Hi,
i just made my first flights with my new glider: Discus CS. I've never flown a Discus before. One thing i recognized was the hight stall speed. I wonder if this could be normal, so i'm interested in your experiences with this ship. I flew the glider without water. With 45 knots i got some warning and with 40 knots i stalled. (In the manual they talk about 35 knots). In thermals i have to fly at min.48 better 51 knots. Even on landing i had to be real fast for my feelings. Any suggestions ? Thanks Hans |
Check your airspeed indicator for accuracy.
Hans Hallder wrote: Hi, i just made my first flights with my new glider: Discus CS. I've never flown a Discus before. One thing i recognized was the hight stall speed. I wonder if this could be normal, so i'm interested in your experiences with this ship. I flew the glider without water. With 45 knots i got some warning and with 40 knots i stalled. (In the manual they talk about 35 knots). In thermals i have to fly at min.48 better 51 knots. Even on landing i had to be real fast for my feelings. Any suggestions ? Thanks Hans |
Better yet, check your weight. The stall 'speed' depends
on many factors and will vary with weight, configuration, and g loading. The best way is to stall the glider in every cofiguration to see what happens, what warning you get. The speed at which it stalls with you in the seat is the stall speed. I always recommend to anyone flying a glider new to them that they carry out a stall in the landing configuration, wheel down, flaps down and spoilers/brakes extended so that they recognise the signs of the approaching stall before it happens for real. Thermalling at 48kts in a Discus does not sound that far out to me but I am on the heavy side. When you say fast approach what do you call fast? 55kts is normally enough except in very stong winds or turbulence. At 11:18 19 April 2004, Charles Yeates wrote: Check your airspeed indicator for accuracy. Hans Hallder wrote: Hi, i just made my first flights with my new glider: Discus CS. I've never flown a Discus before. One thing i recognized was the hight stall speed. I wonder if this could be normal, so i'm interested in your experiences with this ship. I flew the glider without water. With 45 knots i got some warning and with 40 knots i stalled. (In the manual they talk about 35 knots). In thermals i have to fly at min.48 better 51 knots. Even on landing i had to be real fast for my feelings. Any suggestions ? Thanks Hans |
Depending on centre of gravity position, 48-50 knots
is ideal for thermalling the Discus. For heavy pilots, a (removeable) lead weight can be fitted to the top of the fin - this would help to move the CG backwards and slightly lowers the circling speed. Your local Schempp-Hirth rep should be able to supply one. When landing, the glider has quite a nose-up attitude, so it is better to approach slightly faster and/or steeper than normal to have a good view of the landing area. The airbrakes are very effective so this is never a problem. At 10:48 19 April 2004, Hans Hallder wrote: Hi, i just made my first flights with my new glider: Discus CS. I've never flown a Discus before. One thing i recognized was the hight stall speed. I wonder if this could be normal, so i'm interested in your experiences with this ship. I flew the glider without water. With 45 knots i got some warning and with 40 knots i stalled. (In the manual they talk about 35 knots). In thermals i have to fly at min.48 better 51 knots. Even on landing i had to be real fast for my feelings. Any suggestions ? Thanks Hans |
Hi,
My Discus Bwl weighs about 235kg empty (515lbs) With my weight of 75kg plus a 'chute (Approx 5kg) I have a cockpit weight of 80kg (176lbs) At this load (Dry) I have a stall speed of 36kts and can thermal reasonably easily in the low 40s With 100kg water (220 lbs) stall speed goes up to around 40kts and I need to thermal in the high 40s So unless you're 100kgs heavier than me - And I'm assuming that if you can actually get in the glider this is not the case - I'd get your ASI checked. The Discus (dry) will happily approach & round out at 50-55kts, but, as someone said earlier it's pretty nose high at these speeds, so if you're not used to it, and are maintaining what looks like a 'normal' approach attitude to you, then your speed will build up. Regards Kevin At 13:00 19 April 2004, Alan Irving wrote: At 10:48 19 April 2004, Hans Hallder wrote: Hi, i just made my first flights with my new glider: Discus CS. I've never flown a Discus before. One thing i recognized was the hight stall speed. I wonder if this could be normal, so i'm interested in your experiences with this ship. I flew the glider without water. With 45 knots i got some warning and with 40 knots i stalled. (In the manual they talk about 35 knots). In thermals i have to fly at min.48 better 51 knots. Even on landing i had to be real fast for my feelings. Any suggestions ? Thanks Hans |
Flight Test RealAir Griffon Spitfire | Dudley Henriques | Simulators | 1 | December 4th 04 11:46 AM |
Landing and T/O distances (Was Cold War ALternate Basing) | Guy Alcala | Military Aviation | 3 | August 13th 04 12:18 PM |
Angle of climb at Vx and glide angle when "overweight": five questions | Koopas Ly | Piloting | 16 | November 29th 03 10:01 PM |
