Teflon tape attaching
Old June 10th 18, 03:10 AM posted to rec.aviation.soaring
JohnO[_2_]
Default Teflon tape attaching
Can anyone tell us what glue to use to stick Teflon rubbing tape onto the nose of a rudder?
The wide Teflon tape does not come with adhesive.
email johnorto at gmail dot com
Old June 10th 18, 08:51 AM posted to rec.aviation.soaring
bumper[_4_]
If you are after a tape coating that is slippery and abrasion resistant, you don't want PTFE (Teflon). Teflon is slick, but doesn't deal with abrasion well. They do sell it with adhesive backing, try McMaster-Carr or Amazon.
Much better where abrasion is expected, would be UHMW-PE (ultra high molecular weight polyethylene). Available on Amazon. Comes in a milky clear that won't stick out like a soar thumb on white. Mostly uses an acrylic adhesive.. Note that UHMW is very strong mechanically and cannot be stretched to install on compound curves.
Another possible option is to use UHMW-PE sheet-it would have to be mechanically fixed though.
Old June 13th 18, 08:51 AM posted to rec.aviation.soaring
JohnO[_2_]
Thanks Bumper I have ordered some UHMW-PE tape from Amazon.
Old June 19th 18, 09:40 PM posted to rec.aviation.soaring
Steve Koerner
Incidentally UHMW-PE tape is ideal for providing a sliding surface for the wing spar stubs at the ledge of the fuselage spar box opening. Putting the tape there is particularly advantageous for solo assembly as it prevents abrasion damage to the bottom of spar stubs.
Wax, Teflon, Wx? Guy Acheson Soaring 31 July 10th 17 10:35 PM
Teflon tape [email protected] Owning 7 March 9th 08 03:44 AM
Ease of attaching and detaching 01-- Zero One Soaring 1 November 18th 05 07:45 PM
FS Teflon wire at Dayton RST Engineering Home Built 1 May 12th 05 01:56 AM
Teflon gap seal tape... Marc Ramsey Soaring 10 April 3rd 05 04:35 PM
