![]() https://en.wikipedia.org/wiki/Genera...cs_MQ-9_Reaper The General Atomics MQ-9 Reaper (sometimes called Predator B) is an unmanned aerial vehicle (UAV) capable of remotely controlled or autonomous flight operations, developed by General Atomics Aeronautical Systems (GA-ASI) primarily for the United States Air Force (USAF). The MQ-9 and other UAVs are referred to as Remotely Piloted Vehicles/Aircraft (RPV/RPA) by the USAF to indicate their human ground controllers. The MQ-9 is the first hunter-killer UAV designed for long-endurance, high-altitude surveillance. In 2006, the then–Chief of Staff of the United States Air Force General T. Michael Moseley said: "We've moved from using UAVs primarily in intelligence, surveillance, and reconnaissance roles before Operation Iraqi Freedom, to a true hunter-killer role with the Reaper." The MQ-9 is a larger, heavier, and more capable aircraft than the earlier General Atomics MQ-1 Predator; it can be controlled by the same ground systems used to control MQ-1s. The Reaper has a 950-shaft-horsepower (712 kW) turboprop engine (compared to the Predator's 115 hp (86 kW) piston engine). The greater power allows the Reaper to carry 15 times more ordnance payload and cruise at about three times the speed of the MQ-1. The aircraft is monitored and controlled by aircrew in the Ground Control Station (GCS), including weapons employment. In 2008, the New York Air National Guard 174th Attack Wing began the transition from F-16 piloted fighters to MQ-9 Reapers, becoming the first fighter squadron conversion to an all–unmanned combat aerial vehicle (UCAV) attack squadron. In March 2011, the U.S. Air Force was training more pilots for advanced unmanned aerial vehicles than for any other single weapons system. The Reaper is also used by the United States Navy, the CIA, U.S. Customs and Border Protection, NASA, and the militaries of several other countries. The USAF plans to keep the MQ-9 in service into the 2030s. A typical MQ-9 system consists of multiple aircraft, ground control station, communications equipment, maintenance spares, and personnel. A military crew comprises a pilot, sensor operator, and Mission Intelligence Coordinator. The aircraft is powered by a 950 horsepower (710 kW) turboprop, with a maximum speed of about 260 knots (480 km/h; 300 mph) and a cruising speed of 150–170 knots (170–200 mph; 280–310 km/h). With a 66 ft (20 m) wingspan, and a maximum payload of 3,800 lb (1,700 kg), the MQ-9 can be armed with a variety of weaponry, including Hellfire missiles and 500-lb laser-guided bomb units. Endurance is 30 hours when conducting ISR missions, which decreases to 23 hours if it is carrying a full weapon load. The Reaper has a range of 1,000 nmi (1,150 mi; 1,850 km) and an operational altitude of 50,000 ft (15,000 m), which makes it especially useful for long-term loitering operations, both for surveillance and support of ground troops. Role Unmanned combat aerial vehicle National origin United States Manufacturer General Atomics Aeronautical Systems First flight 2 February 2001 Introduction 1 May 2007 Status In service Primary users United States Air Force U.S. Customs and Border Protection Royal Air Force Italian Air Force Number built 163 as of 2014 Program cost US$11.8 billion Unit cost US$16.9 million (flyaway cost, 2013) Developed from General Atomics MQ-1 Predator Developed into General Atomics Avenger On 13 September 2009, positive control of an MQ-9 was lost during a combat mission over Afghanistan, after which the control-less drone started flying towards the Afghan border with Tajikistan. An F-15E Strike Eagle shot it down with an AIM-9 missile. It was the first US drone to be destroyed intentionally by allied forces. By July 2010, thirty-eight Predators and Reapers had been lost during combat operations in Afghanistan and Iraq, another nine were lost in training missions in the U.S. In 2010, the USAF conducted over 33,000 close air support missions, a more-than-20 percent increase compared with 2009. By March 2011, the USAF had 48 Predator and Reaper combat air patrols flying in Iraq and Afghanistan compared with 18 in 2007. On 22 October 2013, the USAF's fleets of MQ-1 Predator and MQ-9 Reaper UAVs reached 2,000,000 flight hours. The RPA program began in the mid-1990s, taking 16 years for them to reach 1 million flight hours; the 2 million hour mark was reached just two and a half years later. The high demand for UAVs has caused Air Combat Command to increase pilot output from 188 in 2015 to 300 in 2017 at Holloman. On 13 November 2015, the Pentagon reported that an MQ-9 had killed ISIL member Mohammed Emwazi, popularly known as "Jihadi John," who was responsible for executing several Western prisoners. Specifications General characteristics Crew: 0 onboard, 2 in ground station Length: 36 ft 1 in (11 m) Wingspan: 65 ft 7 in (20 m) Height: 12 ft 6 in (3.81 m) Empty weight: 4,901 lb (2,223 kg) Max takeoff weight: 10,494 lb (4,760 kg) Fuel capacity: 4,000 lb (1,800 kg) Payload: 3,800 lb (1,700 kg) Internal: 800 lb (360 kg) External: 3,000 lb (1,400 kg) Powerplant: 1 × Honeywell TPE331-10 turboprop, 900 hp (671 kW) with Digital Electronic Engine Control (DEEC) Performance Maximum speed: 300 mph; 260 kn (482 km/h) Cruise speed: 194 mph; 169 kn (313 km/h) Range: 1,151 mi; 1,852 km (1,000 nmi) Endurance: 14 hours fully loaded Service ceiling: 50,000 ft (15,000 m) Operational altitude: 25,000 ft (7.5 km) Armament 7 hardpoints Up to 1,500 lb (680 kg) on the two inboard weapons stations Up to 750 lb (340 kg) on the two middle stations Up to 150 lb (68 kg) on the outboard stations Center station not used Up to 4 AGM-114 Hellfire air to ground missiles can be carried or four Hellfire missiles and two 500 lb (230 kg) GBU-12 Paveway II laser-guided bombs. The 500 lb (230 kg) GBU-38 Joint Direct Attack Munition (JDAM) can also be carried. Testing is underway to support the operation of the AIM-92 Stinger air-to-air missile. In March 2014, MBDA successfully test fired a dual mode Brimstone missile from a Reaper aircraft on behalf of the UK Ministry of Defence and Royal Air Force. Avionics AN/DAS-1 MTS-B Multi-Spectral Targeting System AN/APY-8 Lynx II radar Raytheon SeaVue Marine Search Radar (Guardian variants) * |
General Atomics MQ-1 Predator pics 2 [01/11] - general-atomics-mq1-predator-uav-drone-united-states_5.jpg (1/1) | Miloch | Aviation Photos | 0 | May 2nd 17 03:30 PM |
General Atomics MQ-1 Predator pics 1 [09/11] - general-atomics-mq1-predator-uav-drone-united-states_2.jpg (1/1) | Miloch | Aviation Photos | 0 | May 2nd 17 03:28 PM |
General Atomics MQ-1 Predator pics 1 [08/11] - general-atomics-mq1-predator-uav-drone-united-states.jpg (1/1) | Miloch | Aviation Photos | 0 | May 2nd 17 03:28 PM |
General Atomics MQ-1 Predator pics 1 [07/11] - general-atomics-mq-1-predator-drone-20.jpg (1/1) | Miloch | Aviation Photos | 0 | May 2nd 17 03:28 PM |
General Atomics MQ-1 Predator pics 1 [03/11] - General Atomics MQ-1 Predator 3.jpg (1/1) | Miloch | Aviation Photos | 0 | May 2nd 17 03:28 PM |
