You are in: BGA Website Info for Clubs & Members Technical News
NewsAirworthiness DirectivesInspections & ModificationsAMP ManualFeesDatasheetsContactsLinks Technical News Latest news K7 & K10 Owners: Grounding Notice 27th May 2004 Schleicher K7 all serial numbers and variants Schleicher K10 Conversions, all serial numbers and variants This just in from the BGA web site. If you fly either of these aircraft you should be interested. Robert Mudd Due to an in-flight wing structural failure, as a precautionary measure, the BGA have decided to ground all Schleicher K7 and converted K10 gliders, with immediate effect. The accident investigation is in the initial stages and it is not known at this stage if the structural failure was the result of a mechanical defect or operation outside the approved flight envelope. |
Earlier, Robertmudd1u wrote:
K7 & K10 Owners: Grounding Notice 27th May 2004 Link: http://www.gliding.co.uk/bgainfo/technical/news.htm Bob K. http://www.hpaircraft.com/hp-24 |
Antenna ground plane and coax grounding | G. Fred McCutchen | Home Built | 2 | August 8th 04 12:27 PM |
Antenna Ground Plane Grounding | Fastglasair | Home Built | 1 | July 8th 03 05:21 PM |
