Easy and affordable IGC logger
Old April 17th 18, 08:31 AM posted to rec.aviation.soaring
Senna Van den Bosch
Default Easy and affordable IGC logger
Since my FLARM doesn't have an SD card slot, I'm looking for an easy to use IGC logger.
Right now, I can get the EW IGC-logger microRecorder for € 295, which has built in GPS, antenna, SD card and USB cable in the box.
An LX Nano (regular nano, no display) is also an option, which is € 399, but is from LXNav, so probably more support available, SD card, wall charger and requires no additional cables.
What would your suggestions be? Do you have experiences with any? All info is welcome, thanks!
Old April 17th 18, 10:00 AM posted to rec.aviation.soaring
Nick Hill[_3_]
With the Nano the SD card is the internal storage and the recomendation
is you do not remove it to download traces. It is easy to do over USB
or bluetooth with the Nano config app on a phone. The config app also
alows you to configure the parameters, declare tasks etc on the Nano
from your phone.
Nick Hill
Old April 17th 18, 10:43 AM posted to rec.aviation.soaring
Senna Van den Bosch
Op dinsdag 17 april 2018 11:00:59 UTC+2 schreef Nick Hill:
from your phone.
Nick Hill
That would be very handy, is it android/iOS only? Or both?
Old April 17th 18, 03:30 PM posted to rec.aviation.soaring
Dan Marotta
I have a Replogle barograph with a fresh pack of pressure sensitive
thingies and camera plus mount that you can have for the cost of
shipping. :-D
from your phone.
Nick Hill
Dan, 5J
Old April 17th 18, 12:49 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
use IGC logger.
I have one of these, which has always worked well for me.
It records on a 2GB SD card, which is easy to pop out when you're
downloading the log from it.
Its only drawback as far as I'm concerned is its power switch, which is
of the "always powered pushbutton" type. The problem here is that, during
the winter when the logger is not being used, is that the MicroRecorder
will flatten fully charged batteries in a bit over three months by
watching the switch for the 'turn on' press and, because these are NiMH
chemistry, letting them go flat for any length of time wrecks them.
However:
- All you need do to avoid this problem is to remember to charge the
Microrecorder every couple of months.
- The batteries are a set of four NiMH AA cells kept as a flat package,
with white shrink-wrap plastic and fitted with a connector on the end
of a short cable. They can be replaced without breaking the security
seal and, if you're happy to use a soldering iron, you can make up a
replacement pack rather than buying one from EW.
Martin | martin at
Gregorie | gregorie dot org
Old April 17th 18, 02:45 PM posted to rec.aviation.soaring
krasw
Original Nano has nightmarish user interface, row of leds and fiddly microscopic switch that you can also press. Better to get one with display, you at least know if it's up and running without user manual to decode led colors.
Old April 17th 18, 07:57 PM posted to rec.aviation.soaring
MNLou
I have to disagree. I turn the Nano on, make sure it has 2 blinking green lights, and I'm done until I turn it off at the end of the flight.
It doesn't get much simpler than that.
Lou
Old April 18th 18, 05:57 AM posted to rec.aviation.soaring
krasw
Lou
Except when it spontaneously turns itself off on the grid (in WGC, of course), while auto-off setting was disabled. It is ok unit but you just cannot trust these toys.
Old May 1st 18, 09:05 AM posted to rec.aviation.soaring
I find the Nano extremely user friendly, compact and easily uploaded. Just press the button and confirm the on indication light. Both my wife and I use the Nano, it is a nice reliable unit.
Old April 17th 18, 02:53 PM posted to rec.aviation.soaring
Senna Van den Bosch
Op dinsdag 17 april 2018 13:49:12 UTC+2 schreef Martin Gregorie:
use IGC logger.
However:
Martin | martin at
Would it be a problem to fix the GPS antenna of the EW MicroRecorder next to the FLARM antenna?
A path to an affordable trainer? Wallace Berry[_2_] Soaring 13 August 3rd 13 04:43 PM
Looking for an affordable glider.... xTrainwrecKx Soaring 4 August 17th 11 12:03 PM
Looking for an affordable glider.... xTrainwrecKx Soaring 1 August 9th 11 05:07 PM
Affordable Glider K Smith Soaring 20 July 23rd 09 07:13 AM
Affordable planes Tom Home Built 4 November 6th 08 08:59 PM
