Winch Physics
Old March 20th 04, 04:47 PM
Bob Johnson
Default Winch Physics
This has been covered in these pages before, but it may be timely to
post it again in view of the coming fuel price squeeze and the increased
interest in winching.
This Excel spreadsheet explains mathematically why a winch system
comprised of lighter linear (rope) and rotational elements will
significantly out-accelerate a more-massively built winch. Read petrol
powered vs. Diesel powered.
The Diesel, despite its other admitted advantages (or perhaps because of
them) will take longer to "wind up". The diesel engine is more massive
than a petrol engine in the crankshaft and flywheel, and in all other
moving parts. I do not know the exact masses of the two types of prime
movers. Perhaps someone out there can contribute this information. The
dry weights of the two power plants might be sufficient information.
This longer "wind up" period results in fewer "G's" being applied to the
sailplane being launched during the acceleration from rest to flying
speed and the subsequent start of the pull-up and climb.
We find with our 454 c.i. petrol engine-powered and Plasma rope-equipped
winch that our Blanik L-13 with two souls on board (1100 lb-mass) will
be flying before we can get the throttle fully advanced. We can easily
break a 1000-lb weak link during acceleration, but can't do so with a
1360-lb "blue" link.
Quicker than this I do not know how you could go.
The numbers add up to close to 1 "G" for the heavy two-place. Since
these maths are on a spreadsheet, all items comprising the entire system
can be changed to fit your particular situation. And all units have been
worked out on both the "English" and metric systems.
My spreadsheet had nothing to do with Craig Freeman's excellent winch
design for the Permian Soaring Asscociation. Rather, I did the
spreadsheet to find out just why it was so excellent.
http://www.permiansoaring.us/ (See "Special Projects")
The Excel spreadsheet is available as an email attachment. Let me know
if you would like me to send you one.
Cheers,
Bob Johnson Midland, Texas
Old March 20th 04, 05:40 PM
Bill Daniels
"Bob Johnson" wrote in message
Cheers,
I can attest to Bob Johnson's statement that the Permian Soaring Association
winch is a very energetic machine. I took a launch in their L-13 last
November with Bob driving the winch and Craig Freeman coaching me from the
back seat. Bob's spreadsheets and that neck snapping launch go a long way
to convince me that the ubiquitous Chevy 454 is a very good winch engine.
In their case, the 454 is a very appropriate engine.
I still am holding out for a diesel though. Some of the older diesels were
slow to spool up but the newer electronically-controlled, turbocharged,
common-rail diesels are just as snappy as spark ignition engines according
to the operators I have spoken with. The low cost of operation, low
maintenance and massive low-end torque of diesels are real plusses.
If you plan to build a winch for any glider that might show up for a launch,
you have to consider gliders like a ASH 25 at 2200 pounds gross. My single
seat Nimbus could be over 1400 pounds with water ballast. If you add to
that the summer 15,000 foot + density altitudes of many of the very
attractive winch runways in the western USA, the power requirements go way
up.
Someone correctly pointed out that turbocharged diesels will maintain their
power to very high altitudes. However, even with sea level power, at zero
wind and high density altitude, the glider will have to be accelerated to a
far higher groundspeed to reach liftoff airspeed. It's that high cable
speed just after liftoff times the 1G cable tension that adds up to the big
HP demand.
From a practical and perhaps simplistic view, excess horsepower is no
problem since you don't have to use all that is available. Insufficient HP
is a problem you just can't get around.
Bill Daniels
Old March 21st 04, 01:20 AM
Andreas Maurer
On Sat, 20 Mar 2004 10:47:47 -0600, Bob Johnson
I have no idea what Diesel winches you have seen so far, but it's very
easy to break the weak link during the initial acceleration with ours.
280 hp turbo Diesel and 3.500 ft of good-old fashioned steel cable.
Wind drivers in my club are instructed not to apply full power
immediately since the acceleration is so quick that it WILL break the
weak link.
The weak link I'm talking about is the 2.000 lbs (the strongest that
is available) onr for our DG-505.
Bye
Andreas
Old March 25th 04, 02:53 AM
Bob Johnson
Hi Andreas and Bill --
You're right, a 2000-lb weak link and a turbo for high altitude launches
can make all the difference in the world.
I figure Andreas' DG 505 at 615 kg gross and using all of the strength
of a 8929 N (2000-lb) weak link should get airborne (65 km/h or 35 kt)
in about 1.5 sec and take 125 kW (165 hp) out of the engine in the
process.
That's ripping the nose ring out of the bull's nose!
Cheers and all the best,
BJ
weak link.
Bye
Andreas
Old March 25th 04, 03:40 AM
Bill Daniels
Bob, let me try a different tack and look at the instantaneous power demand
at the moment of highest wire speed.
Andreas will be airborne at 65 km/h but won't really begin his climb until
over 102 km/h. At 100 km/h he is still accelerating at 10 meters per second
per second with a line pull of 615 kg. At that instant, he is demanding 169
kW or 227 HP at the glider. Since, as you pointed out, the winch engine is
also accelerating the drum and cable as well as overcoming cable friction
with the runway the real power demand at the engine is much higher.
If the glider must be accelerated to a higher ground speed because of
density altitude, the power demand goes higher still. At a 10,000 foot
density altitude he will need to go 20% faster before beginning the climb
and require 20% more power.
It's difficult to forecast the worst case power demand so I've always
advocated a large power margin to insure the power demand can always be met.
Bill Daniels
process.
BJ
of
weak link.
Bye
Andreas
Old March 25th 04, 04:38 AM
Bob Johnson
Hi Bill --
That's right, I'm just dealing with the initial problem of accelerating
the ship off the ground. The dynamics of the climb I'm leaving to others
smarter than me.
If your experience, of which I know you have in abundance, dictates
ADDING power when the ship begins its climb, then so be it. The big
block in the PSA winch has to be backed off from 3800 rpm to 3000 rpm in
the climb when launching our L-13, even in a low-wind situation as
prevailed last Saturday. I believe Craig is pulling back just right, as
he climbs at 55 kt.
As a crazy analogy, look at the Super Hornet. With engines spooled up
and in full afterburner, it takes a tremendous shove from the steam
catapault to get the ship in the air. Once in the air it immediately
climbs out like a banshee.
Thus my gut feeling that it takes more power to accelerate to flying
speed than it does to climb.
What am I missing here?
BJ
Bill Daniels
process.
BJ
of
weak link.
Bye
Andreas
Old March 25th 04, 02:35 PM
Bill Daniels
The craziness is in the horsepower formula. The Super Hornet's engines at
full thrust on the carrier deck produce no horsepower at all - just thrust.
Once it starts to move, the speed term in the HP formula kicks in and the HP
output soars. A bit of trivia, at about 325 knots, one pound of thrust
equals one HP which means that at 325 knots the Super Hornet's engines with
44,000 pounds of combined thrust are producing 44,000 HP vs. 0 HP one second
before the cat shot.
Using units I am more familiar with, 1 HP= 550 foot pound seconds. Or in
the case of a winch launch, cable tension in pounds times cable speed in
feet per second divided by 550. Because of the FPS term, the HP demand
peaks at the maximum cable speed just as the glider arcs up into the climb.
Unfortunately, without an energy storage system, the winch engine has to be
sized to meet peak demand even if that demand lasts only a second or two.
Bill Daniels
Hi Bill --
smarter than me.
he climbs at 55 kt.
BJ
demand
until
second
169
engine is
friction
climb
met.
Bill Daniels
launches
process.
BJ
because
of
massive
other
prime
The
information.
to
flying
very
ours.
weak link.
Bye
Andreas
Old March 25th 04, 01:46 PM
Andreas Maurer
On Wed, 24 Mar 2004 20:40:02 -0700, "Bill Daniels"
I'm offering German Daimler-Benz 280 hp...
Typical acceleration is about 3 seconds till liftoff (which happens
around 80 kp/h I'd estimate since the tail wheel prohibits the AoA of
the wing, and once off the ground the speed is immediately in the
green range. Precise speeds are hard to tell because due to the quick
acceleration the airspeed indicator is lagging behind.
Our winch operation typically looks like this:
The thrust lever is moved smoothly withing three seconds to a desired
engine RPM (which depends upon the wind condition and is typically
between 2.600 and 2.800 RPM for a DG505 or ASK-21).
Advancing the throttle quicker greatly enhances the risk of killing
the wek link during initial acceleration.
Shortly after the liftoff of the glider the acceleration is already
done (and the glider at a safe speed of 90-110 kp/h) and the glider
immediately starts its climb, reaching full climb angle at about 150
to 200 ft.
We sometimes even fly with pretty strong tailwinds of up to 20 kp/h
tailwind component (which should give a good comparation to the TAS
effects on high-elevation airfields). Launch height and ground run
distance are significantly reduced of course, but reaching a safe
speed for the glider is never a problem.
Launching with a Dynema cable (PU) on the winch of the other club on
our airfield didn't show much difference concerning acceleration and
tow heights (the Dynema cable is offers less than 10 percent better
launch height).
The advantages of using a "plastic" cable are rather in the handling -
splicing a Dynema cable is pure joy (although it requires the same
time (15 minutes) than doing a complete splice on a steel cable).
Bye
Andreas
Old March 27th 04, 02:35 PM
plasticguy
Has anybody figured the effects of the
elasticity/stretch of the winch cable.
I seem to remember some references to plasma rope
instead of steel cable. This stretch probably
makes it easier to accelerate the drum to speed as the
line stretches. Now it the acceleration rates of the drum
and glider are non-linear at the start of launch, your calculations
of horsepower (should be torque) get really muddy fast.
Scott.
Winch design c1rrus Soaring 10 January 19th 04 12:18 PM
Winch problem Lach and JoAnn Ohman Soaring 8 December 24th 03 05:13 PM
Accurate plane performace? R Simulators 27 December 19th 03 04:54 AM
Winch Way Is Up !! Craig Freeman Soaring 45 November 6th 03 03:08 PM
using winch instead of aerotow goneill Soaring 5 August 27th 03 02:46 PM
