https://en.wikipedia.org/wiki/Cessna_182_Skylane
The Cessna 182 Skylane is an American four-seat, single-engined light airplane, built by Cessna of Wichita, Kansas. It has the option of adding two child seats, installed in the baggage area. Introduced in 1956, the 182 has been produced in a number of variants, including a version with retractable landing gear, and is the second most popular Cessna model, after the 172. The Cessna 182 was introduced in 1956 as a tricycle gear variant of the 180. In 1957, the 182A variant was introduced along with the name Skylane. As production continued, later models were improved regularly with features such as a wider fuselage, swept tailfin with rear "omni-vision" window, enlarged baggage compartment, higher gross weights, landing gear changes, etc. The "restart" aircraft built after 1996 were different in many other details including a different engine, new seating design, etc. By mid-2013 Cessna planned to introduce the next model of the 182T, the JT-A, using the 227 hp (169 kW) SMA SR305-230 diesel engine running on Jet-A with a burn rate of 11 U.S. gallons (42 L; 9.2 imp gal) per hour and cruise at 155 kn (287 km/h). Cessna has no timeline for the JT-A and the diesel 172. The normally aspirated, avgas fueled 182 went out of production in 2012, but came back in 2015. The Cessna 182 is an all-metal (mostly aluminum alloy) aircraft, although some parts – such as engine cowling nosebowl and wingtips – are made of fiberglass or thermoplastic material. Its wing has the same platform as the smaller Cessna 172 and the larger 205/206 series; however, some wing details such as flap and aileron design are the same as the 172 and are not like the 205/206 components. Role Light utility aircraft National origin United States Manufacturer Cessna Aircraft Company Introduction 1956 Status In production Produced 1956–1985 1996–2012 2015–present Number built over 23,237 Unit cost US$480,000 (182T, 2017) The retractable gear R182 and TR182 were offered from 1978 to 1986, without and with engine turbocharging respectively. The model designation nomenclature differs from some other Cessna models with optional retractable gear. For instance the retractable version of the Cessna 172 was designated as the 172RG, whereas the retractable gear version of the Cessna 182 is the R182. Cessna gave the R182 the marketing name of "Skylane RG". The R182 and TR182 offer 10-15% improvement in climb and cruise speeds over their fixed gear counterparts or, alternatively, 10-15% better fuel economy at the same speeds at the expense of increased maintenance costs and decreased gear robustness. The 1978 R182 has a sea level climb rate of 1140 fpm and cruising speed (75% BHP) at 7,500 feet (2,300 m) of 156 KTAS at standard temperature. Specifications (Cessna 182T) General characteristics Crew: one Capacity: three passengers Length: 29 ft 0 in (8.84 m) Wingspan: 36 ft 0 in (11.0 m) Height: 9 ft 4 in (2.8 m) Wing area: 174 sq ft (16.2 m²) Airfoil: NACA 2412 Aspect ratio: 7.47 Empty weight: 1,970 lb (894 kg) Useful load: 1,140 lb (517 kg) Max. takeoff weight: 3,100 lb (1406 kg) Powerplant: 1 × Lycoming IO-540-AB1A5 3-bladed constant speed, 230 hp (172 kW) Performance Never exceed speed: 175 knots (201 mph, 324 km/h) Maximum speed: 150 knots (173 mph, 278 km/h) Cruise speed: 145 knots (167 mph, 269 km/h) Stall speed: 49 knots (56 mph, 91 km/h) Range: 930 nmi (1,070 mi, 1,722 km) Service ceiling: 18,100 ft (5,517 m) Rate of climb: 924 ft/min (4.7 m/s) Wing loading: 17.8 lb/sq ft (87 kg/m²) Power/mass: 0.074 hp/lb (122 W/kg) |
Over NYC 2 - Cessna Skylane.jpg (1/1) | Mitchell Holman[_8_] | Aviation Photos | 0 | January 6th 15 01:08 PM |
CESSNA 182 SUPER SKYLANE for sale (?!) | Jürgen Schmidt | Owning | 0 | December 18th 05 09:20 PM |
Cessna Skylane Wheel Pants on EBAY | UTAH | Aviation Marketplace | 0 | February 25th 04 02:25 AM |
Cessna 182 Skylane Gear Strut Fairings | SAC | Aviation Marketplace | 0 | November 14th 03 11:36 PM |
