It needs jets.
The Champion part number breakdown for this plug is
U - Auxilliary gap G - 10mm thread ?? ( could also be 18mm! ) 80 - special/custom heat range P - Platinum electrode V - surface Gap ( electrode flush with thread body no extended 'arm' ) Perhaps this might help in your search! http://www.championaerospace.com/ - the manufacturers web site along with their distibutor list. Ian "Ludovic Launer" wrote in message ... Hi, I'm looking for spark plugs for an ASH26E They are : CHAMPION UG80PV If anyone knows where I could get hold of these.. anywhere on the globe !, that would be wonderful... Equivalent spark plugs (other manufacturer, ...) would also do ! Thanks Ludovic Launer |
Hi Ludovic
You have to change to a Bosch type for the spark plug - but for that is some mechanical work to do on the engine side. Please call Schleicher. Dieter Ludovic Launer schrieb in im Newsbeitrag: ... Hi, I'm looking for spark plugs for an ASH26E They are : CHAMPION UG80PV If anyone knows where I could get hold of these.. anywhere on the globe !, that would be wonderful... Equivalent spark plugs (other manufacturer, ...) would also do ! Thanks Ludovic Launer |
Dieter Mühlethaler wrote:
Hi Ludovic You have to change to a Bosch type for the spark plug - but for that is some mechanical work to do on the engine side. Please call Schleicher. Dieter Dieter is correct. The Champion plugs are not available anymore (except by luck, if you find someone with a few forgotten ones), and the factory now uses a Bosch plug. Older engines must make a simple (15 minute) modification to the engine to use the Bosch plug. Your dealer or Schleicher can loan you the tool to do this. A year ago, Martin Heide told me the plugs were originally used in racing cars in Europe, but not anymore, and the supplies have been used up. That is why they had to switch to a different plug. Several years ago, I talked to a Champion engineer, who said they were also used in some military tanks. They were produced in very small quantities for special orders only, and he did not expect Champion would ever make them again because of the high cost and very low demand. -- ----- change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
Owner Change/rotate spark plugs? | Victor J. Osborne, Jr. | Owning | 34 | February 25th 05 07:19 PM |
Spark plug question: Massive electrode or fine wire? | Peter R. | Owning | 9 | February 4th 05 02:03 AM |
Bougies blindées BG à vendre/BG spark plugs for sale | stef | General Aviation | 0 | May 14th 04 04:57 PM |
Color of spark plugs | john smith | Owning | 5 | March 2nd 04 03:08 AM |
2nd update on Review of Plasma II Ignition System | MikeremlaP | Home Built | 8 | July 22nd 03 01:37 AM |
