FES vs Gas Engine – Finding a Thermal?
Old August 24th 17, 09:28 PM posted to rec.aviation.soaring
V1[_4_]
Default FES vs Gas Engine – Finding a Thermal?
While reading the FES article in June Soaring (yes, I’m behind in my reading), I noticed the author’s comment about searching for a thermal while FES was running, then shutting down FES as he started to climb. This is a topic I don’t recall seeing discussed in any FES vs gas comparisons.
In my Solo-powered Ventus 2cxT, my experience has been that the vibration (and possibly disturbed airflow) caused so much wild gyration in the vario readings that it seemed pointless to try to determine if I was flying into rising air, so I just climbed first, then shut down the engine and started a thermal search.
My question – do others have experience to share about their ability to find thermals while a sustainer or self-launcher (either gas or electric) was running? If electric has an advantage here, this could reduce the run-time needed and conserve “fuel”.
- Frank
Old August 24th 17, 09:42 PM posted to rec.aviation.soaring
Bruce Hoult
I've only had ten or so flights in a Grob 109, but on as far as I can recall every one of them we shut down the engine once established in lift ... in some cases in thermals, or often in ridge lift just after (barely) clearing the trees at the end of the strip (which was on a plateau).
Old August 24th 17, 10:23 PM posted to rec.aviation.soaring
Dave Nadler
was running?
Sure, but it depends a lot on the glider and power plant.
In Antares I normally reduce power just after take-off down to 400-500fpm climb.
When I feel the first thermal, I make a circle to be sure.
If pretty sure, bring the power all the way back but do not shut down.
If I'm climbing one turn, I retract motor.
Typical altitude about 1000 ft, for example:
https://www.onlinecontest.org/olc-2....Id=-1855578239
or a bit lower, with a brief boost after initial shutdown:
https://www.onlinecontest.org/olc-2....Id=-1769203627
Try this in most motor-gliders and you'll kill yourself.
In ArcusM it is more difficult to feel the thermal, but in any case one
needs to go much higher for a safer shut-down (typically climb to 2500ft).
A thermal helps here but you still have to do the cool-down cycle and
plummet-mode during retraction (sometimes takes a couple tries).
And because of the plummet factor your search area is severely restricted
by the need to be close-in for an emergency return on failure.
In my prior motorglider was really hard to feel the thermals, and again
being gas powered with severe plummet mode, had to always go a lot higher.
Absolutely, but ONLY if:
- there is lift near the launch point, and
- traffic permits low-level thermalling (while always maintaining
a safe emergency return plan).
Hope that helps!
Best Regards, Dave
Old August 25th 17, 12:54 AM posted to rec.aviation.soaring
Dan Marotta
It's pretty easy in the Stemme with the triple probe mounted to the
front of the nose cone, in front of the propeller.* All the soaring
instruments work as designed without interference from the prop. BTW,
the Stemme (used) costs less than the Arcus AND you can take a friend! :-D
- Frank
Dan, 5J
Old August 25th 17, 01:03 AM posted to rec.aviation.soaring
JS[_5_]
Doesn't everyone with a SLSP do this every flight?
Worked fine in the ASH26E. CAI302 with electronic TE.
Seat of the pants input is useful too.
Vibration? That's for two-stroke users.
Old August 25th 17, 06:35 AM posted to rec.aviation.soaring
Scott Manley[_2_]
I fly an Alisport Silent 2 Electro (FES capable of self-launch).
I take off with full power, climb to a safe altitude, pull the gear up, reduce power to about 80%, and then cruise-climb looking for a thermal. When I find one, I start circling and continue to run the motor. This gets me up into the stronger part of the thermal more quickly.
When it is obvious the thermal is doing most of the lifting, I shut down the motor. With the FES, the shutdown is automatic after dialing the motor down below 1000 RPM (a couple counter-clockwise turns on the rheostat). The motor controller takes over, electronically brakes the motor/prop to a stop, and the blades fold back aerodynamically. The controller then positions the blades along side the fuselage by pulsing the motor.
I simply continue to work the thermal.
On any decent soaring day, I use about 20% of the battery capacity to launch and climb into a thermal, leaving 80% in reserve in case I do something stupid.
On more than one occasion, I have restarted the FES in flight when a thermal didn't pan out. One one flight, I had launched a little too early in the day and needed to restart/re-climb four times before the day started working. Fortunately, starting and stopping the FES is as simple as turning the volume up/down on a radio, minimizing pilot workload to near zero.
The pitot/TEC probe on the Silent 2 Electro is mounted high on the vertical stabilizer, clear of (above) the prop wash.
Old August 25th 17, 05:46 PM posted to rec.aviation.soaring
Tony[_5_]
My experience in the Electro mirrors Scott's, although he seems to be better at centering the low thermals than I! I'm usually closer to 30% battery used for a self launch.
Old August 25th 17, 06:34 PM posted to rec.aviation.soaring
Dave Nadler
On Friday, August 25, 2017 at 12:46:05 PM UTC-4, Tony wrote:
... I'm usually closer to 30% battery used for a self launch.
In Antares 20E (without charge+) I'm typically around 15% used.
Obviously depends on ballast load and how high...
Old August 29th 17, 08:56 PM posted to rec.aviation.soaring
My experience is similar to Tony's. I usually climb to 1000 at about 70% power then dial back to sustainer level 4 KW searching for the 1st thermal then center the thermal until I climb to 2000 then shut down. A good day I will have 70% battery left. On a bad day 50%
There is no plummet mode with the FES
Old August 29th 17, 11:09 PM posted to rec.aviation.soaring
Dave Walsh
Default _FES_vs_Gas_Engine_–_Finding_a_Thermal?
Not sure an electric "engine on a stick" is sensible as a new
design for a get you home (turbo) glider - all the drag and
complexity of the erection mechanism/doors etc. Surely the
FES route make much more sense - simpler, less drag, more
efficient.
Of course if you already own a Rotax/Solo shaker stick engine
it might be attractive (outside of EASA land) you lucky
Americans.
When the engine on a stick fails the drag is very dependant on
the individual sailplane: it's not just the engine & pylon there's
often a big radiator too. From recollection the DG400(&PIK20E)
was about 14:1; the DG800B/C a bit better, a previous post
gives 20:1 for the ASH26E; the Antares 20E (no radiator) is
30:1.
Dave Walsh
Need help finding someone. Tim Murphy Soaring 0 March 12th 12 04:15 PM
Thermal Forcasting -Thermal index gldrgidr Soaring 6 November 27th 10 10:26 PM
Thermal Data Files Thermal Mapping Project Australia Mal Soaring 0 December 2nd 05 11:14 PM
Finding a partnership Greg Owning 11 November 10th 03 08:40 PM
Help finding photo Chris W Piloting 11 July 29th 03 04:07 PM
