Duster plans wanted
Old May 15th 04, 04:06 AM
Leon McAtee
Default Duster plans wanted
I'd like to buy a set of plans for a Duster BJ-1b. These need not be
original and can be a copy as they will not be used to build a glider,
only for documentation for an existing Duster that came with no plans.
Leon McAtee
Leon@Alluretech dot net
N 7852R Original plans #38
Old May 15th 04, 04:21 PM
G.A. Seguin
Hi Leon,
I have a set.
I have resisted answering request for Duster plan up to now.
The sailplane built from these plan broke in flight, succesfull
bail out. The plan were never updated. One such event in a life
time is enough. It is up to you Leon, I will decide from the answer
you give to this post.
Gilles
(Leon McAtee) wrote in message . com...
Leon McAtee
Old May 15th 04, 04:49 PM
JJ Sinclair
Gilles, Could you give us more details on this? The rudder and fin were
redesigned after an in-flight break-up. Was that you?
I have built 2 Dusters and flown them for over 400 hours. I consider it a safe
design, after the change to the fin and rudder. As with any home-built, the
quality of construction may not have been up to aircraft standards and in many
cases the builder doesn't follow the designers instructions. More information,
please.
JJ Sinclair
I have a set.
Gilles
JJ Sinclair
Old May 15th 04, 10:40 PM
JJ Sinclair
It was this aircraft, I was not the pilot.
I consider the Duster a safe aircraft.
I question putting these plan, not updated,
back in circulation.
Gilles
Thanks, Gilles
I can provide the modification information that was issued after the rudder
flutter accident. The requester has a completed Duster, he only wants the plans
for reference.
JJ Sinclair
Old May 28th 04, 08:25 PM
Leon McAtee
Still looking for Duster plans. I purchased a set but after getting
them I discovered they are very old photocopies - and about 80% scale.
This would have been good enough for most inspection and confirming
conformity to the plans. Unfortunatly I will need to do some repair
and some of the information needed (rudder foil shape for example)
needs to be full size. So............
I'm still in the market for a set of original Duster plans, or an
acurate, modern digital copy.
Leon McAtee
Leon @ alluretech.net
(JJ Sinclair) wrote in message ...
Gilles
Thanks, Gilles
for reference.
JJ Sinclair
Old May 16th 04, 02:32 PM
JJ Sinclair
I'd like to make sure this particular one is at least built
per plans. The more information I can get the better my final
decisions will be - I hope.
The modified Duster has a fabric covered rudder with a counterbalance on top.
The forward fin attachment is also strengthened.
JJ Sinclair
WANTED: T40A Plans Marty Hammersmith Home Built 3 August 6th 10 07:50 PM
PBY blisters or plans wanted Tsahi Ben-Ami Restoration 0 June 13th 04 02:15 AM
Fly Baby Plans Sets Wanted Ron Wanttaja Home Built 0 June 9th 04 07:18 AM
Plans wanted Rick Pellicciotti Home Built 1 January 7th 04 09:29 PM
Wanted - Long EZ and Q2 plans 1engineer Home Built 41 August 26th 03 06:31 PM
