https://en.wikipedia.org/wiki/McDonnell_XP-67
The McDonnell XP-67 "Bat" or "Moonbat" was a prototype for a twin-engine, long-range, single-seat interceptor aircraft for the United States Army Air Forces. Although the design was conceptually advanced, it was beset by numerous problems and never approached its anticipated level of performance. The project was cancelled after the sole completed prototype was destroyed by an engine fire. In 1940, the U.S. Army Air Corps issued Request for Proposal R-40C, requesting designs for a high-speed, long-range, high-altitude interceptor intended to destroy enemy bombers. The specifications were very bold, encouraging manufacturers to produce radical aircraft that would outperform any existing fighter in the world at the time. The aerospace parts manufacturer McDonnell Aircraft, eager to begin manufacturing its own aircraft, responded to the proposal with drawings and specifications of the proposed Model I, which would be powered by an unusual geared drivetrain with a single Allison V-3420 engine buried in the fuselage powering twin wing-mounted pusher propellers in the wings. However, 22 other manufacturers also issued proposals to meet the Army's request; the McDonnell proposal had relatively unimpressive anticipated performance, and its odd drivetrain was unproven. The Model I fell in 21st place when the 23 proposals were examined and scored. The proposals that were accepted included the similarly ill-fated XP-54, XP-55, and XP-56. Despite the apparent setback, Air Corps leaders were impressed by the nascent company's efforts, and granted McDonnell a $3,000 contract to re-engineer the aircraft. On 30 September 1941, the USAAF granted McDonnell a $1,508,596 contract, plus an $86,315 fee, for two prototypes, a wind tunnel model, and associated engineering data. The Model IIa was designated as the XP-67. The production aircraft was intended to have a pressurized cockpit, a novel innovation at the time. A number of armament configurations were considered including six .50 in (12.7 mm) machine guns, four 20 mm (.79 in) cannon, and even a 75 mm (2.95 in) cannon before the configuration of six 37 mm (1.46 in) M4 cannon was chosen. Power would be provided by two Continental XIV-1430-1 inverted V-12 engines, fitted with turbosuperchargers, and the engine exhaust gases would augment thrust. Role Interceptor Manufacturer McDonnell Aircraft First flight 6 January 1944 Status Cancelled on 13 September 1944 Primary user United States Army Air Forces Number built 1 Program cost US$4,742,746 ....By this time, it was becoming obvious that the XP-67 was hampered by a serious lack of power. The engines were only delivering 1,060 hp (790 kW), well short of their promised 1,350 hp (1,007 kW) rating. Although McDonnell promised a very impressive 500 mph (805 km/h) top speed with the new powerplants, the Army rejected the proposal, demanding more testing of the existing design. As a result of wind tunnel tests, the tailplanes were raised 12 in (31 cm) while the XP-67 waited for replacement engines. On 6 September 1944, the starboard engine of the XP-67 caught fire during a test flight, and test pilot E.E. Elliot executed an emergency landing at Lambert Field in St. Louis, Missouri. He attempted to park the craft pointing into the wind to blow the flames away from the airframe, but the starboard main landing gear brakes failed, pivoting the XP-67 so the flames blew directly towards the aft fuselage. Elliot escaped safely, but the blaze gutted the fuselage, engine, nacelle and starboard wing; the aircraft was a total loss. The destruction of the lone flying prototype dealt a serious blow to the entire program because the second prototype was only 15% complete at the time. Army leaders decided to reevaluate the XP-67, ultimately deciding on 13 September that it offered no significant advantages over existing fighters already in service. The project was canceled, the remains of the first prototype were scrapped, and work was halted on the second prototype. Specifications (XP-67) General characteristics Crew: one, pilot Length: 44 ft 9¼ in (13.65 m) Wingspan: 55 ft (16.76 m) Height: 15 ft 9 in (4.80 m) Wing area: 414 ft2 (38.50 m2) Empty weight: 17,745 lb (8,049 kg) Loaded weight: 22,114 lb (10,031 kg) Max. takeoff weight: 25,400 lb (11,521 kg) Powerplant: 2 × Continental XIV-1430-17/19 twelve cylinder inverted vee liquid-cooled engine, 1,350 hp (1,007 kW) each Performance Maximum speed: 405 mph (352 knots, 650 km/h) at 25,000 ft (7,600 m) Cruise speed: 270 mph (235 knots, 435 km/h) Range: 2,385 mi (2,074 nmi, 3,837 km) Service ceiling: 37,400 ft (11,400 m) Rate of climb: 2,600 ft/min (12.7 m/s) Wing loading: 53.4 lb/ft2 (260 kg/m2) Power/mass: 0.06 hp/lb (0.09 kW/kg) Armament Guns: 6 × 37 mm (1.46 in) M4 cannons (never installed in prototype) * |
McDonnell F-101 Voodoo pics [19/19] - McDonnell-F-101-Voodoo-046_preview.jpg (1/1) | Miloch | Aviation Photos | 0 | July 11th 16 12:40 AM |
McDonnell F-101 Voodoo pics [18/19] - McDonnell-F-101-Voodoo-035_preview.jpg (1/1) | Miloch | Aviation Photos | 0 | July 11th 16 12:40 AM |
McDonnell F-101 Voodoo pics [17/19] - McDonnell-F-101-Voodoo-023_preview.jpg (1/1) | Miloch | Aviation Photos | 0 | July 11th 16 12:40 AM |
McDonnell F-101 Voodoo pics [16/19] - McDonnell-F-101-A-Voodoo-.jpg (1/1) | Miloch | Aviation Photos | 0 | July 11th 16 12:40 AM |
McDonnell F-101 Voodoo pics [15/19] - mcdonnell-f101-voodoo_2.jpg (1/1) | Miloch | Aviation Photos | 0 | July 11th 16 12:40 AM |
