![]() https://en.wikipedia.org/wiki/Sukhoi_Su-57 The Sukhoi Su-57 (Russian: ????? ??-57) is the designation intended for a stealth, single-seat, twin-engine jet multirole fighter aircraft designed for air superiority and attack operations. The aircraft is the product of the PAK FA , a fifth-generation fighter programme of the Russian Air Force. Sukhoi's internal name for the aircraft is T-50. The Su-57 will be thefirst aircraft in Russian military service to use stealth technology. The fighter is planned to have supercruise, stealth, supermaneuverability and advanced avionics to overcome the prior generation fighter aircraft as well as ground and maritime defences. The fighter is intended to succeed the MiG-29 and Su-27 in the Russian Air Force and serve as the basis for the Fifth Generation Fighter Aircraft (FGFA) being co-developed by Sukhoi and Hindustan Aeronautics Limited (HAL) for the Indian Air Force. The prototype first flew on 29 January 2010 and deliveries of production aircraft to the Russian Air Force are to begin in 2018. The prototypes and initial production batch are to be delivered with a highly upgraded variant of the AL-31F used by the Su-27 family as interim engines while a new clean-sheet design power-plant is currently under development. The aircraft is expected to have a service life of up to 35 years. The Su-57 will be a fifth generation multirole fighter aircraft and the first operational stealth aircraft for the Russian Air Force. Although most information is classified, sources within the Sukhoi company and Defense Ministry have openly stated that the aircraft is to be stealthy, supermaneuverable, have supercruise capability, incorporate substantial amounts of composite materials, and possess advanced avionics such as active phased array radar and sensor fusion. The Su-57 has a blended wing body fuselage and incorporates all-moving horizontal and vertical stabilizers; the vertical stabilizers toe inwards to serve as the aircraft's airbrake. The aircraft incorporates thrust vectoring and has adjustable leading edge vortex controllers (LEVCONs) designed to control vortices generated by the leading edge root extensions, and can provide trim and improve high angle of attack behaviour, including a quick stall recovery if the thrust vectoring system fails. The advanced flight control system and thrust vectoring nozzles make the aircraft departure resistant and highly maneuverable in both pitch and yaw, enabling the aircraft to perform very high angles of attack maneuvers such as the Pugachev's Cobra and the Bell maneuver, along with doing flat rotations with little altitude loss. The aircraft's high cruising speed and normal operating altitude is also expected to give it a significant kinematic advantage over prior generations of aircraft. Role Stealth air superiority fighter National origin Russia Manufacturer Sukhoi First flight 29 January 2010 Introduction 2019 (planned) Status Final flight testing/pre-production Primary users Russian Air Force Russian Navy Produced 2009–present Number built 9 flyable prototypes Program cost US$8–10 billion (est.) Unit cost T-50: US$50 million Variants Sukhoi/HAL FGFA In December 2014, the Russian Air Force planned to receive 55 fighters by 2020. Yuri Borisov, Russia's deputy minister of defence for armaments stated in 2015 that the Air Force will slow production and reduce its initial order to 12 fighters and retain large fleets of fourth-generation fighters due to the nation's economy. Russian Air Force Commander-in-Chief Viktor Bondarev, stated that the fighter is to enter serial production in 2017, after all trials are completed. In 2017, Russian deputy defence minister Yuri Borisov stated that the Su-57 will most likely enter service in 2018, due to implementation of more advanced engines, and further testing. He also stated that it will be part of new 2018-2025 state armament programme. Actual number of aircraft to be delivered is yet unknown. Specifications (T-50) General characteristics Crew: 1 Length: 19.8 m (65 ft) Wingspan: 13.95 m (45 ft 10 in) Height: 4.74 m (15 ft 7 in) Wing area: 78.8 m² (848.1 ft²) Empty weight: 18,000 kg (39,680 lb) Loaded weight: 25,000 kg (55,115 lb) typical mission weight, 29,270 kg (64,530 lb) at full load Max. takeoff weight: 35,000 kg (77,160 lb) Fuel capacity: 10,300 kg (22,700 lb) Powerplant: 2 × Saturn AL-41F1 for initial production, izdeliye 30 for later production turbofans Dry thrust: 93.1 kN / 108 kN for supercruise (21,000 lbf / 24,300 lbf for supercruise) each Thrust with afterburner: 147 kN / 178 kN (33,067 lbf / 40,016 lbf) each Performance Maximum speed: At altitude: Mach 2 (2,140 km/h; 1,320 mph) Supercruise: Mach 1.6 (1,700 km/h; 1,060 mph) Range: 3,500 km (2,175 mi; 1,890 nmi) subsonic 1,500 km (930 mi; 810 nmi) supersonic Service ceiling: 20,000 m (65,000 ft) Wing loading: 317–444 kg/m² (65–91 lb/ft²) Thrust/weight: AL-41F1: 1.02 (1.19 at typical mission weight) izdeliye 30: 1.16 (1.36 at typical mission weight) Maximum g-load: +9 g Armament Guns: 1 × 30 mm Gryazev-Shipunov GSh-301 autocannon in right LEVCON root Hardpoints: 12 hardpoints (6 × internal, 6 × external) and provisions to carry combinations of: Missiles: Air-to-air missiles: 4 × RVV-MD 2 × R-73 Air-to-surface missiles: 4 × Kh-38ME Anti-ship missiles: 2 × Kh-35E Anti-radiation missiles: 4 × Kh-58UShKE Avionics Sh121 multifunctional integrated radio electronic system (MIRES) Byelka radar N036-1-01: Frontal X-band active electronically scanned array (AESA) radar N036B-1-01: Cheek X-band AESA radars for increased angular coverage N036L-1-01: Slat L-band arrays for IFF L402 Himalayas electronic countermeasure suite 101KS Atoll electro-optical targeting system 101KS-O: Laser Directional Infrared Counter Measures 101KS-V: Infra-red search and track 101KS-U: Ultraviolet missile approach warning system 101KS-N: Targeting pod * |
Sukhoi Su-34 pics 2 [2/7] - Sukhoi Su-34 cockpit 064288.jpg (1/1) | Miloch | Aviation Photos | 0 | May 26th 17 02:56 PM |
Sukhoi Su-25 pics [18/20] - sukhoi-su-25-cockpit_pics81-8124.jpg (1/1) | Miloch | Aviation Photos | 0 | July 23rd 16 03:46 PM |
Sukhoi Su-25 pics [17/20] - sukhoi-su25-frogfoot_7.jpg (1/1) | Miloch | Aviation Photos | 0 | July 23rd 16 03:46 PM |
Sukhoi Su-25 pics [16/20] - sukhoi-su25-frogfoot_4.jpg (1/1) | Miloch | Aviation Photos | 0 | July 23rd 16 03:46 PM |
Sukhoi Su-25 pics [15/20] - sukhoi-su25-frogfoot.jpg (1/1) | Miloch | Aviation Photos | 0 | July 23rd 16 03:46 PM |
