https://en.wikipedia.org/wiki/Percival_Mew_Gull
about the video: Long shot of Alex Henshaw's aeroplane Percival Mew Gull landing at Gravesend's airfield in Kent after his record breaking flight to South Africa and back. Several shots of the aviation pioneer being congratulated by the mayor. Long shots of crowds giving him three cheers before he is carried away on the shoulders of a man. The Percival Mew Gull was a British racing aircraft of the 1930s. It was a small, single-engine, single-seat, low-wing monoplane of wooden construction, normally powered by a six-cylinder de Havilland Gipsy Six piston engine. During its racing career it set many records and was considered a significant, efficient design, one that eventually reached a top speed of 265 mph (425 km/h) on a modest 205 hp (153 kW) in its final 1939 form. A modern-day observer has characterised the Mew Gull as "the Holy Grail of British air racing". During the second half of the 1930s, Mew Gulls were dominant in air-racing in the UK and consistently recorded the fastest times until the outbreak of war stopped all civilian flying in late 1939. With the Percival Gull already making a name for itself as a racer, over several months in 1933–1934, Capt. Edgar W. Percival designed and built a single-seat racer derivative initially named the E1 'Mew Gull'. This was developed into the E2, E2H and the E3H variants between 1934 and 1938. The sometimes-used designation "P6" is incorrect; this retrospective tag was created after Percival left the company and long after the Mew Gulls were built, thus no Mew Gulls were ever built as "P6s". With the exception of the sole E3H, G-AFAA – which was built after the company moved to Luton, all of the Mew gulls were built in the small factory at Gravesend. It should be noted that the E3H, whilst very strongly visually resembling the E2H, was in truth a totally new and different machine, with each element differing from its predecessor in some way. It was most certainly not a 'clipped-wing' version of the E2H as it has sometimes been described. Structurally, there was very little commonality of parts between the Gulls IV/ VI/ Vega Gull and the Mew Gull, other than a few minor components. All of the Gulls, however, did use a similar generic structure. Proprietary equipment such as engines, airscrews, spinners, instruments, undercarriage legs, wheels and tyres were generally common to all series. The Mew Gulls (apart from the E1 in its initial configuration) used a fixed, conventional oleomatic main undercarriage and a fully castoring tailskid. Small manually operated, split trailing-edge wing flaps were incorporated into the mainplanes, but were "...singularly ineffective even when fully extended". Role Racing aircraft Manufacturer Percival Aircraft Company Designer Edgar Percival First flight March 1934 Primary user Civilian racer Produced 1934–1938 Number built 6 Developed from Percival Gull In September 1936 G-AEKL, having previously been Edgar Percival's private mount, was re-engined and modified to enter in the Schlesinger Race. The Schlesinger African Air Race was a race from England to South Africa (6,154 miles), but G-AEKL was withdrawn ten days before the Schlesinger following a fatal taxiing accident at Liverpool Speke Airport. Two other E2H Mew Gulls were entered, both of which had been built at the same time to the same specification as the modified KL. Both failed to finish the race to South Africa. In the 1937 King's Cup Race, the rebuilt and re-painted G-AEKL was 1st with Charles Gardner at the controls in his house-colours of dark blue with pale-blue lettering and trim (See Flight of the Mew Gull, p91.). He averaged 234 mph over the 1,442-mile course. Percival flew his latest E3H "Super"-Mew G-AFAA, the sixth and last Mew Gull built, to a third-place finish and still another E2H, G-AEXF was raced by Alex Henshaw. The 1938 King's Cup Race was a 1,012 mile event and this time, Alex Henshaw's much modified E2H G-AEXF came in 1st at 236 mph and Giles Guthrie in his red "standard" E2H G-AEKL placed 2nd. Edgar Percival flew a third Mew Gull, the E3H (G-AFAA) and finished 6th. Percival might easily have won, but as well as being made scratch-man by the Handicappers, he left the fine-tuning of his airscrew pitches until just before the race and his ground-crew were still tinkering with them as Alex Henshaw took off. At this time the Bracket-Type airscrew simply did not have the pitch-range to cope with the exceptionally wide speed range of the E3H (59–265 mph). An optimisation for either cruise or takeoff and climb would inevitably compromise the other. Alex Henshaw attempted to take the England – Cape Town Record in 1939, taking off on 5 February 1939 from Gravesend Airport, landing at Wingfield Aerodrome at the Cape the next day, covering the 6,377 miles course in 39 hours and 25 minutes, averaging 209.44 mph while in the air. The return trip was just 11 minutes longer. It is interesting to note that during all of Alex Henshaw's adventures in this aircraft it was never damaged. Specifications (Type E.1) General characteristics Crew: 1 Length: 18 ft 3 in (5.56 m) Wingspan: 24 ft (7.32 m) Height: 6 ft 10 in (2.08 m) Wing area: 88 ft² (8.2 m²) Empty weight: 996 lb (453 kg) Loaded weight: 1,460 lb (664 kg) Powerplant: 1 × Napier Javelin IA inline, 165 hp (123 kW) Performance Maximum speed: 195 mph (170 knots, 314 km/h) Cruise speed: 175 mph (152 knots, 282 km/h) Range: 550 mi (478 nm, 885 km) * |
Looking for the 3 gull logo | Pat Russell[_2_] | Soaring | 3 | November 27th 12 02:12 AM |
Slingsby Gull in America | glider[_2_] | Soaring | 0 | October 8th 09 06:47 PM |
Cramped Cockpits, pt 4 - mew gull.jpg (1/1) | Mitchell Holman[_2_] | Aviation Photos | 0 | January 23rd 08 04:03 AM |
Stinson Gull Wing | acroman | Aviation Photos | 0 | August 19th 07 04:14 PM |
