Metric aircraft countersunk machine screws
Old February 3rd 18, 08:51 PM posted to rec.aviation.soaring
Charles Longley
Default Metric aircraft countersunk machine screws
Does anyone have a source for metric aircraft countersunk machine screws? Similar to MS24693S28. They need to be aircraft hardware store screws have the wrong taper on them. This is for Blanik L-23 & L-33’s.
Old February 3rd 18, 09:54 PM posted to rec.aviation.soaring
AS
US-standard countersunk screws have a taper angle of 82degr. or 100 degr. vs. a metric screw having a 90degr. taper angle.
Is there a DIN or ISO standard specified by LET? If so, McMaster Carr carries them but I am not sure how an aircraft standard plays into that.
Uli
'AS'
Old February 3rd 18, 10:43 PM posted to rec.aviation.soaring
Tim Taylor
Last time we ordered some it was from Fastenal.
Old February 3rd 18, 11:36 PM posted to rec.aviation.soaring
Charles Longley
Well it’s not DIN 965. That’s pretty much what you find in a hardware store.
Old February 3rd 18, 11:52 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Find an L-13 that won't be brought back - buy it cheap - lots of good spares. Gear etc like the L-23...
Old February 4th 18, 12:43 AM posted to rec.aviation.soaring
AS
Could they be DIN 7991 or ISO 10642? These are hex-insert type and not Philips screws. Here is an online source for them in grade 10.9:
https://www.fullerfasteners.com/prod...ersunk-socket/
Uli
'AS'
Old February 4th 18, 02:52 AM posted to rec.aviation.soaring
Charles Longley
No they’re philips screw.
Old February 4th 18, 03:41 AM posted to rec.aviation.soaring
AS
Sorry - I should have been more clear: could you substitute the Philips type with the hex-insert type as per DIN 7991 / ISO 10642?
Uli
'AS'
Old February 4th 18, 12:05 PM posted to rec.aviation.soaring
'Aircraft Spruce and Specialty' has metric aircraft hardware
Old February 6th 18, 05:49 PM posted to rec.aviation.soaring
Bob Kuykendall
Link?
Fairey Long-range Monoplane pics 2 [4/9] - Like the first machine, it is fitted with a Napier Lion engine. Refinements have been added to this second machine, such as the spats over the undercarriage wheels.jpg (1/1) Miloch Aviation Photos 0 January 6th 18 04:31 PM
Blanik screws? Wade G Soaring 10 March 28th 16 03:03 AM
Metric Aircraft Hardware [email protected] Soaring 2 November 27th 07 06:23 AM
FAA Screws Up Again BushOKDemocratsSTUPID Instrument Flight Rules 2 March 22nd 06 10:39 PM
Metric Aircraft Nuts and Bolts John Scott Soaring 6 December 14th 05 08:54 PM
