Hi y'all,
I have to replace the cloth tape gap seal after loosing the one on the rudder in flight. I removed the adhesive residue with GooOff, which worked really well and washed the area with denatured alcohol. The new tape still won't stick very strong. The glider is metal with PU-paint. What surface prep solvent can you recommend to make the tape stick? Thanks for the any advise, Uli 'AS' |
Which denatured alcohol did you use? Be sure to use at least 90%. Second, mask off the area that will be taped and lightly sand with 1000 or 1500 grit wet sandpaper. Sand just enough to dull the surface.
Forgot to mention I also use a small roller, designed for installing pill and stick flooring, to push the tape down to insure full contact of the adhesive.
On Sunday, August 13, 2017 at 2:01:31 PM UTC-4, Tim Taylor wrote:
Forgot to mention I also use a small roller, designed for installing pill and stick flooring, to push the tape down to insure full contact of the adhesive. Thanks, Tim! The Denatured Alcohol I use is the pure stuff - not Rubbing Alcohol. I will try sanding and the edge-roller. I was wondering if Acetone would be a better choice to clean up but am not sure if it does attack PU paint. Uli 'AS' |
Uli,
I have found acetone will attack most paints. I use it on gel coat sparingly, but try to use less aggressive solvents if posible. I use the 95% "rubbing" alcohol for most daily wing tape clean up. Works well and and dries clean without an oily feel. Also, see I fat fingered the "peel and stick" tile. Good luck, Tim |
On Sunday, August 13, 2017 at 11:51:18 AM UTC-7, Tim Taylor wrote:
Uli, I have found acetone will attack most paints. I use it on gel coat sparingly, but try to use less aggressive solvents if posible. I use the 95% "rubbing" alcohol for most daily wing tape clean up. Works well and and dries clean without an oily feel. Also, see I fat fingered the "peel and stick" tile. Good luck, Tim 3M Prep-sol. Works well and doesn't attack the paint like acetone. You do have to wipe it dry after application though. Craig 7Q |
I sand the area where the stickie will go with 200 grit and sand the inside (10mm) of the Mylar with 200 grit also. Then wipe everything down with Acetone.........it won't hurt Poly Urethane. Mask off the area to insure the Mylar goes on straight, then roll it down with lots of pressure. I use a 1" bearing on a stick.
JJ |
If you live in a cold climate or are trying to do this in the winter, you should also use a heat gun or hair dryer to warm the surface, transfer tape and mylar as you use the roller. Don't get carried away with the heat, as you can easily damage the mylar and/or wing if you get things too toasty. Sometimes I also go back over the bond after a couple of days with the heat gun and roller. Don't melt the safety tape.
Most of the above advice concerns Mylar seals, so the real question is what solvent Uli needs to prep the surface for the cloth tape. You can try anything, but in order of aggressiveness (And possible damage to the PU paint) Methyl Ethyl Ketone is very aggressive and evaporates with little residue, acetone is second in both qualities and alcohol is the gentlest. It is also possible that the tape you are using does not have as good an adhesive as the original, or it needs a longer time to take a set. Let it cure for a while and use a roller to ensure the join is compressed as much as possible.
LS4 aileron gap seal and mylar seal width | Eric Foertsch | Soaring | 8 | May 18th 17 07:50 PM |
EE Lightning Prep | Bill[_18_] | Aviation Photos | 0 | November 18th 08 08:51 PM |
The party prep is done... | Jay Honeck | Piloting | 0 | July 19th 05 04:24 PM |
Teflon gap seal tape... | Marc Ramsey | Soaring | 10 | April 3rd 05 04:35 PM |
Solvent save for markings | chris | Soaring | 2 | January 22nd 04 12:35 AM |
