Air Mass (Blue dot) on Butterfly
Old February 2nd 18, 03:54 AM posted to rec.aviation.soaring
Jonathan St. Cloud
Default Air Mass (Blue dot) on Butterfly
Just wondering if the users Air-avionics Butterfly, find the air mass measurement helpful (Blue dot)? Do you find this measurement more accurate and less susceptible to gusts? this data v the vario data? Are you using this data instead of the vario derived Netto?
Old February 2nd 18, 06:52 AM posted to rec.aviation.soaring
jfitch
I do. It is different than the baro data, and requires interpretation. I set it for an 80% inertial component, at 100% I find it too twitchy to use. It will often lead the baro by a useful amount (about 1 sec) and in gusty conditions can give you more information about vertical vs. horizontal gusts. I can use it to thermal with the prop boom up, the baro vario is fairly useless for that. I'll use it in bumpy or gusty thermals try to get more information about the structure.
Old February 2nd 18, 07:14 AM posted to rec.aviation.soaring
krasw
I use inertial almost exclusively while gliding (80-85% VAM). Nothing beats blazing under cloud at 100 kts and seeing that you fly trough steady 4.5 kt thermal while variometer needles are all over the place.
During thermalling I find traditional variometer still useful as you cannot totally ignore horizontal gusts and windshear, which TE vario shows.
Old February 2nd 18, 01:27 PM posted to rec.aviation.soaring
JS[_5_]
I use the Air-Glide audio for most of the flight, but don't look at the the blue dot enough to comment. What's used the most on the display are wind (excellent) and TAS in cruise (important). Believe the VAM mix is somewhere around 60%.
For the gusts Krasw mentions, it seems that if its late in the day and thermals are broken, I'll switch audio to the ClearNav running on 100% electronic TE. But perhaps that's just trying to blame something else for me being tired/rubbish/etc.
Old February 3rd 18, 12:57 PM posted to rec.aviation.soaring
krasw
I use inertial almost exclusively while gliding (80-85% VAM). Nothing beats blazing under cloud at 100 kts and seeing that you fly trough steady 4..5 kt thermal while variometer needles are all over the place.
I used to have Glide S with good TE probe, but I'm now installing it to next glider using static ports/electronic compensation, mainly to experiment what happens. I have had good experience with electronic compensation on every glider that has used it. It tells you same thing as TE probe, difference is just mathematics (if static/TE probes are ok).
Old February 6th 18, 10:52 AM posted to rec.aviation.soaring
I did the same tests last year in my LS8. It did not work. As per Air Avionics advice, electronic compensation with the Air Glide S only makes sense with multi-pressure probes (static / pitot from the same probe). My tests confirmed that - electronic compensation was simply not possible with any of the three fuselage static sources.
However, the vario works very well when connected to a TE-probe together with a Winter mechanic vario. This as long as the T-piece in the TE line is located about 2m away from both instruments. With this setup, there was no difference in the AirGlide vario readings with the Winter connected or removed from the TE line.
Old February 6th 18, 12:00 PM posted to rec.aviation.soaring
Andrzej Kobus
This is highly depended on a glider type. For some gliders it works well and for others it does not. I have it installed in ASH-31 Mi and it works well using fuselage static.
Old February 6th 18, 10:05 AM posted to rec.aviation.soaring
Fox Two[_2_]
I switched from the CAI to the AirGlide last year, and once I configured it the way I liked it, I've loved it. The blue dot is an excellent aid in determining whether a bump is horizontal or vertical; I am fooled much less often by horizontal gusts with the AirGlide. And once in a thermal, the blue dot leads the vario, so you can find the core faster.
But what's an even more important feature than the blue dot is the instantaneous wind data -- it's the most sophisticated wind measurement system available -- and this feature alone justifies the system's price.
With the blue dot showing you the vertical component of the airmass, and the instantaneous wind showing you the horizontal component, you'll get a much clearer image of what's going on around you. This is cool when looking for blue cloud streets, but it is vital when flying in the mountains below the peaks.
Chris
Old February 6th 18, 10:55 AM posted to rec.aviation.soaring
The blue dot is particularly useful in cruise. It gives a good indication of wether you get closer to a line of lift or a line of sink.
A & P in western Mass? orange Owning 1 September 27th 06 10:46 AM
Aircraft Seat Mass Edamsky General Aviation 1 March 7th 06 12:25 PM
Mass Production of Aircraft [email protected] Piloting 20 June 7th 05 07:11 PM
Weapons of Mass Destruction running with scissors Instrument Flight Rules 23 April 24th 04 02:00 PM
Budgets of Mass Destruction B2431 Military Aviation 4 February 4th 04 04:38 AM
