USA 18 Meter Sailplane National Championships Day 1 8/01/2017.
Old August 2nd 17, 02:48 AM posted to rec.aviation.soaring
Tom Kelley #711
Default USA 18 Meter Sailplane National Championships Day 1 8/01/2017.
Pilot's meeting started 10 am. Mark, our CD, and Kerry, our CM, simply know how to put on a show. Brief, to the point and excellent side shows for weather, griding, and taxiway/ tow out use, etc. The weather, well some of the models are good, others need to be trashed. A lot of conflicting information. But the task called today fit the weather pattern perfectly. Well done Mr. CD! Just a few blue holes, no biggie. Start opened at 1345. Scores and start times are up on the SSA website. http://www.ssa.org/Contests?cid=2354&display=results
When you see the score sheet, click the blue link at the bottom and the task will appear! Around 285 miles as it was a AT. But we ran to Winn which is west, then sorta south to Callaghan then northish to Big Wells, then tip toed along eastish to Los Angeles then had a good street to run home on. I think I saw the top 23 pilots with over 900 point, Bases rose from close to 6,000 msl at the start to over 8,000 msl middle of task area. Lift was good with solid 4-6 kt climbs. Had a few closer to 8 kts and the streeting helped running home.
So all are back, safe and sound. Not sure what's up with the weather over the next few days,
Old August 2nd 17, 03:46 AM posted to rec.aviation.soaring
Sean Fidler
Nice flying Tom!
Old August 2nd 17, 01:25 PM posted to rec.aviation.soaring
1026 points?
I didn't know more than 1,000 points was possible. Was the scorer bribed with a dozen Krispy Kremes and bottomless coffee?
Ray
Old August 2nd 17, 01:44 PM posted to rec.aviation.soaring
Ron Gleason
On Wednesday, 2 August 2017 06:25:11 UTC-6, wrote:
1026 points?
Ray
From the SSA 2017 US Nationals Competition Rule Book
11.8 Scoring Guest Pilots
11.8.1 Terms such as "Best Speed" and "Best Distance" refer to the performance of regular entrants only; guest pilots achieving a
better daily result shall receive a proportionally extrapolated score.
11.8.2 On a day when the only finishers are guest pilots, the highest speed shall be assigned a score of 600 points.
11.8.3 At the option of contest organizers, guest pilots shall be ranked and listed either separately from regular entrants at the
bottom of official score sheets, or along with regular entrants.
For the day Bruce, flying as a guest as defined in section 5.8 of the rulebook, had a speed of 88.13 and fastest contestant had a speed of 85.92. So 88.13 / 85.92 = 1025.72 or 1026 for the day.
Clear as mud?
Old August 2nd 17, 02:23 PM posted to rec.aviation.soaring
Back in the day ( 1970's ) a French pilot (Aundre Demestry) flying as a guest in the Minden US Nationals, was the only finisher! Nobody knew what to do, finally decided he should get a proportionally higher score.............believe that was something like 2300 points, with the best US land out getting 1000 points. Aundre was an alpine pilot and flew deep into the Sierras to log his winning flight. Alas, Aundre didn't know much about racing and dwindled his massive score down to less than the highest US contersent by the end of the contest.
JJ
Old August 2nd 17, 04:09 PM posted to rec.aviation.soaring
Ron Gleason
1026 points?
Ray
Appears they have rescored everyone and now there are no guests pilots so Bruce now has 1000 points
Old August 2nd 17, 02:01 PM posted to rec.aviation.soaring
John Godfrey (QT)[_2_]
Tom - so you and Peter don't need no stinking long wings?
Interesting
Old August 2nd 17, 02:25 PM posted to rec.aviation.soaring
Tom Kelley #711
Interesting
Ya, comes from the registration. When I filled it out I had done the Seniors earlier as a ASG 29/15 meter, forgot to make the change on the SSA website to 18 Meter when I registered for the 18 Meters. 2T is flying as a 18 Meter.
No toy gliders here!
Best. #711.
Old August 2nd 17, 02:37 PM posted to rec.aviation.soaring
John Seaborn (A8)
Hey I resemble that comment... A8
Best. #711.
Old August 2nd 17, 09:22 PM posted to rec.aviation.soaring
Tim Taylor
Best. #711.
To paraphrase Rick Walters and Pat Philbrick: "We don't need no stinkin wingtip extensions". 18M gliding is the compensator class ;-).
2017 18 Meter Nationals on Facebook Live Sean Franke Soaring 17 August 10th 17 03:26 PM
USA 18 Meter Sailplane Nationals 2nd practice day 7/31/2017 Tom Kelley #711 Soaring 0 July 31st 17 07:14 PM
13.5 Meter World Championships Tony[_5_] Soaring 55 August 18th 15 11:23 AM
Day 11 of the South African National Gliding Championships stephen_p_thomas Soaring 2 December 23rd 11 06:42 AM
South African National Championships 2008-9 [email protected] Soaring 0 December 26th 08 11:43 AM
