https://en.wikipedia.org/wiki/Boeing...tratofreighter
The Boeing C-97 Stratofreighter is a long-range heavy military cargo aircraft developed from the B-29 and B-50 bombers. Design work began in 1942, with the prototype's first flight being on 9 November 1944, and the first production aircraft entered service in 1947. Between 1947 and 1958, 888 C-97s in several versions were built, 811 being KC-97 tankers. C-97s served in the Berlin Airlift, the Korean War, and the Vietnam War. Some aircraft served as flying command posts for the Strategic Air Command, while others were modified for use in Aerospace Rescue and Recovery Squadrons (ARRS). Design and development The C-97 Stratofreighter was developed towards the end of World War II by fitting an enlarged upper fuselage onto a lower fuselage and wings which were essentially the same as those of the B-29 Superfortress with the tail, wing, and engine layout being nearly identical. It was built before the death of Boeing president Philip G. Johnson. It can be easily distinguished from the 377 Stratocruiser by the "beak" radome beneath the nose and by the flying boom and jet engines on later tanker models. The prototype XC-97 was powered by the 2,200 hp (1,600 kW) Wright R-3350 engine, the same as used in the B-29. The XC-97 took off for its first flight on November 9, 1944. The tenth and all subsequent aircraft were fitted with the taller fin and rudder of the B-50 Superfortress. The C-97 had clamshell doors under its tail, so that a retractable ramp could be used to drive in cargo. However, unlike the later Lockheed C-130 Hercules, it was not designed as a combat transport which could deliver directly to primitive forward bases using relatively short takeoffs and landings. The rear ramp could not be used in flight for air drops. Role Military transport aircraft Manufacturer Boeing First flight 9 November 1944 Introduction 1947 Retired 1978 Primary users United States Air Force Israeli Air Force Produced 1944–1952 Number built 77 (total of 888 in all variants) Unit cost $1,205,000 Developed from Boeing B-29 Superfortress Boeing B-50 Superfortress Variants Boeing KC-97 Stratofreighter Boeing 377 Stratocruiser Aero Spacelines Pregnant Guppy Aero Spacelines Super Guppy Aero Spacelines Mini Guppy The C-97 had a useful payload of 35,000 lb (16,000 kg) and could carry two normal trucks, towed artillery, or light tracked vehicles such as the M56 Scorpion. The C-97 was also the first mass-produced air transport to feature cabin pressurization, which made long range missions somewhat more comfortable for its crew and passengers. The civilian derivative of the C-97 was the Boeing 377 Stratocruiser, a very luxurious transoceanic airliner which featured a lower deck lounge and could be fitted with sleeper cabins. The first Stratocruiser flew on July 8, 1947. Only 56 were built. C-97s evacuated casualties during the Korean War. C-97s also participated in the Biafran airlift, delivering relief materials to Uli airstrip in Biafra during the Nigerian Civil War. Flying under the cover of darkness and at treetop level to evade radar, at least two C-97s were lost.[6] Boeing KC-97G Stratofreighter of the Minnesota Air National Guard in 1971 after service as part of Military Airlift Command The USAF Strategic Air Command operated C-97 Stratofreighters from 1949–1978. Early in its service life, it served as an airborne alternative SAC command post. While only 77 C-97 transports were built, 811 were built as KC-97 Stratofreighters for inflight refueling. Many KC-97s were later refitted as C-97G transports and equipped several squadrons of the US Air National Guard. Two C-97s are still airworthy at the present day, one (s/n 52-2718, named "Angel of Deliverance") operated as a privately owned warbird, the other operated as a fire bomber in the United States. Specifications (C-97) General characteristics Crew: 5–6 (Pilot, Copilot, Navigator, Flight engineer, 1–2 Loadmasters) Capacity: 134 troops[45] or 69 stretchers or tanker equipment Length: 110 ft 4 in (33.7 m) Wingspan: 141 ft 3 in (43.1 m) Height: 38 ft 3 in (11.7 m) Wing area: 1,734 ft² (161.1 m²) Empty weight: 82,500 lb (37,410 kg) Loaded weight: 120,000 lb (54,420 kg) Useful load: 37,500 lb (17,010 kg) Max. takeoff weight: 175,000 lb (79,370 kg) Powerplant: 4 × Pratt & Whitney R-4360B Wasp Major radial engines, 3,500 hp (2,610 kW) 28-cylinders each Performance Maximum speed: 375 mph (603 km/h) Cruise speed: 260 knots (300 mph, 482 km/h) Range: 4,949 mi (4,300 nm, 6,920 km) Ferry range: 5,000 nm (5,760 mi, 9,270 km) Service ceiling: 35,000 ft (10,670 m) Wing loading: 69.2 lb/ft² (337.8 kg/m²) Power/mass: 0.117 hp/lb (192 W/kg) * |
"Miloch" wrote in message ...
https://en.wikipedia.org/wiki/Boeing...tratofreighter Here's the one I'll always remember: https://aviation-safety.net/database...?id=19870730-0 Here was this "apron queen" that had been sitting on the tarmac, exposed to the elements for twenty years until someone got the bright idea to get it into their air and make a quick buck by flying a load of race horses to Florida. Taking off overloaded and in the thin air of Mexico City, the crew discovered they couldn't fly over the mountains. Once they saw there was no hope of making it back to the airport, they aimed for the Mexico City-Toluca highway, fled the cockpit and raced back to the tail section, awaiting the impact, which killed one crewman, four passengers, and 44 on the ground. One of the survivors was the man in charge of caring for the horses, two of which actually survived. I won't soon forget the news footage of this forlorn-looking horse just standing there amid the wreckage... http://articles.chicagotribune.com/1...-plane-crashed http://www.nytimes.com/1987/07/31/wo...xico-city.html |
Pima museum Batch 3 [41/43] - C-97F Stratofreighter DSC_3242.jpg (1/1) | Indrek | Aviation Photos | 0 | December 24th 10 11:47 PM |
Pima museum Batch 3 [40/43] - C-97F Stratofreighter DSC_3240.jpg (1/1) | Indrek | Aviation Photos | 0 | December 24th 10 11:47 PM |
Pima museum Batch 3 [39/43] - C-97F Stratofreighter DSC_3239.jpg (1/1) | Indrek | Aviation Photos | 0 | December 24th 10 11:47 PM |
Military Cockpits C-97K Stratofreighter.jpg (1/1) | J.F. | Aviation Photos | 0 | October 7th 07 01:07 AM |
Military Cockpits C-97G Stratofreighter.jpg (1/1) | J.F. | Aviation Photos | 0 | October 7th 07 01:07 AM |
