What color devices are pilots using for Top Hat/XCSoar? I'm running Top Hat on a Kobo Glo (large eink gray scale--great readability) and a Dell Streak 5 (smaller screen, color, acceptable readability). If the Dell were a little brighter and larger, it would be perfect.
Options seem to range from other mobile phones all the way up to the OpenVario project (at least for XCSoar). What works for you? Chip Bearden "JB" |
On Friday, June 23, 2017 at 1:03:45 PM UTC-6, wrote:
What color devices are pilots using for Top Hat/XCSoar? I'm running Top Hat on a Kobo Glo (large eink gray scale--great readability) and a Dell Streak 5 (smaller screen, color, acceptable readability). If the Dell were a little brighter and larger, it would be perfect. Options seem to range from other mobile phones all the way up to the OpenVario project (at least for XCSoar). What works for you? Chip Bearden "JB" The 7" Streak works well - if you can find one. About the same brightness as the 5", but easier to read due to the size. I usually use the smaller Streak. These days I think color really is not much of an advantage. The real info is in the info boxes. Mike |
Though I have a ClearNav II in my Stemme, I also have a Dell Streak 5
running XCSoar on the right side of the cockpit. I find that each platform delivers information that the other does not or delivers similar information in a more understandable way. Even when I fly solo, I run the Streak for the added information. Note that I have the terrain display turned off as it makes for a much clearer display, not to mention that I have a high definition canopy displaying the terrain. On 6/23/2017 1:20 PM, Mike C wrote: On Friday, June 23, 2017 at 1:03:45 PM UTC-6, wrote: What color devices are pilots using for Top Hat/XCSoar? I'm running Top Hat on a Kobo Glo (large eink gray scale--great readability) and a Dell Streak 5 (smaller screen, color, acceptable readability). If the Dell were a little brighter and larger, it would be perfect. Options seem to range from other mobile phones all the way up to the OpenVario project (at least for XCSoar). What works for you? Chip Bearden "JB" The 7" Streak works well - if you can find one. About the same brightness as the 5", but easier to read due to the size. I usually use the smaller Streak. These days I think color really is not much of an advantage. The real info is in the info boxes. Mike -- Dan, 5J |
On Fri, 23 Jun 2017 12:03:43 -0700, chip.bearden wrote:
What color devices are pilots using for Top Hat/XCSoar? I'm running Top Hat on a Kobo Glo (large eink gray scale--great readability) and a Dell Streak 5 (smaller screen, color, acceptable readability). If the Dell were a little brighter and larger, it would be perfect. A Medion S.3747. It has a transreflective screen which is more readable in bright sun than any of the purely backlit devices. It also has an 800 mAH removable battery. It is a smaller screen - 3.5" - but that is a benefit if, like me, you fly a glider with the panel inside under the nose fairing (Std Libelle in my case) because this prevents anything from hanging out over the edge of the panel. I'm actually running LK8000 rather than XCSoar, but that doesn't affect this discussion. IMO the S.3747 is worth grabbing if you can find one. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
I use a Nexus 2013 7 inch. Its best with polarized sunglasses. Otherwise there is a reflection. I have also used a moto g3 which also worked great.
On Friday, June 23, 2017 at 9:50:40 PM UTC-4, wrote:
I use a Nexus 2013 7 inch. Its best with polarized sunglasses. Otherwise there is a reflection. I have also used a moto g3 which also worked great. I use XC Soar on an Oudie Lite; before, on a Streak 5 inch. I had connected the Streak by IOIO board, I now connect the Oudie to a CNv with the Goddard cable. I prefer the Oudie for visibility. |
On Friday, June 23, 2017 at 3:03:45 PM UTC-4, wrote:
What color devices are pilots using for Top Hat/XCSoar? I'm running Top Hat on a Kobo Glo (large eink gray scale--great readability) and a Dell Streak 5 (smaller screen, color, acceptable readability). If the Dell were a little brighter and larger, it would be perfect. Options seem to range from other mobile phones all the way up to the OpenVario project (at least for XCSoar). What works for you? Chip Bearden "JB" Samsung Galaxy Note 4. Daylight readable with polarized sunglasses Internal GPS and barograph for backup system use. Large very high resolution screen many spares available Recent android OS not obsolete windows CE type stuff - will be supported for several more years. Wifi Bluetooth I used it 2 years with XCsoar and it worked great. |
I'm currently trying an OpenVario with XCSoar. Open source all around. It's a nice system. Check out details at openvario.org. I think TopHat has a Linux version that will work.
On Friday, June 23, 2017 at 9:04:47 PM UTC-7, SoaringXCellence wrote:
I'm currently trying an OpenVario with XCSoar. Open source all around. It's a nice system. Check out details at openvario.org. I think TopHat has a Linux version that will work. A couple of friends are using OpenVario. Heat can be a problem. Jim |
Jim Didn't realize there was much OpenVario action over here. Haven't heard anything about heat problems. Are those related to the display? If so, do you know which one(s)? Yes, Top Hat Linux is available but I haven't heard of anyone who's actually done it yet. Working in the technology field, the most dangerous words are "it *should* work". Polarized glasses don't work well with the screen of my Portable PowerFLARM.. I'm mostly OK with my Dell Streak 5 except for size so any of the phone devices wouldn't be much of an improvement. Chip Bearden "JB" |
| Pacific War in Color, pt 9 - P 61 in color.jpg (1/1) | Mitchell Holman[_9_] | Aviation Photos | 0 | April 5th 17 02:18 PM |
| Pacific War in Color, pt 8 - P 39-color.jpg (1/1) | Mitchell Holman[_9_] | Aviation Photos | 1 | April 4th 17 09:41 PM |
| Pacific War in Color, pt 8 - P 39s-color.jpg (1/1) | Mitchell Holman[_9_] | Aviation Photos | 0 | April 4th 17 02:31 PM |
| XCSOAR | Travis Beach[_2_] | Soaring | 3 | May 24th 08 04:36 PM |
| Flying platforms/airgeeps | David L. Burkhead | Home Built | 3 | January 19th 05 07:33 AM |
