https://en.wikipedia.org/wiki/Lockheed_L-188_Electra
The Lockheed L-188 Electra is an American turboprop airliner built by Lockheed. First flown in 1957, it was the first large turboprop airliner built in the United States. Initial sales were good, but after two fatal crashes that led to expensive modifications to fix a design defect, no more were ordered. With its unique high power-to-weight ratio, huge propellers and very short wings (resulting in the majority of the wingspan being enveloped in propwash), large Fowler flaps which significantly increased effective wing area when extended, and four-engined design, the airplane had airfield performance capabilities unmatched by many jet transport aircraft even today—particularly on short runways and high field elevations. Jet airliners soon supplanted turboprops for many purposes, and many Electras were modified as freighters. Some Electras are still being used in various roles into the 21st century. The airframe was also used as the basis for the much more successful Lockheed P-3 Orion maritime patrol aircraft. The Model 188 Electra is a low-wing cantilever monoplane powered by four wing-mounted Allison 501-D13 turboprops. It has a retractable tricycle landing gear and a conventional tail. It has a cockpit crew of three and can carry 66 to 80 passengers in a mixed-class arrangement, although 98 could be carried in a high-density layout. The first variant was the Model 188A, followed by the longer-range 188C with room for 1,000 US gallons (3,800 L) more fuel and maximum take-off weight 3,000 pounds (1,400 kg) higher. Role Turboprop airliner National origin United States Manufacturer Lockheed Corporation First flight December 6, 1957 Introduction January 12, 1959 with Eastern Air Lines Status In limited use Primary users American Airlines Eastern Air Lines Braniff Airways National Airlines Produced 1957–61 Number built 170 Variants Lockheed P-3 Orion American Airlines was the launch customer. Eastern Air Lines, Braniff Airways and Northwest Airlines followed. The Electra suffered a troubled start. Passengers of early aircraft complained of noise in the cabin forward of the wings, caused by propeller resonance. Lockheed redesigned the engine nacelles, tilting the engines upwards three degrees. The changes were incorporated on the production line by mid-1959 or as modification kits for the aircraft already built, and resulted in improved performance and a better ride for passengers. Three aircraft were lost in fatal accidents between February 1959 and March 1960. After the third crash, the FAA limited the Electra's speed until the cause could be determined. After an extensive investigation, two of the crashes (in September 1959 and March 1960) were found to be caused by an engine mount problem. The mounts were not strong enough to damp a phenomenon called "whirl mode flutter" (analogous to the precession of a child's top as it slows down) that affected the outboard engine nacelles. When the oscillation was transmitted to the wings and the flutter frequency decreased to a point where it was resonant with the outer wing panels (at the same frequency, or harmonically related ones), violent up-and-down oscillation increased until the wings would tear off. The company implemented an expensive modification program (the Lockheed Electra Achievement Program or LEAP) in which the engine mounts and the wing structures supporting the mounts were strengthened, and some of the wing skins were replaced with thicker material. All Electras were modified at Lockheed's expense at the factory, the modifications taking 20 days for each aircraft. The changes were incorporated in later aircraft as they were built. However, the damage had been done, and the public lost confidence in the type. This and the smaller jets that were being introduced eventually relegated Electras to the smallest airlines. Production ended in 1961 after 170 had been built. Losses to Lockheed have been estimated as high as $57 million, not counting an additional $55 million in lawsuits. Electras continued to carry passengers into the 1980s, but most now in use are freighters. In 1973, the Argentine Navy bought three Electras equipped with cargo doors. These were used during the "Dirty War" to toss political prisoners into the Rio de La Plata in the infamous death flights. The Electras were also used for transport duties during the Falklands War in 1982. Specifications (Model 188A) General characteristics Crew: Five (3 flight deck) Capacity: 98 passengers Payload: 33,800 lb (15331 kg) Length: 104 ft 6 in (31.85 m) Wingspan: 99 ft 0 in (30.18 m) Height: 32 ft 10 in (10.00 m) Wing area: 1,300 sq ft (120.8 m²) Empty weight: 57,400 lb (26,036 kg) Max. takeoff weight: 113,000 lb (51,256 kg) Powerplant: 4 × Allison 501-D13 turboprop engines, 3,750 eshp (2,800 kW) each Performance Maximum speed: 390 knots (448 mph, 721 km/h) at 12,000 ft (3,660 m) Cruise speed: 324 knots (373 mph, 600 km/h) Range: 1,913 nmi (2,200 mi, 3,540 km) with maximum payload, 2,409 nmi, 2,770 mi, 4,455 km with 17,500 lb (7,938 kg) payload Service ceiling: 32,000 ft (9,753 m) Rate of climb: 1,970 ft/min (10 m/s) * |
On 20 Aug 2017 06:59:37 -0700, Miloch
wrote: Western Airlines was also another user of the Electra. They replaced the DC-6B's as Western's major aircraft. When they introduced the Electra they had two special flights out of Ontario, California for city dignitaries. I knew the Western Airline agent at Ontario, and he was able to get me on board for one of the flights. Great aircraft, the take off run, really pushed you back in your seat ! https://en.wikipedia.org/wiki/Lockheed_L-188_Electra The Lockheed L-188 Electra is an American turboprop airliner built by Lockheed. First flown in 1957, it was the first large turboprop airliner built in the United States. Initial sales were good, but after two fatal crashes that led to expensive modifications to fix a design defect, no more were ordered. With its unique high power-to-weight ratio, huge propellers and very short wings (resulting in the majority of the wingspan being enveloped in propwash), large Fowler flaps which significantly increased effective wing area when extended, and four-engined design, the airplane had airfield performance capabilities unmatched by many jet transport aircraft even today—particularly on short runways and high field elevations. Jet airliners soon supplanted turboprops for many purposes, and many Electras were modified as freighters. Some Electras are still being used in various roles into the 21st century. The airframe was also used as the basis for the much more successful Lockheed P-3 Orion maritime patrol aircraft. The Model 188 Electra is a low-wing cantilever monoplane powered by four wing-mounted Allison 501-D13 turboprops. It has a retractable tricycle landing gear and a conventional tail. It has a cockpit crew of three and can carry 66 to 80 passengers in a mixed-class arrangement, although 98 could be carried in a high-density layout. The first variant was the Model 188A, followed by the longer-range 188C with room for 1,000 US gallons (3,800 L) more fuel and maximum take-off weight 3,000 pounds (1,400 kg) higher. Role Turboprop airliner National origin United States Manufacturer Lockheed Corporation First flight December 6, 1957 Introduction January 12, 1959 with Eastern Air Lines Status In limited use Primary users American Airlines Eastern Air Lines Braniff Airways National Airlines Produced 1957–61 Number built 170 Variants Lockheed P-3 Orion American Airlines was the launch customer. Eastern Air Lines, Braniff Airways and Northwest Airlines followed. The Electra suffered a troubled start. Passengers of early aircraft complained of noise in the cabin forward of the wings, caused by propeller resonance. Lockheed redesigned the engine nacelles, tilting the engines upwards three degrees. The changes were incorporated on the production line by mid-1959 or as modification kits for the aircraft already built, and resulted in improved performance and a better ride for passengers. Three aircraft were lost in fatal accidents between February 1959 and March 1960. After the third crash, the FAA limited the Electra's speed until the cause could be determined. After an extensive investigation, two of the crashes (in September 1959 and March 1960) were found to be caused by an engine mount problem. The mounts were not strong enough to damp a phenomenon called "whirl mode flutter" (analogous to the precession of a child's top as it slows down) that affected the outboard engine nacelles. When the oscillation was transmitted to the wings and the flutter frequency decreased to a point where it was resonant with the outer wing panels (at the same frequency, or harmonically related ones), violent up-and-down oscillation increased until the wings would tear off. The company implemented an expensive modification program (the Lockheed Electra Achievement Program or LEAP) in which the engine mounts and the wing structures supporting the mounts were strengthened, and some of the wing skins were replaced with thicker material. All Electras were modified at Lockheed's expense at the factory, the modifications taking 20 days for each aircraft. The changes were incorporated in later aircraft as they were built. However, the damage had been done, and the public lost confidence in the type. This and the smaller jets that were being introduced eventually relegated Electras to the smallest airlines. Production ended in 1961 after 170 had been built. Losses to Lockheed have been estimated as high as $57 million, not counting an additional $55 million in lawsuits. Electras continued to carry passengers into the 1980s, but most now in use are freighters. In 1973, the Argentine Navy bought three Electras equipped with cargo doors. These were used during the "Dirty War" to toss political prisoners into the Rio de La Plata in the infamous death flights. The Electras were also used for transport duties during the Falklands War in 1982. Specifications (Model 188A) General characteristics Crew: Five (3 flight deck) Capacity: 98 passengers Payload: 33,800 lb (15331 kg) Length: 104 ft 6 in (31.85 m) Wingspan: 99 ft 0 in (30.18 m) Height: 32 ft 10 in (10.00 m) Wing area: 1,300 sq ft (120.8 m²) Empty weight: 57,400 lb (26,036 kg) Max. takeoff weight: 113,000 lb (51,256 kg) Powerplant: 4 × Allison 501-D13 turboprop engines, 3,750 eshp (2,800 kW) each Performance Maximum speed: 390 knots (448 mph, 721 km/h) at 12,000 ft (3,660 m) Cruise speed: 324 knots (373 mph, 600 km/h) Range: 1,913 nmi (2,200 mi, 3,540 km) with maximum payload, 2,409 nmi, 2,770 mi, 4,455 km with 17,500 lb (7,938 kg) payload Service ceiling: 32,000 ft (9,753 m) Rate of climb: 1,970 ft/min (10 m/s) * |
wrote in message ...
On 20 Aug 2017 06:59:37 -0700, Miloch wrote: Western Airlines was also another user of the Electra. They replaced the DC-6B's as Western's major aircraft. When they introduced the Electra they had two special flights out of Ontario, California for city dignitaries. I knew the Western Airline agent at Ontario, and he was able to get me on board for one of the flights. Great aircraft, the take off run, really pushed you back in your seat ! The article below is par for the course when it comes to most Sub-Saharan airlines. The Lockheed L-188 Electra now carries cargo mostly, but in darkest Africa, the natives are packed aboard SRO, and folklore is rich with tales about, when a fuselage is full, jungle bunnies with only a few shillings to spend will be allowed to climb into the baggage compartments, meaning that on takeoff these 60-year-old airframes are carrying two to three times the number of passengers they were designed for. "Many private airlines operate out of Zaire, with relatively few controls over safety and maintenance." Of course, most aren't FAA-certified. "There have been a spate of plane crashes in the region recently." As long as all those involved are from the Heart of Darkness, it rarely makes the news: https://aviation-safety.net/database...?id=19951218-0 ------------------------------------------------------------------------- Mystery surrounds Angola plane crash victims (c) 1995 Copyright Nando.net (c) 1995 Reuter Information Service KINSHASA (Dec 20, 1995 - 09:17 EST) - The identity of 139 people killed when a Zairean charter flight crashed in northern Angola on Monday remained a mystery two days after the world's worst air disaster of 1995. An Angolan government official said on Wednesday the plane crashed in Angola's Lunda Norte province near the Zairean border and may have been on charter to Jonas Savimbi's opposition UNITA movement. Zaire's transport minister, Alexis Thambwe Mwamba, said 139 of the 144 people on Monday's flight from Kinshasa had been killed. Doctors said four of the survivors were in intensive care with serious burns. "There were 139 people on board, plus five crew. There were only five survivors," Thambwe Mwamba told Reuters on Tuesday. A ministry official said most of the dead were Angolans but had no further details. Thambwe Mwamba had no precise details on where the plane went down, its destination or on the identity of the passengers. Lunda Norte governor Moises Ndele told Angolan state radio the plane had crashed in the UNITA-controlled Cuango area of the province. "The plane could have been rented by UNITA coming from Zaire via Damba, which is a region under UNITA's control in Uige province. "The plane crashed around the Cuango area, an area under UNITA control," he said, adding that aircraft from Zaire frequently landed at an airstrip close to the town of Luzamba. Another theory suggested a link with the diamond trade. Many of the diamonds produced in Angola's remote Lunda Norte and Lunda Sul regions are smuggled out via Zaire and large numbers of Zaireans regularly travel to eastern Angola to dig for diamonds or buy them to sell. For many years Zaire was accused of supporting Savimbi's UNITA rebels, who controlled much of the diamond area but have since agreed a peace deal with the government in Luanda. Many private airlines operate out of Zaire, with relatively few controls over safety and maintenance. In May 1994, Zaire's acting foreign minister and a Tunisian presidential aide were among nine people killed in a crash on the approach to Kinshasa's Ndjili airport. A transport ministry official said the plane used for Monday's charter flight was an Electra, based at Ndjili and owned by Trans Service Airlift, a private company. Officials could not say what caused the crash but Thambwe Mwamba said an inquiry was under way. "I also have to speak to the owner of TSA, who is a Belgian. I hope we should know more in the next few days," he said. Hospital staff said five survivors were flown to Kinshasa on Tuesday and four were in intensive care in Ngaliema clinic. "They have been badly burned and their condition is serious. At this stage they are unable to talk," a doctor said. A fifth survivor, the co-pilot, had been taken away by his family. Five corpses were also brought back from Angola. Reference books suggest the largest Electra, a plane built by Lockheed, entered service worldwide in 1959 with an intended capacity of 99 passengers or 12 tonnes of cargo. There have been a spate of plane crashes in the region recently. On December 3 a Cameroon Airlines Boeing 737 crashed as it came into land at Cameroon's Douala port, killing 72 people. In Nigeria's latest accident last month, a Nigeria Airways Boeing 737 crashed on landing at Kaduna airport in the north, killing nine people and injuring 44. Before Monday's crash, the worst air disaster of 1995 involved a Russian Aeroflot Tu-154 which disappeared on December 7 with 97 people on board. The wreckage was found on Monday inland from the Tatar Strait. |
