Prandtl multi probe receptacle used for TE only?
Old February 14th 18, 11:03 PM posted to rec.aviation.soaring
Matt Herron Jr.
Default Prandtl multi probe receptacle used for TE only?
I have a Prandtl type receptacle in the fin of my ASW27. The previous owner converted to to TE probe only, by tying off the static and pitot lines behind the panel. Anything wrong with this set-up? I guess there would be more potential for leaks, at a minimum. will the extra volume of air connected in the unused tubes create any adverse effects on the TE line? I get my static from the ports on the boom about 2/3 back.
Thanks for any input.
Matt
Old February 14th 18, 11:44 PM posted to rec.aviation.soaring
Dave Nadler
Hi Matt!
You mean a 3-way probe, right?
The probe pitot and static are better than fuselage ports (though pitot
is easily wiped out by a bug). If your instrumentation is working OK with
fuselage ports, why mess with it?
Nope.
No, they are not connected in any way.
See ya, Dave
Old February 14th 18, 11:57 PM posted to rec.aviation.soaring
JS[_5_]
On Wednesday, February 14, 2018 at 3:44:59 PM UTC-8, Dave Nadler wrote:
Hi Matt!
Nope.
See ya, Dave
The three circuits are not supposed to be connected, but if there is a bad O-ring, all bets are off.
In a perfect world, your system as plumbed will work fine. If the mod was done due to crosstalk, and there is a leak in the plugged static or pitot lines, it will be erratic.
After the lines were disconnected and plugged, there's a chance nobody has leak checked them.
They're a pain to replace. I have a spare fitting for ASW27/28/29 at home, hope to never need it. Fortunately my leak was found to be two things, a bad probe and a hidden connector in the back of the panel, which Rex found instead of replacing the fitting.
Old February 15th 18, 01:24 AM posted to rec.aviation.soaring
Matt Herron Jr.
Hi Matt!
Nope.
See ya, Dave
I agree in normal use the three lines are not connected. However, if you just insert a TE probe into the multipart receptacle then all three ports share the same flow because the TE probe doesn't go deep enough and is not stepped like the Prandtl probe.
Old February 15th 18, 02:00 AM posted to rec.aviation.soaring
Dave Nadler
Yup, IMHO a huge design blunder to put the O-rings in the socket
instead of on the probe. I once asked SH how to replace the O-rings,
and they said they have absolutely no idea ;-(
Old February 15th 18, 07:39 AM posted to rec.aviation.soaring
How to change the internal O-rings is all explained in the service section of the ESA Systems web page. That's not to say it is easy - or even possible in the case of ring 3 without removing the socket which means cutting open the fin.
Old February 15th 18, 08:36 AM posted to rec.aviation.soaring
The probes and sockets are produced by esa-systems in Berlin. There's an instruction on how to replace the O-rings on their website: https://www.esa-systems.com/en/suppo...i-change-them/
Old February 15th 18, 01:29 PM posted to rec.aviation.soaring
Now tell me again...
Why aren't the O rings on the probe?
Must be an oversupply of engineers needing to design something like this O ring insertion tool.
Old February 15th 18, 02:12 PM posted to rec.aviation.soaring
krasw
torstai 15. helmikuuta 2018 1.03.47 UTC+2 Matt Herron Jr. kirjoitti:
Matt
Volume of triple pneumatic tube from tail to panel might be close to half of variometer flask volume, so answer is "maybe" even in theoretical world. But there is too many variables in pitot-static system to give you systematic answer.
Prandtl Flying Wing Testing by NASA [email protected] Soaring 2 March 24th 16 06:55 PM
military spec receptacle MIL-C-24368/2 [email protected] Naval Aviation 0 June 30th 08 05:53 PM
Multi - probe KP Soaring 1 March 7th 05 06:03 PM
Discus Prandtl tube Serge Serfaty Soaring 5 October 6th 04 08:48 AM
