Turnpoint descriptions
Old June 24th 04, 05:58 PM
Tuno
Default Turnpoint descriptions
While working recently on a Java program to combine and geographically
filter turnpoints from multiple .CUP files, I noted that when I use SeeYou
to convert from .CUP to .DA4 (for Filser/LX Nav products) format, the
turnpoint names get truncated to 8 characters and all uppercase. This
presents name collisions for pairs of turnpoints with verbose names like
"Black Canyon North" and "Black Canyon South" -- both get saved with the
name "BLACK CA", which causes LXe to complain when the file is loaded
therein.
Is there a "standard" somewhere for what data are contained in turnpoints
and how they are named? I know .DA4 files are used for LX Nav products; what
are .CUP files used for (besides SeeYou)?
thx/2NO
Old June 24th 04, 10:56 PM
Martin Gregorie
On Thu, 24 Jun 2004 15:58:09 GMT, "Tuno"
therein.
Take a look at the standard BGA text file format and the excellent
TPSelect program. The BGA TP file is in a human readable format that's
independent of any particular hardware. TPSelect reads and displays
this file to allow you to optionally select turn points from it and
write them to another file in a format that suits your TP upload
program.
For example, use TPSelect to pick out the nearest 500 TPs to my home
base (my GPS won't hold more than that) and then save them to a file
that's acceptable to flexGPS. I use the latter to load the file into
my GPS.
IMO this approach has a lot of advantages:
- there's only one human-readable master file
- each program does a specific job and does it well
- using two programs is no big deal: its only done once a year
- there are a LOT of device-specific uploaders around
- the uploaders are easy to find via the Soaring Exchange
The only down side is that most of these programs are for MSDOS and/or
Windows, which is hard lines on Mac or Linux users.
martin@ : Martin Gregorie
gregorie : Harlow, UK
demon :
co : Zappa fan & glider pilot
uk :
Old June 25th 04, 02:20 AM
Tuno
Thanks Martin!
Which is precisely why my filter program is being developed in Java.
Old June 27th 04, 03:41 PM
Martin Gregorie
On Fri, 25 Jun 2004 00:20:33 GMT, "Tuno"
Thanks Martin!
I'll drink to that! :-)
What package/class hierarchy are you using to get serial port access
from Java?
I've looked at the usual suspects (Sun's SerialPort class and the open
source RXTX package) but both look to be somewhat orphaned and/or need
major system surgery to install so I'm doubtful if they're viable. The
SimpleSerial class isn't really portable without a lot of effort. OTOH
if I could find a socket library for the Borland C/C++ compiler I just
might have a portable solution. I have mostly complete code for
Linux...
demon :
uk :
Old June 25th 04, 03:39 AM
Paul Remde
Hi,
I suggest you take a look at some of the waypoint files on the Worldwide
Soaring Turnpoint Exchange by John Leibacher at:
http://acro.harvard.edu/SOARING/JL/TP
If I understand correctly, John uses perl scripts to create the waypoint
files from data sources. I've found that names are shortened very nicely.
If you asked him, I bet he'd share his method with you. I think the method
involves removing vowels (only when necessary) and using capitals for the
start of new words.
Good Luck,
Paul Remde
"Tuno" wrote in message
s.com...
therein.
what
thx/2NO
Old June 25th 04, 12:03 PM
Derrick Steed
Paul Remde wrote:
Hi,
http://acro.harvard.edu/SOARING/JL/TP http://acro.harvard.edu/SOARING/JL/TP
start of new words.
Good Luck,
Paul Remde
ws.com... ws.com...
therein.
what
thx/2NO
And Perl is highly portable between platforms - text manipulation is its forte, but it can equally well handle binary with ease with good format handling.
Rgds,
Derrick.
Filser LX20 turnpoint list Croft Brown Soaring 5 June 21st 04 02:14 PM
Wolrd Soaring Turnpoint Exchange down? Lars P. Hansen Soaring 2 June 21st 04 10:11 AM
Soaring Server - Worldwide Soaring Turnpoint Exchange John Leibacher Soaring 0 June 19th 04 05:57 PM
FAI turnpoint Question Mark Grubb Soaring 13 February 15th 04 03:31 AM
Ardoin Turnpoint in Marfa area? chris Soaring 3 December 29th 03 04:06 AM
