Oudie IGC spurious RF emissions
Old June 25th 17, 04:37 PM posted to rec.aviation.soaring
Evan Dosik
Default Oudie IGC spurious RF emissions
My Oudie IGC will too often break the squelch with a hideous noise on both my panel radio (an old Dittel) and also most any handheld that comes within about 12" of the Oudie.
Anyone else seeing this issue?
Thanks,
Evan
6E
Old June 25th 17, 04:39 PM posted to rec.aviation.soaring
Echo
Actually...my oudie2 is connected to my 302...and as of yesterday at powerup my 302 makes an awful loud noise with no other issues. Related?
Jordan
Old June 25th 17, 04:50 PM posted to rec.aviation.soaring
Evan Dosik
Jordan
Possibly? Kind of hard to describe my noise. Sort of a loud, constant "honking" or droning. Mixed mid frequency, not a high pitched squeal. At first I thought a local power plane had a stuck mic.
Old June 25th 17, 04:45 PM posted to rec.aviation.soaring
Karl Kunz[_2_]
Do you have your Oudie connected to a USB charger? Some USB charging units are notorious for generating RF interference.
Old June 25th 17, 04:51 PM posted to rec.aviation.soaring
Evan Dosik
No Karl, I'm on the internal battery.
Thanks
Old June 25th 17, 04:58 PM posted to rec.aviation.soaring
Scott Williams
Thanks,
Evan
6E
I've been flying with a Oudie IGC, SV-7, Dittle/Funke Fsg-2T And have not had any rf interference. I'm using an air data cable from Cumulus, and running on the Oudie internal battery.
good luck,
Scott.
Aircraft Emissions Survey Michael Westbrook Piloting 0 February 18th 12 03:22 AM
Oudie and 302 Stephen[_3_] Soaring 9 November 2nd 11 05:07 AM
Oudie Steve Hunt Soaring 2 July 8th 11 12:19 AM
oudie Steve Hunt[_2_] Soaring 0 July 7th 11 08:58 AM
spurious ELT signal F.L. Whiteley Soaring 4 October 20th 04 03:01 PM
