Winpilot/SeeYouMob with IPAQ 4150
Old February 23rd 04, 11:47 AM
Nick Gilbert
Default Winpilot/SeeYouMob with IPAQ 4150
Hi There,
Does anyone have any knowledge on the suitability of an IPAQ 4150/4155 for
use with Winpilot/SeeYouMob? I have read some conflicting advice on whether
or not the 4150 is able to communicate serial data (I have a Cambridge
GPS-Nav).
Does anyone know if this will be possible or if bluetooth is the only way
with this model?
Thanks,
Nick
Sydney, Australia
Old February 23rd 04, 09:34 PM
Andrej Kolar
Nick, iPaq 4150/4155 does not have a COM port built in. It will only work
with a Bluetooth GPS receiver, but not with what we normally carry in our
cockpits.
Andrej Kolar
"Nick Gilbert" wrote in message
Hi There,
whether
GPS-Nav).
with this model?
Thanks,
Nick
Sydney, Australia
Old February 24th 04, 02:49 AM
Jim Kelly
If you are happy with the smaller display, then consider the H2210,
otherwise you need the larger H5150 or H5550 (sometimes the 0
becomes a 5, same unit).
Pity, the H4150 is a lovely size and weight, but without "serial"
support you cannot link to serial devices like varios and loggers.
Bluetooth works well in a glider but we'd be better off without it
as a simple "serial" cable can replace the two Bluetooth
transmitters, making life for the glider battery less miserable.
Since we need a power cable anyway, Bluetooth offers nil advantage
for gliding.
Cheers,
Jim Kelly.
"Andrej Kolar" wrote in message
only work
in our
| cockpits.
| Andrej Kolar
| Hi There,
4150/4155 for
on
| whether
Cambridge
| GPS-Nav).
only way
| with this model?
| Thanks,
| Nick
| Sydney, Australia
Old February 24th 04, 05:55 AM
tango4
"Jim Kelly" wrote in message
u...
Bluetooth offers nil advantage for gliding.
Except that you can use the newer and lower cost PDA's. Oh, and you only
need one BT converter and once thats in your ship you can transfer the
logger files to a BT laptop without any cables or wiring in the panel and
without breaking the OO's seals.
Ian
Old February 24th 04, 10:40 AM
Jim Kelly
Please elaborate on how to use:
* WinPilot on a non-serial iPaq with a Volkslogger
* WinPilot on a non-serial iPaq with a Cambridge 302
Cheers,
Jim Kelly
"tango4" wrote in message
message
| u...
you only
panel and
| Ian
Old February 24th 04, 06:21 PM
tango4
Hi Jim
You can use a serial to bluetooth converter designed for embedded
applications. simply connecting it to the logger and establishing a BT
connection to the iPaq will solve the problem. Similarly with a 302 the
adaptor goes where the iPaq would have been. You just need to find the right
BT adaptor, pre-program it so that it boots automagically and establishes a
connection to the iPaq.
I hope to put up some pics and process shortly on a website.
Ian
u...
Cheers,
Jim Kelly
message
| u...
you only
panel and
| Ian
Old February 24th 04, 06:11 AM
Nick Gilbert
Andrej,
Thankyou for your reply. Have you tried it? Where does this information come
from?
Regards,
Nick.
cockpits.
Andrej Kolar
Hi There,
for
whether
GPS-Nav).
way
with this model?
Thanks,
Nick
Sydney, Australia
Old February 24th 04, 08:17 AM
Andrej Kolar
Nick, I have to add to the confusion and cancel what I said.
A friend of mine tested it this evening. He says:
Have tested that. It works! The data is read from Garmin eTrex to 4150.
So - It does work. Good news! Lots of pages with links to PDA hardware need
updating.
Andrej Kolar
Andrej,
come
from?
Regards,
Nick.
work
our
cockpits.
Andrej Kolar
Hi There,
for
whether
GPS-Nav).
way
with this model?
Thanks,
Nick
Sydney, Australia
Old February 24th 04, 09:26 AM
Nick Gilbert
Now you see why I need clarification on this point!! I have seen both sides
of the argument!
Nick.
need
updating.
Andrej Kolar
Andrej,
come
from?
Regards,
Nick.
work
our
cockpits.
Andrej Kolar
Hi There,
4150/4155
for
whether
Cambridge
GPS-Nav).
only
way
with this model?
Thanks,
Nick
Sydney, Australia
Old February 24th 04, 10:52 AM
Jim Kelly
Here is an HP FAQ on the H4150 (may need pasting together):
http://h10010.www1.hp.com/wpa/vat/ge...f43-349042#usb
quote from it:
USB desktop cradle/charger:
Is the iPAQ Pocket PC h4100/h4300 models serial supported?
No. There is no serial support on the h4100/h4300 series.
Does the cradle for the iPAQ Pocket PC h4100/h4300 models support
USB?
Yes, the cradle for the iPAQ Pocket PC h4100 and h4300 is USB
only.
Does this cradle work with iPAQ Pocket PCs other than h4100/h4300
models?
No, this cradle is designed specifically to fit the h4100/h4300
models slim design.
both sides
| of the argument!
| Nick.
to 4150.
hardware
| need
| updating.
| Andrej Kolar
| Andrej,
information
| come
| from?
| Regards,
| Nick.
will only
| work
carry in
| our
| cockpits.
| Andrej Kolar
| Hi There,
IPAQ
| 4150/4155
| for
advice on
| whether
a
| Cambridge
| GPS-Nav).
is the
| only
| way
| with this model?
| Thanks,
| Nick
| Sydney, Australia
IPAQ Wiring - which pins are used Michael Soaring 9 March 15th 04 09:48 PM
iPaq wiring, cradles and mounts for gliders - Ideas?? Jim Kelly Soaring 12 December 5th 03 12:45 AM
Ipaq - GPS_Log Help needed (Long) Steve B Soaring 1 September 27th 03 07:00 AM
iPAQ h2210/h2215 Review Paul Remde Soaring 0 September 3rd 03 04:45 AM
iPaq screen viewability Raphael Warshaw Soaring 7 July 27th 03 07:02 PM
