I'm promted to ask a question having read the postings
regarding the different views expressed, in another thread, regarding the wearing of parachutes in the UK and USA. When, as a UK pilot on holiday, flying in the USA a couple of years ago, the CFI demonstrated his preferred landing technique which involved progressively reducing airbrakes as one approached the ground. This gave rise to very prolonged 'hold-offs' and touchdown at the stall. Was this a local quirk? Would appreciate the views of those more qualified than I on the pro's and con's of such an approach. For my own point of view, it struck me that this American technique made spot landing more difficult. Also, I was concerned that there was a prologed period of very slow flying close to the ground. Any thoughts? |
![]() "Steve Hopkins" k wrote in message ... I'm promted to ask a question having read the postings regarding the different views expressed, in another thread, regarding the wearing of parachutes in the UK and USA. When, as a UK pilot on holiday, flying in the USA a couple of years ago, the CFI demonstrated his preferred landing technique which involved progressively reducing airbrakes as one approached the ground. This gave rise to very prolonged 'hold-offs' and touchdown at the stall. Was this a local quirk? Would appreciate the views of those more qualified than I on the pro's and con's of such an approach. For my own point of view, it struck me that this American technique made spot landing more difficult. Also, I was concerned that there was a prologed period of very slow flying close to the ground. Any thoughts? Despite many efforts, US flight instruction in gliders is far from standardized. I have of heard the technique you encountered and disapprove of it for the most part. Changing the amount of spoilers deployed while in the flare is inviting trouble - not to say never do it, just expect it to be tricky. Many CFI-G's have never flown a glider cross country or, for that matter, at any other locale than those with a long paved runways. Getting the glider down and stopped in the shortest distance is not something they have thought about very much. I prefer a fairly steep glide path to a flair with spoilers left where they were in the approach followed by a low-energy touchdown and a short rollout. Pretty much what I would expect to do in an off-field landing. Bill Daniels |
Bill Daniels wrote:
... Despite many efforts, US flight instruction in gliders is far from standardized. ... Thanks to many efforts, french flight instruction in gliders is (or at least should be) standardized. The standard say students should first learn to keep the airbrakes during roundout at the half efficiency position they had during the last part of the final, and later learn to do the rouddout while progrssively extending the airbrakes to their maximum. Although this does not provide the lowest possible speed at touch down, this provides the highest possible decay in speed and this is the important thing as well for minimizing the length of the ground roll as for avoiding to bounce. We don't have Schweitzers which would defeat this strategy. The local equivalent in terms of national singularity would probably be the Bijave, which works this way. |
![]() "Steve Hopkins" k wrote in message \ When, as a UK pilot on holiday, flying in the USA a couple of years ago, the CFI demonstrated his preferred landing technique which involved progressively reducing airbrakes as one approached the ground. This gave rise to very prolonged 'hold-offs' and touchdown at the stall. Was this a local quirk? yes...and not a particularly good one either INHO. |
involved progressively reducing airbrakes as one approached the ground...
Sounds kinda flaky to me. I guess the key thing is what "progressively" means, and at what point during the approach the reduction in spoilers is started. Spoilers SHOULD be reduced in the last few seconds of the approach, as touching down in the proper landing attitude without spoilers gives the lowest touchdown speed -- especially important for unflapped ships and off- or rough-field landings. Mike Yankee (Address is munged to thwart spammers. To reply, delete everything after "com".) |
MikeYankee wrote:
involved progressively reducing airbrakes as one approached the ground... Sounds kinda flaky to me. I guess the key thing is what "progressively" means, and at what point during the approach the reduction in spoilers is started. Spoilers SHOULD be reduced in the last few seconds of the approach, as touching down in the proper landing attitude without spoilers gives the lowest touchdown speed -- especially important for unflapped ships and off- or rough-field landings. I think SHOULD is too strong a statement. Many gliders become very sensitive to pitch control with spoilers closed, and any value from a reduction in touchdown speed is likely to be negated by ballooning and subsequent hard touchdown. This is especially true of all the flapped gliders I've flown when landing with positive flap (the usual case); it's probably easier to do on an unflapped glider. If you can do it under the stress and uncertain conditions of field landing, I'm impressed, because I know I'm very unlikely to do so, based on thousands of landings on airports and dozens in fields. Another situation where it would be a poor choice is a short field where the need to stop as quickly as possible is important. Floating along is not a good idea when a fence is approaching! -- ----- change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
I don't think it's too strong, but perhaps too general. It depends somewhat on conditions. If it's gusty, keeping some spoiler on is wise because quickly cleaning up the wing as you lower the nose may be the best way to fly out of a wind shear; if your spoilers are already retracted and you're still 20 ft high a few knots above stall speed you may arrive precipitously. On the other hand, if you're coming in over an obstacle into a short field, a firm impact with spoilers is preferable to floating into the trees at the other end. On the third hand, if you're landing in a long field whose surface is unknown and possibly rough, you're better off making the glider alight at the lowest possible speed, which means no spoilers. I contend that in calm conditions, you should touch down (flapless gliders) with a clean wing and a slightly tail-low attitude. When I see people float and overshoot it's often because they have too much speed and too much spoiler on short final and roundout. Abruptly closing the spoilers in this situation is just like adding power in an airplane. Mike Yankee (Address is munged to thwart spammers. To reply, delete everything after "com".) |
At 19:00 08 February 2004, Bill Daniels wrote:
I prefer a fairly steep glide path to a flair with spoilers left where they were in the approach followed by a low-energy touchdown and a short rollout. Pretty much what I would expect to do in an off-field landing. Unless, of course, you're flying a 2-32 using full dive brakes on final. Holding this configuration through the flare, you will impact terra firma more abruptly than you thought possible and it may be weeks before you can walk upright again. This may, however, be preferable to running into an obstacle. Please to note proper spoiler/dive brake use, proper touch-down attitude and short or off-field landing techniques will vary with the aircraft, the situation and the available alternatives. In a preachy mood... Judy |
![]() "Judy Ruprecht" wrote in message ... At 19:00 08 February 2004, Bill Daniels wrote: I prefer a fairly steep glide path to a flair with spoilers left where they were in the approach followed by a low-energy touchdown and a short rollout. Pretty much what I would expect to do in an off-field landing. Unless, of course, you're flying a 2-32 using full dive brakes on final. Holding this configuration through the flare, you will impact terra firma more abruptly than you thought possible and it may be weeks before you can walk upright again. This may, however, be preferable to running into an obstacle. Please to note proper spoiler/dive brake use, proper touch-down attitude and short or off-field landing techniques will vary with the aircraft, the situation and the available alternatives. In a preachy mood... Judy It's OK, Judy. You made a good point. Bill Daniels |
Tamed by the Tailwheel | [email protected] | Piloting | 84 | January 18th 05 04:08 PM |
VW-1 C-121J landing with unlocked nose wheel | Mel Davidow LT USNR Ret | Military Aviation | 1 | January 19th 04 05:22 AM |
Off topic - Landing of a B-17 | Ghost | Home Built | 2 | October 28th 03 04:35 PM |
Power-out spot landing techniques? | Richard Thomas | Piloting | 50 | August 20th 03 01:27 AM |
