https://en.wikipedia.org/wiki/Hawker_Siddeley_Trident
The Hawker Siddeley HS 121 Trident (originally the de Havilland D.H.121 and the Airco DH 121) was a British short- (and later medium-) range airliner. It was the first T-tail rear-engined three-engined jet airliner to be designed. It was also the first airliner to make a blind landing in revenue service in 1965. The Trident emerged in response to a call by the state-owned British European Airways Corporation (BEA) for a jet airliner for its premier West European routes. BEA had been induced by the government to issue this call despite its unwillingness to buy a large jet fleet. The airline's requirements fluctuated greatly in the 1950s and a decade later evolved radically away from what the Trident could offer. Adherence to BEA's changing specification was widely seen as limiting the Trident's appeal to other airlines and delaying its service entry. During its gestation, the Trident was also involved in a government drive to rationalise the British aircraft industry. The resulting corporate moves and government interventions contributed to delays causing it to enter service two months after its major competitor, the Boeing 727, losing further potential sales as a result. By the end of the programme in 1978, 117 Tridents had been produced. BEA's successor British Airways withdrew its Tridents by the mid-1980s. Trident services ended in China in the early 1990s. The Trident was a jet airliner of all-metal construction with a T-tail and a low-mounted wing with a quarter-chord sweepback of 35 degrees. It had three rear-mounted engines: two in side-fuselage pods, and the third in the fuselage tailcone, aspirating through an S-shaped duct. One version, the 3B, had a fourth "boost" engine aspirated through a separate intake duct above the main S-duct. All versions were powered by versions of the Rolls-Royce Spey, while the boost engine was also by Rolls-Royce: the RB.162, originally intended as a lift engine for VTOL applications. The Trident was one of the fastest subsonic commercial airliners, regularly cruising at over 610 mph (980 km/h). At introduction into service its standard cruise Mach Number was 0.88/ 380 kn IAS, probably the highest of any of its contemporaries. Designed for high speed, with a critical Mach number of 0.93, the wing produced relatively limited lift at lower speeds. This, and the aircraft's low power-to-weight ratio, called for prolonged takeoff runs. Nevertheless, the Trident fulfilled BEA's 6,000 ft (1,800 m) field length criterion and its relatively staid airfield performance was deemed adequate before the arrival into service of the Boeing 727 and later jet airliners built to 4,500 ft (1,400 m) field length criteria. The aerodynamics and wing was developed by a team led by Richard Clarkson, who would later take the Trident's wing design for the wing of the Airbus A300; for the Trident he won the Mullard Award in 1969. Role Narrow-body jet airliner National origin United Kingdom Manufacturer Hawker Siddeley First flight 9 January 1962 Introduction 1 April 1964 Status Retired Primary users British European Airways British Airways CAAC Airlines Cyprus Airways Number built 117 Unit cost US$7.8M (1972) The Trident experienced some key export sales, particularly to China. Following a thawing of relations between Britain and the People's Republic of China, China completed several purchase deals and more than 35 Tridents were eventually sold. In 1977, fatigue cracks were discovered in the wings of the British Airways Trident fleet. The aircraft were ferried back to the manufacturer and repaired, then returned to service. On 1 January 1986, new ICAO noise legislation came into force, requiring operators of first- and second-generation jet airliners to have hush kits fitted to their engines; the main British operator of the type, British Airways, viewed the refit as unviable and instead they chose to phase the Trident out of their fleet. A total of 117 Tridents were produced, while the Boeing 727, built to the original specification for the Trident, sold 1,832 units. Variants Trident 1C Production version for British European Airways, 24 built Trident 1E Increased seating capacity uprated engines and addition of leading edge slats, 15 built Trident 2E As Trident 1E version with triplex autoland system, 50 built Trident 3B High-capacity short-medium range version of the 2E with a 16 ft 5 in (5.00 m) stretch, 1 RB.162 booster engine in the tail; 26 builtSuper Trident 3BExtended range by 692 km (430 miles), two built Specifications Trident 3B Cockpit Crew Three (Captain, First Officer and System Panel Operator) Seating Capacity (Typical) 180 Passengers Length 131 ft 2 in (39.98 m) Wingspan 98 ft (30 m) Wing Area 1,462 sq ft (135.8 m2) Overall Height 28 ft 3 in (8.61 m) Operating Empty Weight, typical 83,000 lb (38,000 kg) Maximum Takeoff Weight 150,000 lb (68,000 kg) Cruise Speed Mach 0.84 – 495 kn (570 mph; 917 km/h) at 30,000 ft (9,100 m) Range 2,235 mi (1,942 nmi; 3,597 km) Service Ceiling 35,000 ft (11,000 m) Powerplant 3 x Rolls Royce Spey RB163-25 Mk512-5 + 1 x Rolls-Royce RB162-86 Booster * |
Hawker Siddeley Harrier pics [15/21] - Hawker Siddeley Harrier.jpg (1/1) | Miloch | Aviation Photos | 0 | August 18th 16 06:51 AM |
Hawker Siddeley Harrier | Miloch | Aviation Photos | 0 | August 18th 16 06:48 AM |
Trimotors, pt 8 - Hawker Siddeley Trident.jpg (1/1) | Mitchell Holman[_3_] | Aviation Photos | 1 | August 5th 16 01:35 PM |
Hawker Siddley Trident 1c G-ARPO | tony jarrett | General Aviation | 2 | February 17th 11 06:06 PM |
Trimotors, pt 5 - Hawker Siddeley Trident.jpg (1/1) | Mitchell Holman | Aviation Photos | 0 | September 26th 07 12:55 PM |
