https://en.wikipedia.org/wiki/Grumman_AF_Guardian
The Grumman AF Guardian was the first purpose-built anti-submarine warfare (ASW) carrier-based aircraft to enter service with the United States Navy. It consisted of two airframes, one for detection gear, the other for weapons. The Guardian remained in service until August 1955, when it was replaced by the twin-engined Grumman S-2 Tracker. The Guardian was the largest single-engine piston-powered carrier aircraft ever to see service. The original design concept for the aircraft that would become the Guardian, the XTB2F of 1944, was for a twin-engined aircraft with a 3,600 lb (1,600 kg) warload and a range of 3,700 mi (5,950 km). This was considered to be too large for practical use from an Essex-class aircraft carrier, and was cancelled in 1945, replaced by a modified Grumman F7F Tigercat, the XTSF-1. However, this too was considered impractical, and another alternative, the internally developed Grumman Model G-70, was selected instead, being given the Navy designation XTB3F-1. This was designed as mixed-power aircraft, with a Pratt & Whitney Double Wasp radial engine in the nose and a Westinghouse 19XB turbojet in the tail. Originally, the Westinghouse engine was to be the new X24C which was to emerge as the J34 series. When it became apparent the X24C delivery schedules would not meet the airframe schedule, the 19XB-2B was substituted. This was found to be unsuitable, and the jet engine was removed without ever having been used in flight. The XTB3F-1S carried a crew of two seated side-by-side and an armament of two 20 mm cannon and 4,000 lb (1,814 kg) of bombs, torpedoes and/or rockets, and made its first flight on 19 December 1945. On 24 December 1945, the Navy changed the role of the aircraft from torpedo-bomber to anti-submarine warfare. All the required equipment could not be fitted into a single aircraft, consequently two variants would be produced, one as a "guppy" (hunter) and another as a "scrapper" (killer). The hunter aircraft would not carry any armament, but instead two additional crew members and a ventral radome for APS-20 search "eyes" (radar) and Electronic Countermeasures (ECM) "ears", consisting of an APR-98 Countermeasures Receiver and AP-70 Bearing Indicator. This aircraft, the XTB3F-1S, first flew in November 1948. The "killer" deleted the cannon of the torpedo bomber, but retained the bomb bay, added a third crewmember, a searchlight, and short-range radar, and (as the XTB3F-2S) first flew in January 1949. Role Anti-submarine aircraft National origin United States Manufacturer Grumman First flight 19 December 1945 Introduction October 1950 Retired 31 August 1955 Status Replaced by S-2 Tracker Primary user United States Navy Number built 389 Redesignated as AF-2W (TB3F-1S) and AF-2S (TB3F-2S), the Guardian entered fleet service on 27 September 1950 with three aircraft delivered to VS-24, with full service introduction shortly after with VS-25. A total of 193 AF-2S Guardians were built. In 1952, the AF-3S (hunter) was introduced, fitting a magnetic anomaly detector (MAD) for the detection of submerged submarines; 40 of this variant were built. The last Guardian was delivered to the Navy in March 1953, with a total of 389 built. The Guardian saw service in the maritime patrol role during the Korean War, however it proved unpopular with pilots, being underpowered and heavy on the controls; the aircraft suffered from a severely high accident rate. Shortly after the end of the war, it began to be replaced by the Grumman S2F Tracker, the U.S. Navy first purpose-built ASW airplane to combine the hunter and killer roles in a single airframe. The last AF retired from active service on 31 August 1955, but it remained in service with the US Naval Air Reserve until 1957. Specifications (AF-2S Guardian) General characteristics Crew: three (four in AF-2W variant) Length: 43 ft 4 in (13.21 m) Wingspan: 60 ft 8 in (18.49 m) (about 25 ft-wings folded (7.62 m)) Height: 16 ft 2 in (5.08 m) Wing area: 560 ft² (52.03 m²) Empty weight: 14,580 lb (6,613 kg) Max. takeoff weight: 22,640 lb (10,270 kg) Powerplant: 1 × Pratt & Whitney R-2800-48W "Double Wasp" radial engine, 2,400 hp (1,790 kW) Performance Maximum speed: 253 mph at full throttle not to exceed 30 minutes at 15,000 ft, gross weight 21,000 pounds (276 kn, 510 km/h) Range: 1,500 mi (1,304 nmi, 2,415 km) Service ceiling: 15,000 ft (4600 m) Rate of climb: 1,850 ft/min (9.4 m/s) Armament Rockets: 6× 5 in (127 mm) unguided High velocity aircraft rocket (HVAR) rockets Bombs: 4,000 lb (1,814 kg) of bombs, torpedoes, and depth charges * |
Gate Guardian MiG-21F-13 01 | Ri©ardo | Aviation Photos | 0 | May 31st 15 11:30 AM |
Guardian - af-2s.jpg (1/1) [108K] | Netko | Aviation Photos | 2 | December 13th 09 04:00 PM |
AF Guardian | nice guy | Aviation Photos | 0 | August 9th 09 11:35 AM |
AF-2S Grumman Guardian 123100 VS-25 Contact Sheet | ac249 | Aviation Photos | 11 | December 26th 08 11:09 PM |
Ugly Airplanes, pt 5 - Grumman AF-2S Guardian.jpg (1/1) | Mitchell Holman | Aviation Photos | 0 | March 1st 08 12:44 PM |
