https://en.wikipedia.org/wiki/Fairey_Firefly
The Fairey Firefly was a British Second World War-era carrier-borne fighter aircraft and anti-submarine aircraft of the Fleet Air Arm (FAA). Designed to the contemporary FAA concept of a two-seat fleet reconnaissance/fighter, the pilot and navigator/weapons officer were housed in separate stations. It was superior in performance and firepower to its predecessor, the Fulmar, but entered operational service only towards the end of the war when it was no longer competitive as a fighter. The limitations of a single engine in a heavy airframe reduced its performance, but it proved to be sturdy, long-ranged, and docile in carrier operations. The Fairey Firefly served in the Second World War as a fleet fighter but in postwar service, although it was superseded by more modern jet aircraft, the Firefly was adapted for other roles, including strike operations and anti-submarine warfare, remaining a mainstay of the FAA until the mid-1950s. UK and Australian Fireflies flew ground attack operations off various aircraft carriers in the Korean War. In foreign service, the type was in operation with the naval air arms of Australia, Canada, India and the Netherlands whose Fireflies carried out a few attack sorties as late as 1962 in Dutch New Guinea. The Firefly was designed by H.E. Chaplin at Fairey Aviation; in June 1940, the Admiralty ordered 200 aircraft "off the drawing board" with the first three to be the prototypes. The prototype of the Firefly flew on 22 December 1941. Although it was 4,000 lb (1,810 kg) heavier than the Fulmar (largely due to its armament of two 20 mm Hispano cannon in each wing), the Firefly was 40 mph (60 km/h) faster due to improved aerodynamics and a more powerful engine, the 1,735 hp (1,294 kW) Rolls-Royce Griffon IIB. The Firefly was a low-wing cantilever monoplane with oval-section metal semi-monocoque fuselage and conventional tail unit with forward-placed tailplane. It was powered by a Rolls-Royce Griffon liquid-cooled piston engine with a three-blade airscrew. The Firefly had retractable main landing gear and tail wheel, with the hydraulically operated main landing gear retracting inwards into the underside of the wing centre-section. The aircraft also had a retractable arrester hook under the rear fuselage. The pilot's cockpit was over the leading edge of the wing and the observer/radio-operator/navigator aft of the wing trailing edge - positions which gave better visibility for operating and landing. Both crew had separate jettisonable canopies. The all-metal wing could be folded manually, with the wings ending up along the sides of the fuselage. When in the flying position, the wings were hydraulically locked. Role Carrier fighter Manufacturer Fairey Aviation Company, Ltd. First flight 22 December 1941 Introduction 1943 Retired 1956 (Royal Navy) Primary users Royal Navy Royal Australian Navy Royal Canadian Navy Royal Netherlands Navy Produced 1941–1955 Number built 1,702 The primary variant of the aircraft used during the Second World War was the Mk I, which was used in all theatres of operation. In March 1943, the first Firefly Mk Is were delivered but they did not enter operational service until July 1944 when they equipped 1770 Naval Air Squadron aboard HMS Indefatigable. The first operations were in Europe where Fireflies carried out armed reconnaissance flights and anti-shipping strikes along the Norwegian coast. Fireflies also provided air cover during strikes on the German battleship Tirpitz in 1944. Throughout its operational career, the Firefly took on increasingly demanding roles from fighter to anti-submarine warfare stationed mainly with the British Pacific Fleet in the Far East and Pacific theatres. Fireflies carried out attacks on oil refineries and airfields and gained renown when they became the first British-designed and -built aircraft to overfly Tokyo. After the Second World War, the Firefly remained in front line service with the Fleet Air Arm until the mid-1950s. The UK also supplied the aircraft to Canada, Australia, Denmark, Ethiopia, the Netherlands Naval Aviation Service, India and Thailand. The Royal Canadian Navy employed 65 Fireflies of the Mk AS 5 type onboard its own aircraft carriers between 1946 and 1954. It also had some Mk I Fireflies, and sold several additional examples of these to Ethiopia in the early 1950s. British and Australian Fireflies carried out anti-shipping patrols and ground strikes off various aircraft carriers in the Korean War as well as serving in the ground-attack role in the Malayan Emergency. The Firefly's FAA front line career ended with the introduction of the Gannet. Several versions of the type were developed later in its career to serve as trainers, target tugs and drone aircraft. As an example, the Indian Navy acquired 10 aircraft in the mid-50s for target tug purposes. Specifications (Mk I) General characteristics Crew: Two (pilot & observer) Length: 37 ft 7¼ in (11.46 m) Wingspan: 44 ft 6 in (13.57 m) Height: 13 ft 7 in (4.14 m) Wing area: 328 ft² (30.5 m²) Empty weight: 9,750 lb (4,432 kg) Loaded weight: 14,020 lb (6,373 kg) Powerplant: 1 × Rolls-Royce Griffon IIB liquid-cooled V12 engine, 1,730 hp (1,290 kW) Performance Maximum speed: 316 mph (275 kn, 509 km/h) at 14,000 ft (4,300 m) Range: 1,300 mi (1,130 nmi, 2,090 km) Service ceiling: 28,000 ft (8,530 m) Climb to 10,000 ft (3,050 m): 5 min 45 sec Armament Guns: 4 × 20 mm Hispano-Suiza HS.404 cannons Rockets: 8 × RP-3 "60 lb" rockets Bombs: 2 × 1,000 lb (454 kg) bombs under wings * |
UK1 Z2118 Fairey Firefly Mk4.jpg | Joseph Testagrose | Aviation Photos | 0 | November 26th 12 01:13 PM |
UK1 Z2118 Fairey Firefly Mk4 1.jpg | Joseph Testagrose | Aviation Photos | 0 | November 26th 12 01:13 PM |
UK2 WB406 Fairey Firefly.jpg | Joseph Testagrose | Aviation Photos | 0 | August 16th 12 07:50 AM |
UK2 MB387 Fairey Firefly to SE-BRH.jpg | Joseph Testagrose | Aviation Photos | 0 | December 24th 11 11:23 AM |
UK2 DK568 Fairey Firefly to SE-BRA.jpg | Joseph Testagrose | Aviation Photos | 0 | August 26th 11 12:47 AM |
