Diameter of thermals
Old April 3rd 18, 10:34 PM posted to rec.aviation.soaring
Waveguru
Default Diameter of thermals
Some days the thermals are big, and some days they are very small in diameter and it doesn’t seem to have anything to do with their strength or height. Do any of you know what determines their size? It seems that on the days they are small, they stay small all day, and vise versa.
Boggs
Old April 4th 18, 03:07 PM posted to rec.aviation.soaring
Emir Sherbi
Boggs
Generally, when you take out all the other individual factors, is the atmospheric pressure
Old April 4th 18, 03:11 PM posted to rec.aviation.soaring
Per Carlin
Please explain that, is it a theory for size of the thermal as a function of pressure. Is it pressure at MSL or QFE that is relevant, or the pressure where you are at the moment when you catch the thermal?
Old April 4th 18, 03:31 PM posted to rec.aviation.soaring
Emir Sherbi
The thermal goes up because there is a difference in the densities of the thermal and the air surrounding it. The air density depends mostly on humidity, temperature and pressure. With more pressure, the same quantity (mass) of air have less volume. That is in the assumption that the radiation of the sun gives the same energy to the same mass of air.
Old April 4th 18, 03:13 PM posted to rec.aviation.soaring
Some days they are triagular shaped. Some know kung fu.
Its really the core size, thermals down low tend to have multiple small cores, which join together into larger smoother cores as the thermal gets higher.
Old April 4th 18, 10:59 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
gets higher.
.... and then stops when it hits the inversion.
Martin | martin at
Gregorie | gregorie dot org
Old April 8th 18, 06:28 AM posted to rec.aviation.soaring
Bruce Hoult
Boggs
In what way?
In any given location and altitude, atmospheric pressure seldom varies by more than 3% from the average. Thermal sizes vary a lot more than that day to day.
Old April 5th 18, 12:10 AM posted to rec.aviation.soaring
Duster[_2_]
Assuming with his experience that he's quite aware of how thermals are generated, I'm not sure if we're addressing Mr. Guru's question about thermal diameter. Here's some references that address this issue on a more scientific basis (search "diameter" for each article if you don't want to wade thru).. Aside from those factors mentioned that affect density, thermal diameter will increase with height like an expanding baloon as the relative pressure decreases. Don't forget about the effect of inertia by all that upward-moving mass. Where's our Dr. Wx?
http://trace.tennessee.edu/cgi/viewc...t=utk_gradthes
https://www.jstage.jst.go.jp/article.../54_6_427/_pdf
http://www.expandingknowledge.com/Je...Myths/Main.htm
https://rmets.onlinelibrary.wiley.co...1256/qj.03.180
file:///C:/Users/Michael/Downloads/1819-7038-1-PB.pdf
Now, how about a discussion on what causes sink surrounding lift on a blue day?
Boggs
Old April 5th 18, 01:52 AM posted to rec.aviation.soaring
Tom BravoMike
On Wednesday, April 4, 2018 at 6:10:35 PM UTC-5, Duster wrote:
Assuming with his experience that he's quite aware of how thermals are generated, I'm not sure if we're addressing Mr. Guru's question about thermal diameter. Here's some references that address this issue on a more scientific basis (search "diameter" for each article if you don't want to wade thru). Aside from those factors mentioned that affect density, thermal diameter will increase with height like an expanding baloon as the relative pressure decreases. Don't forget about the effect of inertia by all that upward-moving mass. Where's our Dr. Wx?
I like the dedication in this (linked above) Master of Science thesis 'An Empirical Model of Thermal Updrafts Using Data Obtained From a Manned Glider":
"I would like to dedicate this thesis to my wonderful wife and children for putting up with my hectic schedule and allowing me to take the necessary time away from family time to finish this work".
I can imagine many glider pilots now willing to write a master or doctor thesis based on an empirical experience. In some cases it may take them years and years to gather the needed empirical material... :-)))
Old April 5th 18, 02:03 AM posted to rec.aviation.soaring
And if you can secure funding for the project, think of all the joyous hours of soaring to be had on someone else's money.
Formula for diameter of a circle [email protected] Soaring 3 February 5th 13 04:00 PM
Jantar 3 Axle Diameter? sisu1a Soaring 5 December 15th 08 03:06 AM
? Screw head diameter? Michael Horowitz Home Built 14 January 1st 07 11:05 PM
T-6/SNJ Propeller Diameter Orval Fairbairn Restoration 5 January 1st 05 03:10 AM
Pitch and Diameter of 3 blade prop for IO-360 200HP Bart D. Hull Home Built 1 December 11th 03 11:42 PM
