Does any have, or could anyone take a picture of the port side of of the main wheel on a Standard Jantar 41A? I’m having a heck of a time figuring out the trick to get it back together and adjusted correctly.
Thanks! |
Lots of luck, it's a nightmare involving 2 clutch type plates that are moved together when brakes are requested. I could never get anything better than minimal braking.........recommend changing over to a Tost assembly or a hydraulic retrofit.
JJ |
On Thursday, April 12, 2018 at 8:02:37 AM UTC-7, wrote:
Does any have, or could anyone take a picture of the port side of of the main wheel on a Standard Jantar 41A? I’m having a heck of a time figuring out the trick to get it back together and adjusted correctly. Thanks! If it's the same wheel/brake as a 48-3 or a 59 then I can take some pics of the one I have, though it's no longer on the ship. That thing was simple enough assemble but I never found an adjustment point strong enough for the brakes to actually work without grabbing while not engaged. It's a neat idea how it works in general but a poor design as applied and probably inappropriate on a sailplane. The wheel is allowed to 'float' on the axle to allow both clutch/brake plate things to engage equally even though it's actuated from one side. This also means if you do a taxi turn after landing but still able to keep the tail off the ground the brake can grab from the side load, with potential for a tail slam. The only effective adjustment I made was to convert to a 5.00x5 Clevelend hydraulic. The biggest part of the job was the fork. Had to cut off the lugs that trap the brake plates to remain stationary, as well as machining a flange for the caliper and having it welded it on. Also needed an axle spacer/adapter and a bracket/lever for the master cylinder. Uses the same brake lever in the cockpit... except now it actually works. If there's a Tost kit for it that's probably easier and way better than the stock contraption, but iirc that wheel was smaller and I didn't want to lose ground clearance. I have drawings of the parts that were made and specs for what was bought if you wanted to go that route. |
On Thursday, April 12, 2018 at 11:36:50 AM UTC-7, sisu1a wrote:
On Thursday, April 12, 2018 at 8:02:37 AM UTC-7, wrote: Does any have, or could anyone take a picture of the port side of of the main wheel on a Standard Jantar 41A? I’m having a heck of a time figuring out the trick to get it back together and adjusted correctly. Thanks! If it's the same wheel/brake as a 48-3 or a 59 then I can take some pics of the one I have, though it's no longer on the ship. That thing was simple enough assemble but I never found an adjustment point strong enough for the brakes to actually work without grabbing while not engaged. It's a neat idea how it works in general but a poor design as applied and probably inappropriate on a sailplane. The wheel is allowed to 'float' on the axle to allow both clutch/brake plate things to engage equally even though it's actuated from one side. This also means if you do a taxi turn after landing but still able to keep the tail off the ground the brake can grab from the side load, with potential for a tail slam. Yes - an undocumented feature of the Jantar brake! A sharp turn, including a half-ground-loop caused by a wing-tip snagging high grass, actuates the brake quite sharply. You may end up with some gravel rash on the nose, but it may save you a broken boom. I did this experiment on a Jantar-1! Mike |
How about fixing the wheel so that it doesn't travel on the axle? Only one shoe would apply pressure, maybe not enough to raise the tail...good compromise?
Better yet - a split washer or spring either side of the wheel. Sized right so that shoe disc can compress it as well, but would prevent wheel from binding without brake application. Experimental a/w certificate allows such experimentation...
On Thursday, March 14, 2019 at 5:54:42 PM UTC-7, wrote:
...Experimental a/w certificate allows such experimentation... If it's experimental, I can put a Matco hydraulic disk brake unit in for you. Very effective yet progressive braking action. It will put the glider on its nose, but only if you want. --Bob K. |
SZD 48-1 Standard Jantar 2 placards | [email protected] | Soaring | 2 | January 4th 18 12:52 PM |
Jantar Standard 41b N41BZ | dam zaw | Soaring | 4 | May 5th 11 12:01 PM |
WTB: Standard Jantar or ASW-19 | Kevin Christner | Soaring | 2 | January 9th 11 05:51 PM |
Standard Jantar 48-3 & One-Man Assembly | John[_27_] | Soaring | 6 | July 20th 10 02:31 PM |
Jantar Standard 3 | Miguel Lavalle | Soaring | 9 | November 19th 03 12:01 AM |
