So I am putting a Batt relay on my plane and it is one that grounds out to
complete the circuit. Is it normal to have it get hot. Not to hot to touch but pretty hot. |
David wrote:
So I am putting a Batt relay on my plane and it is one that grounds out to complete the circuit. Is it normal to have it get hot. Not to hot to touch but pretty hot. Could be a 'starter' relay. That kind is intended for non-continuous duty. But hard to guess trying to feel the screen... Richard |
On Tue, 20 Jul 2004 03:24:07 GMT, Richard Lamb
wrote: David wrote: So I am putting a Batt relay on my plane and it is one that grounds out to complete the circuit. Is it normal to have it get hot. Not to hot to touch but pretty hot. Could be a 'starter' relay. That kind is intended for non-continuous duty. But hard to guess trying to feel the screen... Richard If I recall correctly and it's been about 15 years since I built the RV-6... The Master Relay actuates by grounding a lead. The Start Relay actuates by applying 12 DC positive to the relay. The Master is intended for continuous operation while the Start is only for intermittent operation. I don't recall the Master Relay getting hot but, then, I didn't ever attempt to touch it after the engine was operating... John Ammeter |
![]() "David" wrote: So I am putting a Batt relay on my plane and it is one that grounds out to complete the circuit. Is it normal to have it get hot. Not to hot to touch but pretty hot. ++++++++++++++++++++++++++++++++++++++++++++++++++ ++++ Other's have weighed in with concerns that you may wrongly be using a starter solenoid. They normally are grounded... and you supply it with battery voltage. OTOH... What you describe that requires grounding to function, sounds exactly like a bona fide batt relay and they do get quite warm.... but not so hot as to give your finger a blister. Barnyard BOb - |
Barnyard BOb - wrote:
"David" wrote: So I am putting a Batt relay on my plane and it is one that grounds out to complete the circuit. Is it normal to have it get hot. Not to hot to touch but pretty hot. ++++++++++++++++++++++++++++++++++++++++++++++++++ ++++ Other's have weighed in with concerns that you may wrongly be using a starter solenoid. They normally are grounded... and you supply it with battery voltage. OTOH... What you describe that requires grounding to function, sounds exactly like a bona fide batt relay and they do get quite warm.... but not so hot as to give your finger a blister. Barnyard BOb - Aw rats. I do believe BooB is right. Dam defective brain cells let me down again. Richard (or what's left of him) |
![]() "Barnyard BOb -" wrote in message ... "David" wrote: So I am putting a Batt relay on my plane and it is one that grounds out to complete the circuit. Is it normal to have it get hot. Not to hot to touch but pretty hot. ++++++++++++++++++++++++++++++++++++++++++++++++++ ++++ Other's (sic) have weighed in with concerns that you may wrongly be using a starter solenoid. They normally are grounded... and you supply it with battery voltage. For a relay to work, it is grounded. Matter of practicality. Otherwise how would you complete the circuit? OTOH... What you describe that requires grounding to function, sounds exactly like a bona fide batt relay and they do get quite warm.... but not so hot as to give your finger a blister. When you run current through a wire coil and complete a circuit, in this case an electromagnet contactor, a by-product is heat. Resistors make heat. Unavoidable. Barnyard BOb - |
Switching radios on 1 antenna | Nicholas J. Hirsch | Home Built | 16 | June 14th 04 01:49 PM |
Electrical Relay Help | Jeff | Home Built | 10 | August 29th 03 04:03 AM |
