looking for some instrument debugging help.
I have a steam gauge ASI (winter) and an LxNav S80 sharing the same Pitot and static lines. In the air, the two gauges read ASI differently. The S80 reads about 10 knots higher than the Winter at 70 knots, and 5 knots higher at 40 knots. The error seems to scale with higher airspeeds Back on the ground we used a syringe to pressurize the pitot line. Both instruments read within 2 knots of each other for the full speed range. they also held steady at the desired airspeed with the syringe, indicating no leaks in the Pitot system. Back in the air, I tried opening and closing the vent, scooping air into the cockpit to pressurize it, etc. Neither instrument changed its reading, but the offset in speeds remained. Ideas? Leak in Static? Matt |
On Wednesday, February 14, 2018 at 8:38:38 PM UTC-5, Matt Herron Jr. wrote:
looking for some instrument debugging help. I have a steam gauge ASI (winter) and an LxNav S80 sharing the same Pitot and static lines. First, check your static for leaks. Second, check the instruments against a 3rd reference. See if they are consistent (doesn't matter if the 3rd unit is off as long as its consistent). Hope that helps, Best Regards, Dave PS: Once had a customer return an instrument TWICE because he insisted his Winter ASI was correct -- and of course when he finally checked it was way off. Winter 2 1/4" ASIs are notorious (and why a back-seater once said "gee, if I do this in Condor the wings come off"). PPS: I have a Chinese ASI in the shop that is WILDLY off, but great for leak-checks... |
Are they connected to the same pitot and static sources? Some gliders use a triple probe in the tail for the soaring flight computer and vario and the pitot in the nose and statics on the fuselage for the airspeed and altimeter.
Also, make sure the S80 is set to display airspeed in knots, not mph. Best Regards, Paul Remde _________________________ On Wednesday, February 14, 2018 at 7:38:38 PM UTC-6, Matt Herron Jr. wrote: looking for some instrument debugging help. I have a steam gauge ASI (winter) and an LxNav S80 sharing the same Pitot and static lines. In the air, the two gauges read ASI differently. The S80 reads about 10 knots higher than the Winter at 70 knots, and 5 knots higher at 40 knots. The error seems to scale with higher airspeeds Back on the ground we used a syringe to pressurize the pitot line. Both instruments read within 2 knots of each other for the full speed range. they also held steady at the desired airspeed with the syringe, indicating no leaks in the Pitot system. Back in the air, I tried opening and closing the vent, scooping air into the cockpit to pressurize it, etc. Neither instrument changed its reading, but the offset in speeds remained. Ideas? Leak in Static? Matt |
On Wednesday, February 14, 2018 at 6:39:45 PM UTC-8, Paul Remde wrote:
Are they connected to the same pitot and static sources? Some gliders use a triple probe in the tail for the soaring flight computer and vario and the pitot in the nose and statics on the fuselage for the airspeed and altimeter. Also, make sure the S80 is set to display airspeed in knots, not mph. Best Regards, Paul Remde _________________________ On Wednesday, February 14, 2018 at 7:38:38 PM UTC-6, Matt Herron Jr. wrote: looking for some instrument debugging help. I have a steam gauge ASI (winter) and an LxNav S80 sharing the same Pitot and static lines. In the air, the two gauges read ASI differently. The S80 reads about 10 knots higher than the Winter at 70 knots, and 5 knots higher at 40 knots. The error seems to scale with higher airspeeds Back on the ground we used a syringe to pressurize the pitot line. Both instruments read within 2 knots of each other for the full speed range. they also held steady at the desired airspeed with the syringe, indicating no leaks in the Pitot system. Back in the air, I tried opening and closing the vent, scooping air into the cockpit to pressurize it, etc. Neither instrument changed its reading, but the offset in speeds remained. Ideas? Leak in Static? Matt yes, they are connected to the same pitot and static sources. That's what is so weird about this |
Paul's units suggestion would fit:
40knots = about 46mph. 70knots = 80mph. |
looking for some instrument debugging help. I have a steam gauge ASI (winter) and an LxNav S80 sharing the same Pitot and static lines. In the air, the two gauges read ASI differently. The S80 reads about 10 knots higher than the Winter at 70 knots, and 5 knots higher at 40 knots. The error seems to scale with higher airspeeds Back on the ground we used a syringe to pressurize the pitot line. Both instruments read within 2 knots of each other for the full speed range. they also held steady at the desired airspeed with the syringe, indicating no leaks in the Pitot system. Back in the air, I tried opening and closing the vent, scooping air into the cockpit to pressurize it, etc. Neither instrument changed its reading, but the offset in speeds remained. Ideas? Leak in Static? Matt Hi Matt: I experienced the same problem when I received my S100 early last year. Uros sent me the following solution which autozeros the pressure sensors. His suggestions completely solved the problem for me. Best regards Doug XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX Hello, please check under setup-vario, that you have airspeed offset set to 0. Please enter password 01043, to make autozero on pressure sensors. Best regards, Uros XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX |
On Wednesday, February 14, 2018 at 10:27:22 PM UTC-8, Doug C wrote:
On Wednesday, February 14, 2018 at 8:38:38 PM UTC-5, Matt Herron Jr. wrote: looking for some instrument debugging help. I have a steam gauge ASI (winter) and an LxNav S80 sharing the same Pitot and static lines. In the air, the two gauges read ASI differently. The S80 reads about 10 knots higher than the Winter at 70 knots, and 5 knots higher at 40 knots. The error seems to scale with higher airspeeds Back on the ground we used a syringe to pressurize the pitot line. Both instruments read within 2 knots of each other for the full speed range. they also held steady at the desired airspeed with the syringe, indicating no leaks in the Pitot system. Back in the air, I tried opening and closing the vent, scooping air into the cockpit to pressurize it, etc. Neither instrument changed its reading, but the offset in speeds remained. Ideas? Leak in Static? Matt Hi Matt: I experienced the same problem when I received my S100 early last year. Uros sent me the following solution which autozeros the pressure sensors. His suggestions completely solved the problem for me. Best regards Doug XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX Hello, please check under setup-vario, that you have airspeed offset set to 0. Please enter password 01043, to make autozero on pressure sensors. Best regards, Uros XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX Thanks Doug, I will give that a try. As far as units go, both instruments indicate knots. Matt |
| LXNAV V7 - Reviews? | David Reitter | Soaring | 10 | October 21st 14 01:41 AM |
| New vario by LXNAV | [email protected] | Soaring | 6 | May 23rd 13 12:15 AM |
| LXNAV V7 | Paul Remde | Soaring | 2 | November 2nd 11 01:31 AM |
| Compression readings | [email protected] | Owning | 18 | December 15th 04 10:38 PM |
| Different WAAS altitude readings | Wyatt Emmerich | Instrument Flight Rules | 21 | June 29th 04 08:27 PM |
