Has anyone done a 337 to modify a Std Libelle with the Tost 4" wheel? Looking tech data for a 337 or a precedent of someone that has already done this.. I know the Tost Wheel Selection Chart shows compatibility and Streifeneder is ok with the substitution but that's probably enough to satisfy the FAA.
On Sunday, September 17, 2017 at 5:32:43 PM UTC-7, wrote:
Has anyone done a 337 to modify a Std Libelle with the Tost 4" wheel? Looking tech data for a 337 or a precedent of someone that has already done this. I know the Tost Wheel Selection Chart shows compatibility and Streifeneder is ok with the substitution but that's probably enough to satisfy the FAA. Uh this has accommodation for a 4" wheel already right? You are talking off one tailwheel and replacing it with another, maybe with washers or axle spacers? Right? What major modification is being made here and who is telling you a 337 is required? |
Hmmmm........
Do you have the motorcycle wheel, the one that has spoke holes? If so, no 337 needed to replace with current factory unit in use (Stiefenater) JJ |
Has anyone done a 337 to modify a Std Libelle with the Tost 4" wheel? Looking tech data for a 337 or a precedent of someone that has already done this. I know the Tost Wheel Selection Chart shows compatibility and Streifeneder is ok with the substitution but that's probably enough to satisfy the FAA. Mike et al: If you are doing this to improve the brakes, a more simple approach would be to take the wheel to a motorcycle brake shop that still does drum brakes. There are not many places that do that sort of vintage stuff. I've used Vintage Brake in Sonora, California. Mike does a great job of relining and arcing the shoes, but the shop normally has a waiting list. One method to secure a spot and not have your glider down for months is to pay up front and you'll be informed when to send your whole main wheel in. Vintage Brake Michael Morse 209 533-4346 info AT vintagebrake.com www.vintagebrake.com The last job I sent to them was a Libelle wheel. It could put the glider on the nose after the mod. Jim |
What is the long term brake performance?
My thoughts, limited in types, is "Tost" should be "Toast"......,good for one hard braking, then they're toast. Not sure if it's the braking material or the drum. Pull it apart, sand (200 grit or so dry) on the shoes and drums, great for one hard braking event, repeat process. I'm guessing the brake material. Most recent experience is a 2 place Lark. In general, my experience is Tost drum brakes are weak other than the first application. If you have a better experience, please share. I still think it's the shoe friction material from the OEM. Maybe your motorcycle shop has a decent friction material that lasts for multiple hard stops, great! This from someone that has done "band brakes" (1-26 brake against the tire tread.....sucks when the ground is wet) up to various ASW's where you grind the Gelcoat off the belly if you're not careful on pavement. |
On Monday, September 18, 2017 at 11:36:40 AM UTC-7, Charlie M. (UH & 002 owner/pilot) wrote:
What is the long term brake performance? My thoughts, limited in types, is "Tost" should be "Toast"......,good for one hard braking, then they're toast. Not sure if it's the braking material or the drum. Pull it apart, sand (200 grit or so dry) on the shoes and drums, great for one hard braking event, repeat process. I'm guessing the brake material. Most recent experience is a 2 place Lark. In general, my experience is Tost drum brakes are weak other than the first application. If you have a better experience, please share. I still think it's the shoe friction material from the OEM. Maybe your motorcycle shop has a decent friction material that lasts for multiple hard stops, great! This from someone that has done "band brakes" (1-26 brake against the tire tread.....sucks when the ground is wet) up to various ASW's where you grind the Gelcoat off the belly if you're not careful on pavement. I never said anything about a braking issue, I said I wanted to replace the original wheel with the TOST wheel. My A&P interprets the FAA regs as no different parts in a "Type Certificated " aircraft are allowed without an Supplimental Type Certificate issued approving the different part or a Tech Memo from the Certificate Holder (Streifeneder). |
Later 201's came with a Tost wheel, Stiefanater holds the type certificates for all Glasflugel ships, he also sells Tost wheels. No 337 required, no supplemental type cert needed.
JJ |
On Monday, September 18, 2017 at 4:00:02 PM UTC-7, wrote:
Later 201's came with a Tost wheel, Stiefanater holds the type certificates for all Glasflugel ships, he also sells Tost wheels. No 337 required, no supplemental type cert needed. JJ Thanks you! |
I got really excited earlier this year and installed the Beringer wheel in my libelle. Now have a disk brake that works fantastic.
Not sure how you would get around it there, but Streifeneder does have a TM for it |
On Tuesday, September 19, 2017 at 2:10:36 AM UTC-7, Ross wrote:
I got really excited earlier this year and installed the Beringer wheel in my libelle. Now have a disk brake that works fantastic. Not sure how you would get around it there, but Streifeneder does have a TM for it Yes...I saw that modification....think I'll stay with a drum brake for now until I get more experience with a tail dragger...My previous flying has been in either nose wheel gliders or skids up front. |
Wing Wheel - Std Libelle | [email protected] | Soaring | 0 | August 13th 13 11:49 PM |
Tost 5“Penta disk brake wheel Mod for Duo Discus | Mike I Green | Soaring | 0 | February 6th 12 09:38 PM |
Tost brass tail wheel, tube, tire for sale: USA | Barny | Soaring | 2 | August 12th 11 10:43 PM |
Libelle broken wheel landing | Burt Compton - Marfa | Soaring | 3 | April 25th 11 05:55 PM |
need Libelle wheel installed pix | Brad[_2_] | Soaring | 10 | July 31st 10 02:01 AM |
