AirGlide/Butterfly Vario Setup
Old April 11th 17, 11:05 PM posted to rec.aviation.soaring
2G
Default AirGlide/Butterfly Vario Setup
On Saturday, April 8, 2017 at 12:20:45 PM UTC-7, Fox Two wrote:
Does anybody know how to input your glider's empty weight? I've found pilot weight and ballast weight, but not empty glider weight.
Thanks,
Chris
There is no way to input the glider's empty weight, AFAIK. The weight is included in the glider type that you select from MENU SETUP Vario Aircraft (scroll down to your glider and select). You can enter ballast and the pilot weight, however:
MENU Flight Ballast
MENU Flight Pilot Weight
These will be added to the empty weight for your glider type.
Tom
Butterfly vario Steve Parker Soaring 12 September 18th 14 09:41 PM
Where are you Butterfly vario? [email protected] Soaring 17 May 25th 14 05:49 AM
Butterfly Vario IGC Richard[_9_] Soaring 3 April 3rd 13 03:24 PM
New Butterfly Vario Paul Remde Soaring 238 February 20th 12 04:05 AM
Vario setup brianDG303 Soaring 1 April 3rd 08 05:20 PM
