Filser interfacing woes
Old April 2nd 04, 06:40 PM
CV
Default Filser interfacing woes
Hello all,
My old portable PC packed up definitely a few weeks ago and
when I started looking around for a new one I found that
none of them have the old traditional serial port anymore !?
This rather leaves me in the lurch with the Filser GPS-logger
in my glider, since the interface is over a cable that connects
to the serial port.
I imagine there may be others here who have come up agaist
the same thing. Can anyone point me to a solution ?
The model is Filser DX-50, functionally equivalent to the Lx5000
I am told, and possibly this particular problem will be the
same for some other models as well.
Cheers CV
Old April 2nd 04, 07:42 PM
JJ Sinclair
to the serial port
I was able to stop the interferance in my B-100, by routing the cable from the
GPS, away from all the other cables. I also moved the radio antenna cable
(RG-58) to the other side of the instrument panel. All my problems went away. I
think most of it was getting in through the antenna cable. I even had my audio
playing Mexican music in the central California valley, but I think that had
something to do with some day labor's getting back at Zero Sinco.
JJ Sinclair
Old April 2nd 04, 07:46 PM
Eric Greenwell
CV wrote:
Hello all,
to the serial port.
If a downloading program is available for an older PDA like the Compaq
Aero 1500 series, using one of those might be more convenient than a
laptop, and not much more costly (think eBay) than a potentially
problematic USB to Serial adapter. I use 1530 to download the files from
my Cambridge loggers to a compact flashcard, and it's a lot easier than
lugging a laptop around.
change "netto" to "net" to email me directly
Eric Greenwell
Washington State
USA
Old April 2nd 04, 08:30 PM
Eggert Ehmke
Of what problems do you think? I tested some different low cost
USB-to-serial adapters, and all worked fine, with Windows software as well
as with Linux.
Eggert
Old April 2nd 04, 08:34 PM
Eggert Ehmke
All new notebooks have USB ports, that replace the serial ports. To connect
an old serial cable, you need an usb-to-serial adapter. These adapters are
to be found in electronic shops, and on eBay in the 10-20 $ range (at least
in europe). They work fine.
Eggert
Old April 2nd 04, 09:40 PM
Robert Danewid
Eggert
You are wrong! Not all work fine. We have tested several. Some work with
some loggers others do not. We have tested several adapters with
Camridge, EW, Volkslogger and LX, no one worked with all logges.
This is a real problem.
To me the "PDA solution" is the best solution.
Robert
Eggert
Old April 3rd 04, 06:32 AM
CV
Eggert
Big thanks to you, and others who replied. The adapter seems to be
the quick and easy way out for the moment. But I'll keep the PDA
in mind too. Must say that fiddling around with the laptop in
the cockpit when you are just about to derig and have a thousand
other things to think about is a bit invonvenient.
Thanks again /CV
Old April 3rd 04, 08:23 AM
tango4
Why not try an up-to-date laptop with bluetooth capability. With a bluetooth
adaptor in the cockpit downloads, uploads and task programming can be
acheived from the laptop in your car or minivan!
Ian
"CV" wrote in message
connect
are
least
Eggert
Thanks again /CV
Old April 5th 04, 06:09 PM
Denis
interesting, but are there Bluetooth adaptors that fit on a LX 5000
without requiring a PC (I guess it would be a serial to Bluetooth
adaptor) ? Have you tried it ?
Denis
R. Parce que ça rompt le cours normal de la conversation !!!
Q. Pourquoi ne faut-il pas répondre au-dessus de la question ?
Old April 5th 04, 06:55 PM
tango4
I have tried it with variable results. I have some RS232 to bluetooth
adaptorsthat automagically connect to my laptop once it comes within range.
Once I have sorted out how to make a reliable connection I'll post the
results here.
Ian
"Denis" wrote in message
bluetooth
Denis
Volkslogger woes Dan Rihn Soaring 10 March 25th 04 03:10 PM
Russian Air Force Woes - Time to start again? Peter Kemp Military Aviation 31 February 21st 04 02:10 AM
V-22 crash woes over, military says, By Tony Cappacio Otis Willie Military Aviation 0 January 23rd 04 02:36 AM
Cambridge 302 DDV woes - Help me PLEASE !!! Mike Borgelt Soaring 7 October 11th 03 10:44 AM
