https://en.wikipedia.org/wiki/Douglas_A-20_Havoc
The Douglas A-20 Havoc (company designation DB-7) is an United States attack, light bomber, intruder and reconnaissance aircraft of World War II. It served with several Allied air forces, principally the United States Army Air Forces (USAAF), the Soviet Air Forces (VVS), Soviet Naval Aviation (AVMF), and the Royal Air Force (RAF) of the United Kingdom. Soviet units received more than one in three (2,908 aircraft) of the DB-7s ultimately built. It was also used by the air forces of Australia, South Africa, France, and the Netherlands during the war, and by Brazil afterwards. In British Commonwealth air forces, bomber/attack variants of the DB-7 were usually known by the service name Boston, while night fighter and intruder variants were usually known as Havoc. An exception to this was the Royal Australian Air Force, which referred to all variants of the DB-7 by the name Boston. The USAAF referred to night fighter variants as P-70. In March 1937, a design team headed by Donald Douglas, Jack Northrop, and Ed Heinemann produced a proposal for a light bomber powered by a pair of 450 hp (336 kW) Pratt & Whitney R-985 Wasp Junior radial engines mounted on a shoulder wing. It was estimated that it could carry a 1,000 lb (454 kg) bomb load at 250 mph (400 km/h). Reports of aircraft performance from the Spanish Civil War indicated that this design would be seriously underpowered, and it was subsequently cancelled. Later the same year, the United States Army Air Corps (USAAC) issued its own specification for an attack aircraft. The Douglas team, now headed by Heinemann, took the Model 7A design, upgraded with 1,100 hp (820 kW) Pratt & Whitney R-1830 Twin Wasp engines, and submitted the design as the Model 7B. It faced competition from the North American NA-40, Stearman X-100, and Martin 167F. The Model 7B was maneuverable and fast, but did not attract any US orders. The model attracted the attention of a French Purchasing Commission visiting the United States seeking aircraft for the modernization of the Armee de l'Air in the wake of the Munich Crisis. The French discreetly participated in the flight trials, so as not to attract criticism from American isolationists. The Air Corps, which controlled the aircraft's development, but had been excluded from negotiations between the French, the Production Division, and the Navy's Bureau of Aeronautics, was directed by the White House on 19 January 1939 to release the DB-7 for assessment in contradiction of its own regulations. The "secret" was revealed when the Model 7B crashed on 23 January while demonstrating single-engine performance. The French were still impressed enough to order 100 production aircraft, with the order increased to 270 when the war began. Sixteen of those had been ordered by Belgium for its Aviation Militaire. Although not the fastest or longest-range aircraft in its class, the Douglas DB-7 series distinguished itself as a tough, dependable combat aircraft with an excelente reputation for speed and maneuverability. In a report to the British Aeroplane and Armament Experimental Establishment (AAEE) at RAF Boscombe Down, test pilots summed it up as: "has no vices and is very easy to take off and land .... The aeroplane represents a definite advantage in the design of flying controls ... extremely pleasant to fly and manoeuvre." Ex-pilots often consider it their favorite aircraft of the war due to the ability to toss it around like a fighter. The Douglas bomber/night fighter was found to be extremely adaptable and found a role in every combat theater of the war, and excelled as a true "pilot's aeroplane". Role Light bomber Manufacturer Douglas Aircraft Company Designer Ed Heinemann First flight 23 January 1939 Introduction 10 January 1941 Retired (USAF) 1949 Status Retired Primary users United States Army Air Forces Soviet Air Force Royal Air Force French Air Force Produced 1939–1944 Number built 7,478 Developed into Douglas DC-5 In 1940, the US military's indifference to the type was overcome by improvements made for the French and British Commonwealth air forces. The USAAC was impressed enough by the A-20A's high power to weight ratio and easy handling characteristics. Two variants were ordered, in a tranche of more than 200 aircraft: the A-20 for high-altitude daylight bombing and the A-20A for low- and medium-altitude missions. It was intended that the high-altitude variant would be fitted with turbosupercharged Wright R-2600-7 engines; after a prototype suffered technical problems, the USAAC changed its order and an initial shipment of 123 A-20As (with less-powerful R-2600-3 engines) and 20 A-20s (R-2600-11) entered service in early 1941. A further 59 aircraft from this first order were received as P-70 night fighters, with two-stage supercharged R-2600-11 engines. The A-20B, another high-altitude bomber variant – lacking heavy armor and self-sealing fuel tanks – received a significant order from the USAAC: 999 aircraft (although two-thirds of these were exported to the USSR). With the lessons of the Pacific in mind USAAF ordered A-20G in June 1942. Specifications (A-20G-20-DO) General characteristics Crew: 3 Length: 47 ft 11?1/7/8 in (14.63 m) Wingspan: 61 ft 4 in (18.69 m) Height: 17 ft 7 in (5.36 m) Wing area: 464 ft² (43.1 m²) Empty weight: 16693 lb (7708 kg) Loaded weight: 24127 lb (10964 kg) Powerplant: 2 × Wright R-2600-23 "Twin Cyclone" radial engines, 1,600 hp (1,200 kW) each Performance Maximum speed: 317 mph (276 kn, 510 km/h) at 10,700 ft (3,260 m) Cruise speed: 256 mph (223 kn, 412 km/h) Range: 945 mi (822 nmi, 1,521 km) (Combat range) Service ceiling: 23,700 ft (7,225 m) Climb to 10,000 ft (3,050 m): 8.8 min Armament Guns: 6× fixed forward firing 0.5 in (12.7 mm) Browning machine guns in the nose 2× 0.5 in (12.7 mm) Browning machine guns in dorsal turret 1x flexible 0.5 in (12.7 mm) Browning machine gun, mounted behind bomb bay Bombs: 4,000 lb (1,800 kg) * |
Douglas A-20 Havoc pics [21/21] - Douglas-Boston-Havoc-plans-AAM-Nov-1970-L.gif (1/1) | Miloch | Aviation Photos | 0 | July 8th 16 01:46 AM |
Douglas A-20 Havoc pics [05/21] - A Douglas A-20H Havoc with experimental tracked main landing gear.jpg (1/1) | Miloch | Aviation Photos | 0 | July 8th 16 01:46 AM |
Douglas A-20 Havoc pics [21/21] - Pictures of an Aircraft A-20 Havoc.jpg (1/1) | Miloch | Aviation Photos | 0 | June 14th 16 12:45 AM |
Douglas A-20 Havoc pics [08/21] - Douglas A-20 Havoc Cockpit.jpg (1/1) | Miloch | Aviation Photos | 0 | June 14th 16 12:45 AM |
Douglas A-20 Havoc pics [05/21] - Douglas A-20 Havoc 2.jpg (1/1) | Miloch | Aviation Photos | 0 | June 14th 16 12:45 AM |
