Trig TT21 + TN72 TABS ADS-B Out Install working great....
Old February 11th 18, 11:04 PM posted to rec.aviation.soaring
Darryl Ramm
Default Trig TT21 + TN72 TABS ADS-B Out Install working great....
I just helped set up the Ramy Yanetz ASG29's TRIG TT21 transponder with a TN72 GPS Source to use as a TABS ADS-B out system. That along with PowerFLARM in his glider makes for a pretty capable overall traffic awareness/collision avoidance system.
Here is a screenshot of my portable Stratux ADS-B receiver (as would be used in many GA aircraft) receiving the ADS-B signal from the TT21 over 20 nautical miles away. Yes, it's a wave day out at Williams.
https://drive.google.com/file/d/1Kik...SlslyEyMPo62Mu
And again just an reminder, the TN72 is a ~$350 (+ GPS antenna + install costs) GPS Source that can easily be added to any Trig transponder to deliver ADS-B Out in your glider. (If you need full 2020 Compliant ADS-B Out it's a little more involved). This is low-enough cost that it will likely be a "just do it" choice for owners who already have a Trig transponder, and who especially want to provide more visibility to GA traffic (and it makes your glider visible to PowerFLARM buddies at much longer distances).
Old February 11th 18, 11:13 PM posted to rec.aviation.soaring
Please expand on make/model antennae used and where it is located on G29.
Old February 11th 18, 11:52 PM posted to rec.aviation.soaring
Darryl Ramm
Most Trig glider dealers should be able to provide an antenna and either it will have a QMA antenna on it or they will install one for you and cut the GPS antenna cable to your length spec. I know Richard at Craggy Aero can do that for you.... he had one in his hand waving it at me when I last saw him :-) Give him a call.
There is nothing special about the GPS antenna mounting location, or really the GPS antenna itself... but the dealers have been checking out specific antennas. You install it in the same location as you would a GPS antenna for your flight computer.
Please don't use the silly TA70 wall wart antenna. That is TSO-ed-silliness on a stick, just not something suitable for a glider, and seems pretty contrary to the original easy adoption intent of TABS/TSO-C199. TRIG is aware of this, the TA70 came from earlier STCs for 2020 Compliant ADS-B Out installs.
Old February 12th 18, 01:57 AM posted to rec.aviation.soaring
Too many antenna. 4 GPS and 2 FLARM within 30". We need a reliable way to split/share GPS signal off a single antennae.
Old February 12th 18, 02:20 AM posted to rec.aviation.soaring
Richard Pfiffner[_2_]
http://www.craggyaero.com/antennas.htm
Bottom Page
Richard
www.craggyaero.com
Old February 12th 18, 02:58 AM posted to rec.aviation.soaring
Jonathan St. Cloud
Great, now if we could get something like that for GPS. I have 3 GPS's now without ADS-B in out or sideways. Flarm, LX and Butterfly.
Bottom Page
Richard
www.craggyaero.com
Old February 12th 18, 03:07 AM posted to rec.aviation.soaring
George Haeh
So we're looking at:
$350 TN72
$321 GPS Antenna Combiner & cables for Flarm + GPS vario
$671 Total before shipping.
There's just barely enough room under my glareshield for 2 GPS antennae 30"
apart. Without the combiner I'd have to wire the third antenna to my hat.
I'm still entertaining the fantasy of mounting an L2 transponder antenna in
tail battery box of my 27 - and routing a fat enough coax there. I dread
thought of dirtying my 27 with an external transponder antenna.
Old February 12th 18, 02:44 AM posted to rec.aviation.soaring
Darryl Ramm
You can do a lot to merge GPS antennas you already have. Personally I would not be doibg that for a GPS source used to drive any type of ADS-B Out.
Old February 12th 18, 12:01 AM posted to rec.aviation.soaring
son_of_flubber
So Ramy is using the PowerFlarm for ADS-B In? What display? Is it linked to a moving map? Any significant limitations to that configuration?
Old February 12th 18, 12:35 AM posted to rec.aviation.soaring
Dan Marotta
My ClearNav II displays ADS-B In targets generated by my PowerFlarm
portable unit.
A question for Darryl (or a general whine):Â* My Stemme is exempt from
the ADS-B requirement as a glider but, since it's a certificated
aircraft, I probably can't use the TN-72 GPS with my TT22 transponder.Â*
Is there any chance of such a system being installed in a certificated
glider?
Dan
Dan, 5J
Trig TN72 Antenna Andrew Ainslie Soaring 17 April 6th 17 04:21 AM
Trig TT21 for sale [email protected] Soaring 2 April 15th 16 06:35 PM
Trig TT21 transponder for sale Dave Springford Soaring 15 September 7th 12 11:05 PM
Trig TT21 transponder draws only 125 mA! Steve Koerner Soaring 5 March 15th 10 09:59 PM
TRIG TT21 Transponders Tim Mara[_2_] Soaring 12 September 26th 09 02:01 AM
