SLA batteries opinions?
Old April 2nd 18, 06:14 PM posted to rec.aviation.soaring
john firth
Default SLA batteries opinions?
Recently I tested two 12v SLA s which had been in use
sequentially for some years usually recharged before going
going flat, or at least within one day.
Both were run down to 10.5 v with a 10 ohm load and then recharged to 14v,
The Yuasa 7 AH bought 2005 was good for about 2.5 AH
the UB 1280 8AH 6 years old good for 2AH.
On this showing the Yuasa look like the better battery.
Both were used as panel supplies running at .5 A load.
Any opinions on competing SLA batteries?
John F
Old April 2nd 18, 08:10 PM posted to rec.aviation.soaring
krasw
maanantai 2. huhtikuuta 2018 20.14.19 UTC+3 john firth kirjoitti:
John F
Most (incl. Yuasa) specify battery life as 3-5 years. Glider use (deep cycles, low temps) means 3 years max in our experience. To get any amperage from 13 years old battery is nothing short of miracle.
Old April 2nd 18, 08:11 PM posted to rec.aviation.soaring
In your test, did you measure the AH capacity in the discharge or the recharge? The latter is of course generally an overestimate.
The Yuasa had to be really well made to last THAT long! Half the life at half the cost may be OK too though. 6 years is not bad.
The practical life of an SLA mostly depends on how it is treated, not the manufacturing quality. I've seen our club's batteries go dead in less than 2 years. I think that's in part due to sometimes being left in a glider that it tied out, where it gets quite hot. I left a spare battery in my glider trailer for one season, it was then dead, again perhaps due to heat. Other than keeping them cool (but not cold), make sure to fully charge right after use (within a day or two anyway), using a good "smart" charger that will not overcharge it.
Old April 2nd 18, 08:31 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
I do a fully charged - discharge - recharge cycle once a year on my
batteries (Yuasa NP7-12 SLAs) and sling them when they drop below 2/3 of
the capacity measured when they are new.
I use a cheapish multi-chemistry charger of the type sold for charging
and monitoring RC model batteries, so its good for round 0.4 amp charge
and discharge rates. Mine is a Pro-Peak Prodigy II sold in the UK by
Ripmax and is now several years old (12 at a guess). Similar charge/
discharge units will be available almost anywhere.
Martin | martin at
Gregorie | gregorie dot org
Old April 2nd 18, 09:29 PM posted to rec.aviation.soaring
Darryl Ramm
That test is unlikeky to tell you anythibg useful about the battery quality.. If anything it might tell you how they are stored/abused. And storage/use/abuse is likelyvthe thing to worry about with SLA batteries,... they often get killed more than dying of old age.
Buy a good brand name SLA battery from a trusted/high volume dealer so it hopefully has a fresh manufacturing date and should arrive with a decent charge on it. Fully charge and then discharge test and write that date and tested current/capacity on the battery and repeat at every annual. The West Mountain Radio Computerized Battery Tester is a great investment, especially for clubs, FBOs, A&Ps etc. . When capacity gets to about 80% of spec (not initial measured capacity, which is likely higher) I would replace.
You may be better off using LiFePO4 batteries.
Old April 3rd 18, 12:16 AM posted to rec.aviation.soaring
Well I've been wondering about that each time I buy a new SLA and still find that I cannot justify the much higher cost of the LiFePO4 batteries (5x to 10x, depending on size, brand, etc). The theoretical number of times the batteries of each type can be cycled is irrelevant if they will die of old age in a number of years, even if that's 10+ years for LiFePO4 and only 3-4 years for SLA in my use.
This depends also on how much capacity you need vs. the weight and volume needed to hold the battery(ies) in the glider. In my case my modest needs, in warm weather, are usually met by one 4AH SLA, and I can also use a 12AH when I want spare capacity (or a bit of ballast :-). If I had a fancier computer, plus transponder and FLARM, then the picture might be different, since the LiFePO4 can be discharged more deeply without damage while the SLA should only be taken to about half-full (and even when I test them I stop at about 11.5V).
Old April 3rd 18, 12:40 AM posted to rec.aviation.soaring
Darryl Ramm
I did say "may be better off". :-)
Old April 3rd 18, 06:59 AM posted to rec.aviation.soaring
2G
I am switching to Odyssey batteries that use thin pure lead plates (PC680). Virtually all other SLA batteries are made with recycled lead, which is not pure (they claim 99.9%, but I doubt that is realistic - Odyssey guarantees 99.99% pure). They are designed for long life and severe environments.
http://www.odysseybattery.com/design_advantages.aspx
They are rated for deep discharge.
That said, I have had good luck with the Panasonic batteries that I have used in my ASH26e for 4 years, and recommend them for people on a budget.
Tom
Old April 3rd 18, 03:29 PM posted to rec.aviation.soaring
Dan Marotta
I really liked seeing "ASH26e" and "budget" in the same sentence! :-D
Tom
Dan, 5J
Old April 3rd 18, 06:47 AM posted to rec.aviation.soaring
krasw
tiistai 3. huhtikuuta 2018 2.16.45 UTC+3 kirjoitti:
In my experience lifetime of LFP is not better than SLA. My first battery died completely in 6 months, second had much reduced capacity after 2 seasons. Idea that chinese LFPs last thousand cycles or decade is just false.
LiFePO4 batteries JS Soaring 26 October 15th 12 02:51 PM
Batteries Included Mitchell Holman Aviation Photos 0 September 21st 08 12:33 AM
AGM Batteries Dave Anderer Owning 13 March 29th 08 07:38 PM
2-Batteries [email protected] Soaring 69 January 4th 07 04:09 AM
160 new batteries Mal Soaring 0 October 27th 06 11:36 AM
