Pawnee air-oil bear strut pressure
Old March 6th 18, 12:38 AM posted to rec.aviation.soaring
Larry Ruggiero
Default Pawnee air-oil bear strut pressure
Yes I know they’re problematic. Just returned our PA 25-235 from its annual, where one of ours was rebuilt (locked solid) and both serviced. Like I assume many of yours are, our Pawnee has no hopper and will never see gross weight again. So should the air side of the struts still be 575psi per the book? Noticed neither strut budged a bit during taxi and it landed pretty stiff. Plus the gear is now spread wide compared to “normal.” Called our IA and got a virtual shoulder shrug. Thoughts?
Larry Ruggiero, pilot/A&P
Carolina Soaring
Old March 6th 18, 02:37 AM posted to rec.aviation.soaring
Charles Longley
OK I give up. What part are you talking about?
Charlie
Pilot/ A&P
Old March 6th 18, 02:41 AM posted to rec.aviation.soaring
Larry Ruggiero
Landing gear struts instead of bungees.
Old March 6th 18, 02:57 AM posted to rec.aviation.soaring
Charles Longley
Ahh who makes them? One of our Pawnees has bungees the other one has Cessna spring gear.
Old March 6th 18, 03:04 AM posted to rec.aviation.soaring
Charles Longley
Never mind I found them as an option from Piper. I have no advice other then follow the POH for troubleshooting. Maybe set the pressure towards the lower end of the spectrum.
Old March 9th 21, 01:24 PM posted to rec.aviation.soaring
Charlie
Pilot/ A&P
Larry, all you need to do is call Dan at Aerial Banners in Ft. Lauderdale, Florida. Dan is the most knowledgeable person around concerning Pawnee's, he operates about 60 of them and his rebuild shop is impressive. Tell him that I sent you, he will be the best contact available for Pawnee information.. Bob
Old March 11th 21, 01:58 AM posted to rec.aviation.soaring
Tony[_7_]
Charlie
Pilot/ A&P
Larry, all you need to do is call Dan at Aerial Banners in Ft. Lauderdale, Florida. Dan is the most knowledgeable person around concerning Pawnee's, he operates about 60 of them and his rebuild shop is impressive. Tell him that I sent you, he will be the best contact available for Pawnee information. Bob
Yes, but be sure ro speak with Dan - owner Bobby is a sociopath!
Old March 11th 21, 09:45 PM posted to rec.aviation.soaring
Charlie
Pilot/ A&P
And you are a bigger PSYCHO than Bobby
Old April 5th 21, 07:11 PM posted to rec.aviation.soaring
Larry Ruggiero
Charlie
Pilot/ A&P
Old April 5th 21, 07:23 PM posted to rec.aviation.soaring
Larry Ruggiero
Charlie
Pilot/ A&P
Thanks all. To close this out, I just finished overhauling its left strut with new O-rings and backup rings, and it’s fairly straightforward, although the fact that it’s now weeping 5606 out the bottom weep hole tells me that its days are numbered and we’ll probably convert to the hydrosorb/bungee struts after this season. Also the carb airbox wasn’t as worn as I thought and just needed new rubber bushings, which took awhile to get. Btw, the person referenced at Aerial Banners never returned my call.
Larry Ruggiero, A&P/IA
Carolina Soaring Association
To Pawnee or not to Pawnee...that is the question... Travis Beach Soaring 56 March 24th 14 06:21 AM
To Pawnee or not to Pawnee...that is the question... Travis Beach Soaring 4 October 17th 07 01:31 PM
Granville's Strut Seal - Or Other Strut Maintenance Techniques zatatime Owning 4 August 31st 05 04:30 PM
Cherokee Strut Lower Strut Seal Replacement Report Mike Spera Owning 3 July 23rd 05 07:07 PM
High Oil Pressure (was: Low oil pressure, high oil temp?) Thomas Ploch Owning 4 October 5th 04 04:34 AM
Copyright 2004-2025 AviationBanter.
