Azusalite wheels
Old July 9th 04, 12:19 AM
Fred the Red Shirt
Default Azusalite wheels
The Aircraft SPruce Catalog lists Azusalite nylon wheels for
landing gear and also brake kits for the same wheels. However
there is no illustartion fo the brake kits or of the brakes or
wheels after assembly and installation fo the brakes. The parts
list for the brake kits mentions linings, but does not mention
drums or discs.
I haven't found any more complete information on the Web either so
I remain curious, how (and how well) do these brakes work? Given
the low price, I don't expect much for something priced competatively
with bicylce wheels and brakes, but I haven;t a clue as to what the
Azusas actually are, other than inexpensive.
So, does anyone who has seen these care to comment?
FF
Old July 9th 04, 01:51 AM
@net.(reversed).mts
drums or discs.
http://www.tracyobrien.com/moreinfo.asp?id=46
I love my Tracy O'Brian's. Beautifully made and powerful as hell.
They're all you need for azulalite rims.
Jason Marshall
Challenger-II C-IEFQ
Old July 9th 04, 02:28 AM
George A. Graham
You can order a set, then send them back if you don't want them.
Only cost the freight charges.
Those wheels are made for very light airplanes, perhaps ultra-light.
George Graham
RX-7 Powered Graham-EZ, N4449E
Homepage http://bfn.org/~ca266
Old July 9th 04, 07:12 AM
Fred the Red Shirt
"George A. Graham" wrote in message ...
I have in mind using them on a Sky Pup Ultralight, originally
designed to use bicycle wheels w/o brakes. There is no question
that they'd be adequate, what I don't know is if they would be
heavier or harder to install than bicycle disc brakes. After
watching someone struggling to taxi a Sky Pup with neither brakes
nor a stearable tailwheel I concluded that at least one or the
other was a real good idea.
Brakes would probably be no harder to install, would be near the
CG so as tonot affect ballance, and add less parasitic drag compared
to a steerablr tailwheel. A castoring but non-steerable tailwheel
looks to be a non-winner too. Makes the Pup into a nice weather
vane.
I'd kinda like to know SOMETHING about what I'm ordering. The
AS catalog doesn't even say if they are mechanical or hydraulic.
I can call Aircraft Spruce or Azusa and ask, just thought I'd ask
here first for indpendant info.
I'd be ****ed to have to pay even shipping, for an item I returned
because the vendor's description was inadequate.
Thanks, and thanks also to Jason Marshall for the heads up on
Tracy O'Brien brakes.
FF
Old July 9th 04, 02:22 PM
Daniel
Fred the Red Shirt wrote ...
I have in mind using them on a Sky Pup Ultralight, ...
I'd kinda like to know SOMETHING about what I'm ordering. ...
Azusa makes band brakes, drum brakes & disc brakes. All have been
adapted to a variety of wheels, including the TuffWheels called for on
the Sky Pup. The band brake would be plenty sufficient for taxing &
parking. Brakes for stopping a rollout would be rather pointless on a
Sky Pup given the extremely short distance involved. To see what
you're ordering, check:
http://www.azusaeng.com/brakes/brkmain.html
Daniel
Old July 10th 04, 05:09 AM
Ryan Young
Two things about these wheels:
* They have terrible UV resistance.
* They are MUCH smaller in diameter than the bicycle wheels the
airplane is designed around. This will substanially reduce your
ground clearance, and put the wing incidence much lower as well,
meaning you'll need more elevator to get off the ground.
I think Steve Kiblinger has done some work on mounting brakes on
"bicycle" wheels on his Legal Eagle ultralight. There, I've just
given you enough to do your own Google search. ;-)
Azusa drum brakes generally need a fair amount of tune-up before they
work worth a damn. The shoes generally don't fit the drums very well.
Gluing sandpaper inside the drums and dragging the brakes for a while
generally set things to right after you tear out the sandpaper, and
blow out the brake lining dust.
Me, I'd stick with the bike wheels.
Old July 10th 04, 01:36 PM
Blueskies
http://www.azusaeng.com/wheels/whls6n.html
Dan D.
http://www.ameritech.net/users/ddevillers/start.html
"Fred the Red Shirt" wrote in message om...
drums or discs.
FF
500 x5 Wheels, Tires and Brakes HankL Home Built 0 February 26th 04 01:13 PM
WTB: Pair 500x5 Tires, Wheels, Brakes Spar Home Built 0 February 16th 04 10:13 PM
Opinions on Azusa aluminum wheels/brakes/axles? RTW Home Built 2 July 17th 03 04:19 PM
