Removing oxidation from Cobra trailer trim rubber and plastic fenders
Old September 24th 17, 06:43 PM posted to rec.aviation.soaring
Dave Nadler
Default Removing oxidation from Cobra trailer trim rubber and plastic fenders
I have an older Cobra with rubber trim strip (bottom edge of trailer top),
originally nice shiny red, now a bit dark and dull.
Anybody have a proven technique for getting the color back?
Similar for fenders?
Thanks,
Best Regards, Dave
Old September 24th 17, 07:12 PM posted to rec.aviation.soaring
Roy B.
Hi Dave:
On my Nimbus I masked the trim and hit it with Krylon brand "Fusion" spray paint. It bonds to plastic well. Also - Spindleberger sells replacement trim if you like.
Roy
Old September 25th 17, 02:40 PM posted to rec.aviation.soaring
I did what Roy did, knock off the crud with wire brush and 80 grit sandpaper, then mask and shoot with rattle-can, changed to blue. I used 2" tape on top and a 3 foot piece of cardboard below the lip.......spraying 2 foot at a time with the can aimed down 45 degrees. I'm buffing the glass top now........good winter projects.
JJ
Old September 25th 17, 04:25 PM posted to rec.aviation.soaring
Dan Marotta
Default Removing oxidation from Cobra trailer trim rubber and plasticfenders
Curious - why blue instead of red?Â* Something to do with solar radiation?
On 9/25/2017 7:40 AM, wrote:
I did what Roy did, knock off the crud with wire brush and 80 grit sandpaper, then mask and shoot with rattle-can, changed to blue. I used 2" tape on top and a 3 foot piece of cardboard below the lip.......spraying 2 foot at a time with the can aimed down 45 degrees. I'm buffing the glass top now.......good winter projects.
JJ
Dan, 5J
Old September 25th 17, 05:05 PM posted to rec.aviation.soaring
It's a general phenomenon. Red paint/pigments etc reflect longer wavelengths and absorb more blue and UV. Blue reflects more blue and UV so it fades less. Blue cobra trim fades little. Red much more. In the UK some older red cars often become very faded (especially Vauxhall/Opels)
Old September 24th 17, 07:13 PM posted to rec.aviation.soaring
Tom Kelley #711
Thanks,
Best Regards, Dave
Remove and replace with new! Also known as how to end bore doom during winter months.
Best. #711.
Best.
Old September 24th 17, 07:17 PM posted to rec.aviation.soaring
Roy B.
Spindleberger catalog calls it "protection stripe"
Old September 24th 17, 07:27 PM posted to rec.aviation.soaring
Tom Kelley #711
And Vendors here in USA sell this.
Best. #711.
Old September 24th 17, 08:42 PM posted to rec.aviation.soaring
Jim N
Thanks,
Best Regards, Dave
Use boat stuff avail at a place like West Marine. Suggest Inflatable Boat Cleaner
Cobra trailer trim [email protected] Soaring 11 September 5th 13 03:54 PM
Cobra trailer wing dolly plastic sidewall rollers? [email protected] Soaring 4 May 9th 13 10:52 PM
plastic or metal fenders on the trailer? chris Soaring 14 December 20th 10 09:51 PM
Cobra trailer trim. Bob Soaring 12 July 19th 06 05:12 AM
Help - Cobra Trailer Trim? WDM Soaring 2 January 12th 05 07:47 PM
