https://en.wikipedia.org/wiki/PZL_M28_Skytruck
The PZL M28 Skytruck is a Polish STOL light cargo and passenger plane, produced by PZL Mielec, as a development of license-built Antonov An-28. Early licence-built planes were designated PZL An-28. The maritime patrol and reconnaissance variants are named PZL M28B Bryza ("sea breeze"). The Antonov An-28 was the winner of a competition against the Beriev Be-30 for a new light passenger and utility transport for Aeroflot's short haul routes, conceived to replace the highly successful An-2 biplane. The An-28 is derived from the earlier An-14. Commonalities with the An-14 include a high wing layout, twin fins and rudders, but it differs in having a reworked and longer fuselage, with turboprop engines. The original powerplant was the TVD-850, but production versions are powered by the more powerful TVD-10B, with three-blade propellers. The M28 is a twin-engined high-wing strutted monoplane with an all-metal airframe, twin vertical fins and a tricycle fixed landing gear. If an engine fails, a spoiler forward of the aileron opens automatically on the opposite wing. This limits the wing drop to 12° in five seconds instead of 30°. It is capable of Short takeoff & landing (STOL) and hot and high altitude operations. Aerodynamically deployed leading edge slats when approaching stall speed enable a 64 kn (119 km/h) low stall speed and while the certification landing field is 1,640 ft (500 m), PZL has demonstrated landing in 512 ft (156 m). Inlet air ducts inertial separators and inverted configuration of the PT6 and the high wing configuration protect the engines and propellers against foreign object damage for unprepared runways operations. Role STOL transport and patrol aircraft Manufacturer PZL Mielec Design group Antonov/PZL Mielec First flight 22 July 1984 (PZL An-28) 24 July 1993 (PZL M28 Skytruck) Status In production, In active service Primary users Polish Air Force Polish Navy Venezuelan Army United States Air Force Produced 1984-1993 (PZL An-28) 1993- (PZL M28 Skytruck) Number built 176+ (including PZL An-28) Unit cost US$6.5-7 Million Developed from Antonov An-28 176 An-28s and M28s in all variants were built in Poland by 2006. Most numerous users are former Soviet civil aviation and the Polish Air Force and Navy (about 25 as of 2006), smaller numbers are used by the Polish civil aviation and in the United States, Nepal, Colombia, Venezuela, Vietnam and Indonesia. On 4 November 2005, a Vietnamese Airforce M28 crashed in Gia Lam district, Hanoi. All three crewmembers were killed. On 12 February 2009, The weekly periodical Air Force Times reported that the Air Force Special Operations Command (AFSOC) would receive 10 PZL M28 Skytrucks in June 2009. These aircraft carry the U.S. Air Force model design series (MDS) designation of C-145A Skytruck. In 2011 one aircraft crash landed in Afghanistan and was damaged beyond repair. Specifications (PZL M28) General characteristics Crew: 2 Capacity: 19 passengers (17 paratroopers) Payload: 2,300 kg (5,070 lb) Length: 13.10 m (43 ft) Wingspan: 22.06 m (72.38 ft) Height: 4.90 m (16.08 ft) Wing area: 39.72 m² (427.5 ft²) Empty weight: 4,354 kg (9,601 lb) Max. takeoff weight: 7,500 kg (16,534 lb) Fuel capacity: 1,766 kg / 3,894 lb, 2,278 l / 602 US Gal Cabin Length × Width × Height: 5.26 × 1.73 × 1.72 m / 17.25 × 5.66 × 5.63 ft Powerplant: 2 × Pratt & Whitney Canada PT6A-65B turboprops, 820 kW (1,100 shp) each Performance Maximum speed: 355 km/h (192 kts) Cruise speed: 244 km/h (132 kts) long range Stall speed: 120 km/h (65 kts) MTOW Range: 1,592 km (860 NM) 10,000 ft, 45 min. reserve Endurance: 6.2 hrs (10,000 ft, 45 min. reserve) Service ceiling: 7,620 m (25,000 ft) Rate of climb: 12.29 m/s (2,420 ft /min) Take-off: 548 m / 1,800 ft Landing: 499 m / 1,640 ft Fuel Consumption: 268 kg/h / 591 lb/h (10,000 ft) * |
