so indicate.
My intention is to pay the AZ sales tax, along with state registration. Will this trigger a beef with Utah? Can one be obliged to pay sales tax to two states, simply because one has primary residence in a different state than that where a purchased asset is located and utilized?
Many thanks for any insight on this.
Del
Old April 6th 17, 02:18 AM posted to rec.aviation.soaring
Roy B.
Del:
While tax enforcement can vary from state to state - you should be OK with Utah as long as the glider isn't used, stored or tied down in Utah. There are legal/constitutional limits on a state's ability to tax an item that is (and always was) outside of it's territory and the mere fact that a Utah resident owns it is not likely to be enough to tax it if it was never in Utah. By way of illustration, if you owned a piece of real estate in AZ it's not likely that Utah could tax it. Just keep it out of Utah.
ROY
Old April 6th 17, 02:25 AM posted to rec.aviation.soaring
Ron Gleason
I recently purchased a glider in AZ, where I intend to keep it and fly it.. I am a Utah resident, and the bill of sale and FAA registration so indicate.
Del
Make sure you register in AZ and you deal with the AZ FSDO correctly
Mike Schumann[_2_]
Del
If for some reason, you decide to move the glider to UT, they may want you to pay sales tax there. However, you will be entitled to get a credit for the sales tax you previously paid to AZ, so you will only have to pay the difference between the two state's tax rates. If the AZ sales tax rate is higher than UT, you won't owe them any money at all.
Old April 6th 17, 03:01 AM posted to rec.aviation.soaring
Bruce
Del
Del,
If you purchased your glider from an individual as opposed to a business, there will be no sales tax in Arizona. You need to register it in AZ and it will cost you $25 a year.
Old April 6th 17, 05:39 AM posted to rec.aviation.soaring
Del Jensen
Del
Del,
Thanks, guys. I started to worry after reading some war stories out there where people were getting hit for multiple tax bills after buying aircraft.
I've already been in touch with my FSDO. Since the glider isn't changing its home airport, it looks like all I'll have to do is file a program letter.. The rest of the airworthiness certificate stays in place. Thanks for the reminder on state registration - I'll have to register both glider and trailer.
Old April 6th 17, 06:55 AM posted to rec.aviation.soaring
Frank Whiteley
Del
Del,
Old April 6th 17, 04:46 PM posted to rec.aviation.soaring
Dan Marotta
You'll also have to file a Bill of Sale and registration with the FAA.
Regarding trailer registration, a lot of people have Kansas plates. It's
my understanding that Kansas does not register trailers under 2,000
pounds but they provide a plate for people traveling out of KS. I've
seen plenty of them on glider trailers all over the country. You can
also find them online. Maybe somebody from Kansas will chime in about
that. I don't know about legalities for non-KS residents...
Del
Del,
I've already been in touch with my FSDO. Since the glider isn't changing its home airport, it looks like all I'll have to do is file a program letter. The rest of the airworthiness certificate stays in place. Thanks for the reminder on state registration - I'll have to register both glider and trailer.
Dan, 5J
Old April 7th 17, 02:41 AM posted to rec.aviation.soaring
Frank Whiteley
Del
Del,
Dan, 5J
Those are just Steve Leonard's trailers Dan.
Frank Whiteley
Old April 7th 17, 04:38 PM posted to rec.aviation.soaring
Dan Marotta
Snip
Frank Whiteley
Uhhhhh... Actually, no. There are others...
Dan, 5J
State and National records question Gary Emerson Soaring 3 January 22nd 07 11:14 PM
US - State Record question - handicapping Mike Johnson Soaring 4 March 22nd 05 08:47 PM
question about the state of the arts of landing aids on aircraft carriers Charlie Wolf Naval Aviation 0 March 6th 05 02:25 AM
State Record Rules Question Gary Emerson Soaring 2 February 22nd 05 03:30 AM
State Record Question - Minimum Increase for Distance Records Gary Emerson Soaring 3 November 11th 03 04:18 PM
