Instrument mounting question
Old July 18th 04, 10:07 PM
Rob Turk
Default Instrument mounting question
I'm looking for some guidance on safely mounting instruments in an alumimium
panel. Our panel is about 2mm (about 1/12th inch) thick. We had all the
shapes laser cut, so everything fits well.
What do most of you do with deep, heavy instruments like a gyro? Is it safe
to just use the screws on the front or do most of you add some form of
support at the back of the instrument to support the weight? If so, what
construction did you use?
Thanks,
Rob
Old July 19th 04, 12:57 AM
Rip
Look at the recommendations of the instrument manufacturer. Some require
rear support, some don't.
Thanks,
Rob
Old July 19th 04, 04:26 AM
Craig
"Rob Turk" wrote in message l.nl...
Most everything I've ever worked on was face mounted, and that
includes aerobatic competetion aircraft....
Craig C.
cvairwerks@ev1,net
Old July 19th 04, 07:51 PM
Joe Vasher
Thanks,
Rob
Hi Rob,
My suggestion is to face mount, mount the pannel using rubber mounts
(shock mounts) and choose your instruments accordling.
Old July 19th 04, 10:33 PM
Nathan Young
On Sun, 18 Jul 2004 23:07:39 +0200, "Rob Turk"
All 6 instruments + 2 OBS heads are face mounted in my Cherokee.
Instrument Question Dick Home Built 10 May 30th 04 12:05 AM
Aluminum instrument panel finish? Richard Riley Home Built 31 February 4th 04 02:09 AM
Question for Squirrel the Lurker jls Home Built 0 January 30th 04 02:41 PM
Tecumseh Engine Mounting Question jlauer Home Built 7 November 16th 03 01:51 AM
