Electric Self Launch System
Old June 4th 18, 05:08 PM posted to rec.aviation.soaring
Emir Sherbi
Default Electric Self Launch System
Hi everyone,
My name is Emir Sherbi, i'm a mechanical engineer from Argentina. With a partner who is an electronic engineer we've designed an electric self launching system that can be retrofitted in most of the composite sailplanes. Some of you may be saw my booth in the SSA convention in Reno with the mockup of the prototype.
The idea is to sell it as a kit so you don't have to ship the glider to my country. The modifications to be made are very simple. Any repair shop have enough knowledge to do it.
These are the links for who are interested in following the project.
https://www.instagram.com/grasshoppersystem/
https://www.facebook.com/charlysierragolf/
Kindest Regards
Old June 8th 18, 12:41 AM posted to rec.aviation.soaring
2G
On Monday, June 4, 2018 at 9:09:00 AM UTC-7, Emir Sherbi wrote:
Hi everyone,
Kindest Regards
When I stopped by your booth, you indicated that this system is still in development with much work left to be done. Is this accurate?
Tom
Old June 8th 18, 02:51 PM posted to rec.aviation.soaring
Emir Sherbi
Hi everyone,
Kindest Regards
Tom
Hi Tom
The most difficult part that we are working on is the battery pack supplier and testing. In other hand we also are starting to build our own motors, not only for this application but also for another types of vehicles (mostly agricultural). But for the US clients we can supply any already known motor brand to power the kit.
As you can see on the pages that i shared, we are starting to work on the fuselage. The pylon is on its final revision for flight testing but we are still working on the batteries.
Regards
Old June 8th 18, 08:59 PM posted to rec.aviation.soaring
2G
Hi everyone,
My name is Emir Sherbi, i'm a mechanical engineer from Argentina. With a partner who is an electronic engineer we've designed an electric self launching system that can be retrofitted in most of the composite sailplanes.. Some of you may be saw my booth in the SSA convention in Reno with the mockup of the prototype.
Kindest Regards
Tom
Hi Tom
Regards
Which battery chemistry are you going to use?
Tom
Old June 8th 18, 09:50 PM posted to rec.aviation.soaring
Emir Sherbi
Hi everyone,
These are the links for who are interested in following the project..
Kindest Regards
Tom
Hi Tom
Regards
Tom
INR and IMR, depending on the flight mission.
Regards
Old June 9th 18, 12:30 AM posted to rec.aviation.soaring
son_of_flubber
https://breazy.com/products/samsung-...50-25r-2500mah
INR 18650 2500mah Battery (2 Pack) - Samsung
20 amps of continous discharge, the Samsung 25r has been the go to battery for most vapers because of its authenticity and its transparent rating system. In terms of cell degradation the Samsung 25r has been a reliable source of power.
Old June 10th 18, 12:41 AM posted to rec.aviation.soaring
Emir Sherbi
El lunes, 4 de junio de 2018, 13:09:00 (UTC-3), Emir Sherbi escribió:
Hi everyone,
Kindest Regards
Hello,
This is another update with the work done today.
Old October 24th 18, 04:12 PM posted to rec.aviation.soaring
Emir Sherbi
More updates:
Old October 25th 18, 02:48 PM posted to rec.aviation.soaring
I suppose you will provide strong protection to the elevator linkage. If anything goes wrong in the pylon mountings, or parts get loose, you really don't want to risk interference with the elevator control.
The static and TE lines would also very much benefit from protection.
I admire all those who dare such complex work
Aldo Cernezzi
www.voloavela.it
Old October 26th 18, 03:50 AM posted to rec.aviation.soaring
Emir Sherbi
Aldo,
There will be a very thick floor and sidewalls to reinforce the fuselage structure and that will protect the control rod and cables.
If anything get loose it will stay in the motor bay.
Regards
Electric Self Launching System Emir Sherbi Soaring 0 June 4th 18 04:54 PM
FES&electric system batteries krasw Soaring 33 February 25th 17 04:17 PM
ASW24 - electric valve system Norbert Gulczynski Soaring 1 January 25th 15 01:13 PM
Electric Duct Fan (EDF) Self-Launch Glider? CLewis95 Soaring 26 January 20th 11 06:27 PM
Electric self-launch sailplane CH Soaring 2 September 14th 03 01:49 AM
