https://en.wikipedia.org/wiki/Caproni_Ca.60
The Caproni Ca.60 Transaereo, often referred to as the Noviplano (nine-wing) or Capronissimo, was the prototype of a large nine-wing flying boat intended to become a 100-passenger transatlantic airliner. It featured eight engines and three sets of triple wings. Only one example of this aircraft, designed by Italian aviation pioneer Gianni Caproni, was built by the Caproni company. It was tested on Lake Maggiore in 1921: its brief maiden flight took place on February 12 or March 2. Its second flight was March 4; shortly after takeoff, the aircraft crashed on the water surface and broke up upon impact. The Ca.60 was further damaged when the wreck was towed to shore and, in spite of Caproni's intention to rebuild the aircraft, the project was soon abandoned because of its excessive cost. The few surviving parts are on display at the Gianni Caproni Museum of Aeronautics and at the Volandia aviation museum in Italy. The Transaereo was a large flying boat, whose main hull, which contained the cabin, hung below three sets of wings each composed of three superimposed aerodynamic surfaces: one set was located fore of the hull, one aft and one in the center (a little lower than the other two). The wingspan of each of the nine wings was 30 m (98 ft 5 in), and the total wing area was 750.00 m² (8073 ft²); the fuselage was 23.45 m (77 ft) long and the whole structure, from the bottom of the hull to the top of the wings, was 9.15 m (30 ft) high. The empty weight was 14,000 kg (30,865 lb) and the maximum takeoff weight was 26,000 kg (57,320 lb). Each set of three wings was obtained by the direct reuse of the lifting surfaces of the triplane bomber Caproni Ca.4; after the end of the war several aircraft of this type were cannibalized in order to build the Transaereo. Role Experimental airliner National origin Italy Manufacturer Caproni Designer Gianni Caproni First flight February 12 or March 2, 1921 Status Destroyed on second flight Number built 1 The Transaereo was taken out of its hangar for the first time on January 20, 1921, and on that day it was extensively photographed. On January 21, the aircraft was scheduled to be put in the water for the first time, and a cameraman had been hired to shoot some sequences of the aircraft floating on the lake. Because of the low level of the lake and of some difficulties related to the slipway that connected the hangar with the surface of the lake, the flying boat could not reach the water. After receiving De Siebert's authorization, the slipway was lengthened on January 24, and then again on 28. Operations were carried on among problems and obstacles until February 6, when Caproni was informed that 30 wing ribs had broken and needed to be repaired before the beginning of test flights. He was infuriated, and kept his employees awake through the night to allow the tests to begin on February 7. The ribs were fixed, but then a starter was found broken, causing Caproni's frustration, so that the tests had to be postponed again. Always keeping on the water surface, the aircraft made some turns, then accelerated simulating a takeoff run, then made other maneuvers in front of Gianni Caproni and other important representatives of the Italian aviation in the 1920s: Giulio Macchi and Alessandro Tonini of Nieuport-Macchi, Raffaele Conflenti of SIAI. The tests were soon interrupted by the worsening of the weather conditions, but their outcome was positive. The aircraft had proved responsive to the controls, maneuverable and stable; it seemed to be too light towards the bow and at the end of the day some water was found to have leaked inside the fuselage, but Caproni was satisfied. More taxiing tests were successfully carried out on February 11. On February 12 or March 2, 1921, the bow of the aircraft loaded with 300 kg (660 lb) of ballast, the Transaereo reached the speed of 80 km/h (43 kn; 50 mph) and took off for the first time. During the brief flight it proved stable and maneuverable, in spite of a persisting tendency to climb. The second flight took place on March 4. Semprini (according to what he later recalled) accelerated the aircraft to 100 or 110 km/h (54–59 kn, 62–68 mph), pulling the yoke toward himself; suddenly the Transaereo took off and started climbing in a sharp nose-up attitude; the pilot reduced the throttle, but then the aircraft's tail started falling and the aircraft lost altitude, out of control. The tail soon hit the water and was rapidly followed by the nose of the aircraft, which slammed into the surface, breaking the fore part of the hull. The fore wing set collapsed in the water together with the nose of the aircraft, while the central and the aft wing sets, together with the tail of the aircraft, kept floating. The pilot and the flight engineers escaped the wreck unscathed. Specifications (Ca.60) General characteristics Crew: 8 Capacity: 100 passengers Length: 23.45 m (77 ft) Wingspan: 30.0 m (98 ft 5 in) Height: 9.15 m (30 ft) Wing area: 750.00 m² (8073 ft²) Empty weight: 14,000 kg (30,865 lb) Max. takeoff weight: 26,000 kg (57,320 lb) Powerplant: 8 × Liberty L-12 liquid-cooled V12 engines, 294 kW (400 hp) each Performance Cruise speed: 130 km/h (70 kn, 80 mph) Range: 660 km (360 nmi, 410 mi) * |
Caproni Stipa (Flying Barrel) video - 1933 Stipa-Caproni Aircraft-kB4-_OWz5qE_xvid.avi (01/51) | Bob (not my real pseudonym)[_2_] | Aviation Photos | 1 | May 22nd 17 06:17 PM |
Caproni Stipa (Flying Barrel) video - 1933 Stipa-Caproni Aircraft-kB4-_OWz5qE_xvid.avi (51/51) | Miloch | Aviation Photos | 0 | May 18th 17 03:06 PM |
Caproni Stipa (Flying Barrel) pics 2 [6/9] - Stipa-Caproni-6-730x427.jpg (1/1) | Miloch | Aviation Photos | 0 | May 18th 17 02:58 PM |
Caproni Stipa (Flying Barrel) pics 2 [1/9] - Stipa-Caproni Inventions for March.png (1/1) | Miloch | Aviation Photos | 0 | May 18th 17 02:58 PM |
