I'm new to both of these products, and I'm a bit perplexed about a
connection question. My iPaq has a cradle added to the glider by the previous owner, who like myself, ran WinPilot. The iPaq receives the GPS's NMEA stream from the cradle's connection to the LX5000. Works great, no problem. I expect SeeYou Mobile, which I'm now starting to play with, will see the same NMEA stream on the same comm port and be just as happy. But when I tried to use the "Downloader" program on the iPaq in the same cradle, it couldn't establish a connection with the LX5000, and some stuff I've seen on the web talks about using a null modem cable adaptor and the LX5000's other 5-pin connection on the instrument panel. Why wouldn't/couldn't Downloader use the same connection that the GPS stream uses? Is it simply a matter of that connection being dedicated strictly to GPS data? -ted |
I have read your post and there are two possible problems:
1. For Winpilot you need only one way connection. Because of that some installations have only transmit and ground line connected from the instrument. For DownLoader you need both transmit and receive. 2. If you are using standard PC transfer cable to connect to the cradle cable your first problem is that DB9 female connector is on both sides. You can not use the gender changer adapter, because you will be connecting wrong pins. You have to use null modem adapter. Regards Uros www.flyWithCE.com "Ted Wagner" wrote in message news:MbVbc.39723$wl1.29922@fed1read06... I'm new to both of these products, and I'm a bit perplexed about a connection question. My iPaq has a cradle added to the glider by the previous owner, who like myself, ran WinPilot. The iPaq receives the GPS's NMEA stream from the cradle's connection to the LX5000. Works great, no problem. I expect SeeYou Mobile, which I'm now starting to play with, will see the same NMEA stream on the same comm port and be just as happy. But when I tried to use the "Downloader" program on the iPaq in the same cradle, it couldn't establish a connection with the LX5000, and some stuff I've seen on the web talks about using a null modem cable adaptor and the LX5000's other 5-pin connection on the instrument panel. Why wouldn't/couldn't Downloader use the same connection that the GPS stream uses? Is it simply a matter of that connection being dedicated strictly to GPS data? -ted |
The LX 5000 may not allow the ipaq to talk to the logger directly. I know
the LX 1600 has a mode to allow it to become transparent when a program like downloader is trying to talk to the logger. Also some filser ( LX ) instruments do not pass the entire GPS stream through to the ipaq, they filter out all but the stuff thats required and pass it to the ipaq. This removes some overhead from the iPaq but it can be aproblem if you are trying to get secondary data to your iPaq! Ian "Ted Wagner" wrote in message news:MbVbc.39723$wl1.29922@fed1read06... I'm new to both of these products, and I'm a bit perplexed about a connection question. My iPaq has a cradle added to the glider by the previous owner, who like myself, ran WinPilot. The iPaq receives the GPS's NMEA stream from the cradle's connection to the LX5000. Works great, no problem. I expect SeeYou Mobile, which I'm now starting to play with, will see the same NMEA stream on the same comm port and be just as happy. But when I tried to use the "Downloader" program on the iPaq in the same cradle, it couldn't establish a connection with the LX5000, and some stuff I've seen on the web talks about using a null modem cable adaptor and the LX5000's other 5-pin connection on the instrument panel. Why wouldn't/couldn't Downloader use the same connection that the GPS stream uses? Is it simply a matter of that connection being dedicated strictly to GPS data? -ted |
| Thread Tools | |
| Display Modes | |
| Mobile SeeYou & Winpilot | Ian Molesworth | Soaring | 8 | March 25th 04 02:07 AM |
| N94 Airport may expand into mobile home community, locals supportive | William Summers | Piloting | 0 | March 18th 04 04:03 AM |
| SeeYou Mobile | Robert Fidler | Soaring | 0 | March 17th 04 05:18 PM |
| SeeYou Mobile question | Greg Arnold | Soaring | 1 | February 19th 04 05:24 PM |
| SeeYou mobile questions | Andy Durbin | Soaring | 5 | February 19th 04 01:16 AM |
