https://en.wikipedia.org/wiki/Pietenpol_Air_Camper
The Pietenpol Air Camper is a simple parasol wing homebuilt aircraft designed by Bernard H. Pietenpol. The first prototype that became the Air Camper was built and flown by Pietenpol in 1928. The Air Camper was designed to be built of spruce and plywood. One of Pietenpol's goals was to create a plane that was affordable and easy to construct for home builders. Building an Air Camper requires basic woodworking skills and tools. Builders also need to fabricate some metal fittings to attach the wooden parts together. Some welding is required. The plans for the Pietenpol Aircamper were originally published in a four-part serial in the "Flying and Glider" Manual of 1932-33. The original model was flown using an Ace four cylinder water-cooled engine. The Model A Ford engine later became the standard powerplant used; the design was first flown with one in May 1929. In the 1960s Bernard Pietenpol began to favor converted engines from Chevrolet Corvair automobiles. The Corvair engine was smoother, stronger and significantly lighter in weight compared to the Model A, as the Corvair automobiles used air-cooled, flat-six configuration engines, similar in design to those already available (in generally larger displacements) for general aviation use. The length of a Pietenpol varies with the engine choices, as engines that are lighter than the Fords need to be mounted further out from the firewall for weight and balance reasons. Over the years over 30 different engines have flown in the Pietenpol Air Camper. Many modern Pietenpol builders prefer Continental A65, C85 or C90 air-cooled flat four powerplants. Several examples of the Aircamper have been built in Europe and are currently (2012) flying. In the 1920s and 1930s kits were available for the design, but there were none available again until 2015 when the Pietenpol Aircraft Company introduced a kit version of the Air Camper, with components supplied by Aircraft Spruce & Specialty. The kit includes all parts except the engine, aircraft dope and the aircraft fabric covering, and hardware. Role Amateur-built airplane Manufacturer Pietenpol Designer Bernie Pietenpol First flight 1928 with Model A engine, May 1929 Status Plans available (2015) Unit cost US$100 (plans only, 2015) Variants Grega GN-1 Aircamper Pietenpol Sky Scout St Croix Pietenpol Aerial St Croix Pietenpol Aircamper Variants Pietenpol Sky Scout BH Pietenpol also designed and published plans for a single-seat version of the aircraft named the Pietenpol Sky Scout, which was slightly smaller and was powered by the Ford Model T engine. During the late 1920s and early 1930s, this was less expensive than the Model A used in the Air Camper. UK LAA-approved Pietenpol Air Camper In some countries, civil aviation authority approval is required for each experimental aircraft design, in addition to the approval of each aircraft an individual makes, as in the US. A variant of the Pietenpol Air Camper was designed by Mr. J. K. Wills, and UK Light Aircraft Association approval was obtained for this variant. Grega GN-1 Aircamper Grega GN-1 AircamperA plans-only homebuilt design similar to the Air Camper using a Piper Cub wing. St Croix Pietenpol Aerial A biplane adaptation, designed by Chad and Charles Willie and produced by St Croix Aircraft of Corning, Iowa, first flown in 1977. St Croix Pietenpol Aircamper An adaptation of the original design with more wingspan, longer fuselage and higher gross weight. Specifications (Typical Air Camper) General characteristics Crew: One pilot Capacity: One passenger Length: 17 ft 8 in (5.39 m) Wingspan: 29 ft 0 in (8.84 m) Height: 6 ft 6 in (1.98 m) Wing area: 135 ft² (12.5 m²) Empty weight: 610 lb (277 kg) Loaded weight: 995 lb (452 kg) Max. takeoff weight: 1080 lb (490 kg) Powerplant: 1 × Ford Model A automotive conversion engine, 40 hp (30 kW) Performance Maximum speed: 86 knots (100 mph, 160 km/h) Stall speed: 30 knots (35 mph, 56 km/h) Rate of climb: 500 ft/min (152 m/min) Wing loading: 7 lb/ft² (36 kg/m²) * |
I bet Sam's not a happy camper now | [email protected] | Piloting | 0 | April 12th 16 04:19 PM |
For sale or trade: 35% complete Pietenpol Air Camper + extras | [email protected] | Home Built | 0 | March 20th 06 06:51 PM |
Flying RV/Camper | William M | Owning | 15 | October 25th 04 04:30 AM |
Bernard Pietenpol cub w/ Corvair | Robert Loer | Home Built | 1 | August 24th 04 02:49 PM |
pietenpol near Columbus Oh | James Nichols | Home Built | 2 | November 17th 03 10:30 PM |
