Does anyone know how iGlide saves tasks? I put in a task, sometime it saves it and sometimes not. Or it's I there for 3 weeks with the others and then they all disappear. Has anyone else seen this? It never loses my log files, but the tasks (routes in iGlide) seem to be stored in some non permanent location.
On Tuesday, July 25, 2017 at 3:49:00 PM UTC-7, wrote:
Does anyone know how iGlide saves tasks? I put in a task, sometime it saves it and sometimes not. Or it's I there for 3 weeks with the others and then they all disappear. Has anyone else seen this? It never loses my log files, but the tasks (routes in iGlide) seem to be stored in some non permanent location. Never had them disappear. Occasionally after an update the maps will disappear, and this seems to depend on the iPhone model (happens more often on my 5s than on my 6+). The routes are stored in a file called Routes.aip. When you back the phone up in iTunes, navigate to the app data and save it (along with the config.xml, navboxconfig.xml, and styles.xml. These are all text files in xml pseudocode which is pretty readable. There are some very interesting formatting features available by editing the config and styles files, not available in the iPhone UI. Save the old versions if you muck with them so you can get back. You can always throw the file out, next time iGlide is started it will create default ones. To use an edited version, drag it to the same app data area and overwrite the existing, then sync, then restart the app. I'm hoping this gets easier in iOS 11, which will have the equivalent of a Finder app. |
Easy peasy. PM me for more detailed description.
1) I believe you must have iGlide Pro although I am not certain. 2) You must rename the task/route (saves automatically in route list). See top of photo in "edit" mode https://www.icloud.com/sharedalbum/#B13J5HumnGaZKyV Sean |
I've done that. The issue is that they disappear. Sometimes after a day, or a week, or a month. My saved routes are there one day, and gone the next. They last long enough to fly the route, but I can't seem to store any routes for an extended period of time. It's very strange. And annoying because other than this little feature iGlide is really good.
I tried the universal software fix. Delete and reinstall. That seems to have fixed it. I hope.
Interesting. Do you auto-update your iOS firmware and iGlide app via your iOS settings? Was iGlide possibly due for an update and/or on an older version and not updated to the latest version? I assume yes but felt it was worth asking. Some I know in rh Gliding world, for example, never updates their iOS. Many likely ignore the updates as well this can be a problem.
My iGlide has actually been experiencing a slight pause in response. Meaning it took a second for the app to respond to an input, in particular the addition of a TP or a change to a parameter such as radius. This was annoying me and I also did the uninstall reinstall with no improvement (it is rare that uninstall/reinstalls are the solution). The reason I ask is that I just updated my iOS firmware this morning to the latest version, 10.3.3. This immediately solved the hesitation and the iGlide app is responding perfectly. What model iPhone and what version of your iOS firmware are you running? Did you recently update? With complex apps such as iGlide or ForeFlight it is fairly import to keep them up to date. This kind of "bug tolerance" is part of life and happens with most complex apps. Even my Forefligt app (huge development team with huge customer sat focus) has been buggy at times. Keep in mind that the iGlide team is very responsive to these issues as well and an email to them is usually responded to in hours. I'm posting this more for those who follow us into the "iGlide experience." I still believe iGlide is the best mobile soaring navigation app. I use it all the time as a backup in contests and as primary in all other glider flying and absolutely love it. I'm glad to hear your issue is solved. It is still unclear what the problem was as the recent iOS 10.3.3 update might have been the issue. It might be worth an email to the iGlide developers (via App Store) so they can do some testing and have the issue on record. Best, Sean |
Saving See You Tasks and Flights | [email protected] | Soaring | 3 | November 28th 08 06:12 PM |
EARN CASH WHILE SAVING GAS | Gas Savers | Home Built | 0 | June 29th 06 06:12 PM |
Weight saving exercise. | Fortunat1 | Home Built | 43 | March 29th 05 01:51 PM |
saving an aircraft in the air | Cub Driver | Military Aviation | 9 | April 12th 04 10:34 AM |
